strongbones 0 Posted ... I just started using airvpn today with my mac os x. Thought the installation went great but my speeds are nothing what others are apparently getting. I am getting speeds of around 300kbps and lower. When I use your speed test in the client area it says i'm getting 3mbps-5mbps down and around 3mbps up. I tried both UDP and TCP. And all ports. UDP runs faster. Pretty much all I gathered. I read up on all your FAQs and still nothing. I will post my log bellow for you. Any help would be appreciated. Thanks. *Tunnelblick: OS X 10.8.3; Tunnelblick 3.3beta52 (build 3352); Admin user Configuration file for /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk: # --------------------------------------------------------# Air VPN | https://airvpn.org | Sunday 2nd of June 2013 06:44:08 AM# OpenVPN Client Configuration# AirVPN_NL-Castor_UDP-443# -------------------------------------------------------- clientdev tunproto udpremote 95.211.169.3 443resolv-retry infinitenobindns-cert-type servercipher AES-256-CBCcomp-lzoverb 3explicit-exit-notify 5<ca> [security-related line(s) omitted]</ca><cert> [security-related line(s) omitted]</cert><key> [security-related line(s) omitted]</key> ================================================================================ Tunnelblick Log: 2013-06-01 23:44:57 *Tunnelblick: OS X 10.8.3; Tunnelblick 3.3beta52 (build 3352)2013-06-01 23:44:58 *Tunnelblick: Attempting connection with NE-CastorVPN using shadow copy; Set nameserver = 1; monitoring connection2013-06-01 23:44:58 *Tunnelblick: openvpnstart start NE-CastorVPN.tblk 1337 1 0 1 0 305 -atADGNWradsgnw 2013-06-01 23:44:58 *Tunnelblick: openvpnstart log: Loading tun.kext OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line): /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SSam-SLibrary-SApplication Support-STunnelblick-SConfigurations-SNE--CastorVPN.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_305.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --up-restart 2013-06-01 23:44:58 *Tunnelblick: Established communication with OpenVPN2013-06-01 23:44:58 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on May 13 20132013-06-01 23:44:58 MANAGEMENT: TCP Socket listening on 127.0.0.1:13372013-06-01 23:44:58 Need hold release from management interface, waiting...2013-06-01 23:44:58 MANAGEMENT: Client connected from 127.0.0.1:13372013-06-01 23:44:58 MANAGEMENT: CMD 'pid'2013-06-01 23:44:58 MANAGEMENT: CMD 'state on'2013-06-01 23:44:58 MANAGEMENT: CMD 'state'2013-06-01 23:44:58 MANAGEMENT: CMD 'bytecount 1'2013-06-01 23:44:58 MANAGEMENT: CMD 'hold release'2013-06-01 23:44:58 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts2013-06-01 23:44:58 LZO compression initialized2013-06-01 23:44:58 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]2013-06-01 23:44:58 Socket Buffers: R=[196724->65536] S=[9216->65536]2013-06-01 23:44:58 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]2013-06-01 23:44:58 Local Options hash (VER=V4): '22188c5b'2013-06-01 23:44:58 Expected Remote Options hash (VER=V4): 'a8f55717'2013-06-01 23:44:58 UDPv4 link local: [undef]2013-06-01 23:44:58 UDPv4 link remote: 95.211.169.3:4432013-06-01 23:44:58 MANAGEMENT: >STATE:1370155498,WAIT,,,2013-06-01 23:44:58 MANAGEMENT: >STATE:1370155498,AUTH,,,2013-06-01 23:44:58 TLS: Initial packet from 95.211.169.3:443, sid=c55c194d 334ce5a72013-06-01 23:44:58 *Tunnelblick: openvpnstart starting OpenVPN: * /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-SSam-SLibrary-SApplication Support-STunnelblick-SConfigurations-SNE--CastorVPN.tblk-SContents-SResources-Sconfig.ovpn.1_0_1_0_305.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --up-restart2013-06-01 23:44:59 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org2013-06-01 23:44:59 VERIFY OK: nsCertType=SERVER2013-06-01 23:44:59 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org2013-06-01 23:45:02 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key2013-06-01 23:45:02 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication2013-06-01 23:45:02 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key2013-06-01 23:45:02 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication2013-06-01 23:45:02 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA2013-06-01 23:45:02 [server] Peer Connection Initiated with 95.211.169.3:4432013-06-01 23:45:03 MANAGEMENT: >STATE:1370155503,GET_CONFIG,,,2013-06-01 23:45:05 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)2013-06-01 23:45:05 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.65.238 10.4.65.237'2013-06-01 23:45:05 OPTIONS IMPORT: timers and/or timeouts modified2013-06-01 23:45:05 OPTIONS IMPORT: LZO parms modified2013-06-01 23:45:05 OPTIONS IMPORT: --ifconfig/up options modified2013-06-01 23:45:05 OPTIONS IMPORT: route options modified2013-06-01 23:45:05 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified2013-06-01 23:45:05 ROUTE default_gateway=192.168.0.12013-06-01 23:45:05 TUN/TAP device /dev/tun0 opened2013-06-01 23:45:05 MANAGEMENT: >STATE:1370155505,ASSIGN_IP,,10.4.65.238,2013-06-01 23:45:05 /sbin/ifconfig tun0 delete ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address2013-06-01 23:45:05 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure2013-06-01 23:45:05 /sbin/ifconfig tun0 10.4.65.238 10.4.65.237 mtu 1500 netmask 255.255.255.255 up2013-06-01 23:45:05 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw tun0 1500 1558 10.4.65.238 10.4.65.237 init2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: Retrieved from OpenVPN: name server(s) [ 10.4.0.1 ], search domain(s) [ ] and SMB server(s) [ ] and using default domain name [ openvpn ]2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = <dictionary> { }2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 68.105.28.11 68.105.29.11 68.105.28.12 } }2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = No such key2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.4.0.1; DYN_DNS_SD =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = ; MAN_DNS_SD =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 68.105.28.11 68.105.29.11 68.105.28.12; CUR_DNS_SD =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses were not aggregated because running on OS X 10.6 or higher2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 10.4.0.1; FIN_DNS_SD = openvpn2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.8 or higher, so will modify DNS settings using Setup: in addition to State:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS =2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = #2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: /etc/resolve = nameserver 68.105.28.11 nameserver 68.105.29.11 nameserver 68.105.28.122013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: scutil --dns BEFORE CHANGES = DNS configuration resolver #1 nameserver[0] : 68.105.28.11 nameserver[1] : 68.105.29.11 nameserver[2] : 68.105.28.12 if_index : 5 (en1) reach : Reachable resolver #2 domain : local options : mdns timeout : 5 order : 300000 resolver #3 domain : 254.169.in-addr.arpa options : mdns timeout : 5 order : 300200 resolver #4 domain : 8.e.f.ip6.arpa options : mdns timeout : 5 order : 300400 resolver #5 domain : 9.e.f.ip6.arpa options : mdns timeout : 5 order : 300600 resolver #6 domain : a.e.f.ip6.arpa options : mdns timeout : 5 order : 300800 resolver #7 domain : b.e.f.ip6.arpa options : mdns timeout : 5 order : 301000 DNS configuration (for scoped queries) resolver #1 nameserver[0] : 68.105.28.11 nameserver[1] : 68.105.29.11 nameserver[2] : 68.105.28.12 if_index : 5 (en1) flags : Scoped reach : Reachable2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 10.4.0.12013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: ServerAddresses 10.4.0.12013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: SearchDomains openvpn2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: DomainName openvpn2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:07 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes:2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } }2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = No such key2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } }2013-06-01 23:45:08 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } }2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = No such key2013-06-01 23:45:09 *Tunnelblick: No 'connected.sh' script to execute2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 10.4.0.1 } }2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { TunnelblickNoSuchKey : true }2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: /etc/resolve = search openvpn nameserver 10.4.0.12013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG: scutil --dns AFTER CHANGES = DNS configuration resolver #1 search domain[0] : openvpn nameserver[0] : 10.4.0.1 reach : Reachable resolver #2 domain : local options : mdns timeout : 5 order : 300000 resolver #3 domain : 254.169.in-addr.arpa options : mdns timeout : 5 order : 300200 resolver #4 domain : 8.e.f.ip6.arpa options : mdns timeout : 5 order : 300400 resolver #5 domain : 9.e.f.ip6.arpa options : mdns timeout : 5 order : 300600 resolver #6 domain : a.e.f.ip6.arpa options : mdns timeout : 5 order : 300800 resolver #7 domain : b.e.f.ip6.arpa options : mdns timeout : 5 order : 301000 DNS configuration (for scoped queries) resolver #1 search domain[0] : openvpn nameserver[0] : 10.4.0.1 if_index : 5 (en1) flags : Scoped reach : Reachable2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: DEBUG:2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: Flushed the DNS Cache2013-06-01 23:45:09 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with leasewatch2013-06-01 23:45:14 *Tunnelblick leasewatch: A system configuration change was ignored because it was not relevant2013-06-01 23:45:15 *Tunnelblick: This computer's apparent public IP address changed from 68.104.98.235 before connection to 95.211.169.45 after connection ================================================================================ Console Log: 2013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 468771842013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 468771842013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 468771842013-06-01 23:26:00 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:26:00 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 468771842013-06-01 23:26:12 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:26:12 authexec[8539] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:26:12 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:26:12. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk2013-06-01 23:26:12 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk2013-06-01 23:26:56 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:26:56 authexec[8552] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:26:57 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:26:57. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-tEBNCQ/NE-CastorVPN80.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-tEBNCQ/NE-CastorVPN80.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN80.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN80.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN80.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN80.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN80.