hanswurst77 1 Posted ... dear staff,the other day i noticed a strange issue when i was checking my torrent ip.my real ip adress isXXXXXX; i am connected via castor which should have the ip XXXX. in emule, this ip adress is shown correctly.in utorrent, checkmytorrentip shows that my ip adress is XXXXXXXXXthanks for any ideas on this. Quote Share this post Link to post
NaDre 154 Posted ... dear staff,the other day i noticed a strange issue when i was checking my torrent ip.my real ip adress is ?; i am connected via castor which should have the ip ?. in emule, this ip adress is shown correctly.in utorrent, checkmytorrentip shows that my ip adress is ?.thanks for any ideas on this. They had problems with some trackers blocking servers. They have explained that is related to their system for avoiding this. They have asked in the past that you not publish the IP-s involved in this forum. Perhaps you should remove them? Quote Share this post Link to post
hanswurst77 1 Posted ... removed them. wasn't aware of this, thanks for the hint.i will try to contact the staff directly, then. Quote Share this post Link to post
Staff 9761 Posted ... removed them. wasn't aware of this, thanks for the hint.i will try to contact the staff directly, then. Hello! Please see here:https://airvpn.org/topic/9499-connecting-to-trackers-fails-from-different-servers/ Kind regards Quote Share this post Link to post
hanswurst77 1 Posted ... i didn't have problems connecting to the tracker.do i understand correctly that the different ip adress is due to your circumvention measures? Quote Share this post Link to post
Staff 9761 Posted ... i didn't have problems connecting to the tracker.do i understand correctly that the different ip adress is due to your circumvention measures? Yes, 100% correct. EDIT: of course we don't strictly need to "re-route" checkmytorrentip as well, but it was decided to do so for consistency and comfort. Kind regards 1 hanswurst77 reacted to this Quote Share this post Link to post
