freshair 0 Posted ... Hi,I see that I am connected to Leonis NL server, but the speed test page is not workingthe tomato router logs show "possible DNS-rebind attack detected: speedtest.air" dnsleak test says IP: 85.17.20.219Hostname: hosted-by.leaseweb.com What might be the problem? Quote Share this post Link to post
Staff 9751 Posted ... Hello, you should disable the DNS re-bind attacks filter, it's clearly a false positive probably due to the fact that speedtest.air is resolved into an address within the private network, an address which is also the VPN DNS IP address (when you connect to 443 UDP). Kind regards Quote Share this post Link to post