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN80.tblk2013-06-01 23:27:06 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info could not be fetched within 5.0 seconds2013-06-01 23:27:06 Tunnelblick[2096] After 5.0 seconds, gave up trying to fetch IP address information before connecting2013-06-01 23:28:41 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:41 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:44 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:44 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:44 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: has checked for active daemons2013-06-01 23:28:44 Tunnelblick[2096] DEBUG: includeDaemons = 0; noUnknownOpenVPNsRunning = 1; noActiveDaemons = 1 2013-06-01 23:28:44 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: will use killAll2013-06-01 23:28:44 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: requested killAll2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:46 Tunnelblick[2096] disconnect: while disconnecting2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:46 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:28:47 Tunnelblick[2096] openvpnstart stderr from killall: stderr from killall: No matching processes were found2013-06-01 23:28:47 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:28:47 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:28:47 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467573762013-06-01 23:29:07 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:29:08 authexec[8578] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:29:09 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:29:09. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN80.tblk2013-06-01 23:29:09 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN80.tblk2013-06-01 23:29:36 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:29:36 authexec[8590] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:29:36 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:29:36. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-ytLGJ4/NE-CastorVPN018.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-ytLGJ4/NE-CastorVPN018.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN018.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN018.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN018.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN018.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN018.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN018.tblk2013-06-01 23:29:43 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 323 milliseconds2013-06-01 23:29:43 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [68.104.98.235, 64519, 205.233.73.66]2013-06-01 23:29:56 Tunnelblick[2096] DEBUG: addActiveIPCheckThread: threadID '46426624-34699095618604' added to the active list2013-06-01 23:29:56 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: Delaying 5.000000 seconds before checking connection2013-06-01 23:30:02 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 938 milliseconds2013-06-01 23:30:02 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [95.211.169.45, 64533, 205.233.73.66]2013-06-01 23:30:02 Tunnelblick[2096] DEBUG: isOnCancellingListIPCheckThread: threadID '46426624-34699095618604' is not on the the cancelling list2013-06-01 23:30:02 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: fetched IP address 95.211.169.452013-06-01 23:30:02 Tunnelblick[2096] DEBUG: haveFinishedIPCheckThread: threadID '46426624-34699095618604' removed from active list2013-06-01 23:33:06 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:06 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:06 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: has checked for active daemons2013-06-01 23:33:06 Tunnelblick[2096] DEBUG: includeDaemons = 0; noUnknownOpenVPNsRunning = 1; noActiveDaemons = 1 2013-06-01 23:33:06 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: will use killAll2013-06-01 23:33:06 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: requested killAll2013-06-01 23:33:11 Tunnelblick[2096] openvpnstart stderr from killall: Error: Timeout (5 seconds) waiting for openvpn process(es) to terminate2013-06-01 23:33:11 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:33:12 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464266242013-06-01 23:33:18 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:33:18 authexec[8961] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:33:19 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:33:18. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN018.tblk2013-06-01 23:33:19 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN018.tblk2013-06-01 23:34:14 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:34:14 authexec[8974] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:34:15 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:34:15. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-LS74I3/NE-CastorVPN.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-LS74I3/NE-CastorVPN.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN.tblk2013-06-01 23:34:20 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 271 milliseconds2013-06-01 23:34:20 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [68.104.98.235, 64608, 205.233.73.66]2013-06-01 23:34:31 Tunnelblick[2096] DEBUG: addActiveIPCheckThread: threadID '38983680-34973793080281' added to the active list2013-06-01 23:34:31 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: Delaying 5.000000 seconds before checking connection2013-06-01 23:34:41 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 4980 milliseconds2013-06-01 23:34:41 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [95.211.169.45, 64623, 205.233.73.66]2013-06-01 23:34:41 Tunnelblick[2096] DEBUG: isOnCancellingListIPCheckThread: threadID '38983680-34973793080281' is not on the the cancelling list2013-06-01 23:34:41 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: fetched IP address 95.211.169.452013-06-01 23:34:41 Tunnelblick[2096] DEBUG: haveFinishedIPCheckThread: threadID '38983680-34973793080281' removed from active list2013-06-01 23:35:14 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:35:14 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 389836802013-06-01 23:35:14 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: has checked for active daemons2013-06-01 23:35:14 Tunnelblick[2096] DEBUG: includeDaemons = 0; noUnknownOpenVPNsRunning = 1; noActiveDaemons = 1 2013-06-01 23:35:14 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: will use killAll2013-06-01 23:35:14 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: requested killAll2013-06-01 23:35:19 Tunnelblick[2096] openvpnstart stderr from killall: Error: Timeout (5 seconds) waiting for openvpn process(es) to terminate2013-06-01 23:35:19 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:35:20 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:35:20 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 389836802013-06-01 23:35:20 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:35:20 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 389836802013-06-01 23:35:39 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:35:39 authexec[9329] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:35:39 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:35:39. