Not connected, Your IP: 18.117.183.150
When attempting to connect to VPN while connected to AT&T wireless I get "looking for Dns name" then connection timeout. Tried several different connection profiles, earth, Canada.
Please try to re-generate the configuration files in the following way:
- tick "Advanced Mode"
- tick "Resolved hosts in .ovpn files"
- tick "All servers for area or region"
If it's a DNS problem in *.vpn.airdns.org resolution, the above will fix it, because the Configuration Generator will generate files containing only IP addresses and not host names.