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk2013-06-01 23:35:39 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk2013-06-01 23:35:47 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:35:47 authexec[9336] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:35:47 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:35:47. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-NFJROa/NE-CastorVPN.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-NFJROa/NE-CastorVPN.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN.tblk2013-06-01 23:35:58 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info could not be fetched within 5.0 seconds2013-06-01 23:35:58 Tunnelblick[2096] After 5.0 seconds, gave up trying to fetch IP address information before connecting2013-06-01 23:36:38 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:36:38 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 381358082013-06-01 23:36:38 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: has checked for active daemons2013-06-01 23:36:38 Tunnelblick[2096] DEBUG: includeDaemons = 0; noUnknownOpenVPNsRunning = 1; noActiveDaemons = 1 2013-06-01 23:36:38 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: will use killAll2013-06-01 23:36:38 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: requested killAll2013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 381358082013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 381358082013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 381358082013-06-01 23:36:43 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:36:43 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 381358082013-06-01 23:36:51 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:36:51 authexec[9364] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:36:51 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:36:51. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk2013-06-01 23:36:51 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk2013-06-01 23:37:10 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:37:10 authexec[9374] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:37:11 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:37:10. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-U5ZqcP/NE-CastorVPN.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-U5ZqcP/NE-CastorVPN.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN.tblk2013-06-01 23:37:23 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 298 milliseconds2013-06-01 23:37:23 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [68.104.98.235, 64685, 205.233.73.66]2013-06-01 23:37:34 Tunnelblick[2096] DEBUG: addActiveIPCheckThread: threadID '46736896-35157460058776' added to the active list2013-06-01 23:37:34 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: Delaying 5.000000 seconds before checking connection2013-06-01 23:37:40 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 855 milliseconds2013-06-01 23:37:40 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [95.211.169.45, 64695, 205.233.73.66]2013-06-01 23:37:40 Tunnelblick[2096] DEBUG: isOnCancellingListIPCheckThread: threadID '46736896-35157460058776' is not on the the cancelling list2013-06-01 23:37:40 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: fetched IP address 95.211.169.452013-06-01 23:37:40 Tunnelblick[2096] DEBUG: haveFinishedIPCheckThread: threadID '46736896-35157460058776' removed from active list2013-06-01 23:38:45 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:38:45 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467368962013-06-01 23:38:45 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: has checked for active daemons2013-06-01 23:38:45 Tunnelblick[2096] DEBUG: includeDaemons = 0; noUnknownOpenVPNsRunning = 1; noActiveDaemons = 1 2013-06-01 23:38:45 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: will use killAll2013-06-01 23:38:45 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: requested killAll2013-06-01 23:38:51 Tunnelblick[2096] openvpnstart stderr from killall: Error: Timeout (5 seconds) waiting for openvpn process(es) to terminate2013-06-01 23:38:51 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:38:53 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:38:53 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467368962013-06-01 23:38:53 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:38:53 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 467368962013-06-01 23:38:59 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:38:59 authexec[9741] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:38:59 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:38:59. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk2013-06-01 23:38:59 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk2013-06-01 23:39:25 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:39:25 authexec[9753] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:39:26 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:39:25. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-m71hhi/NE-CastorVPN.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-m71hhi/NE-CastorVPN.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN.tblk2013-06-01 23:39:37 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 290 milliseconds2013-06-01 23:39:37 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [68.104.98.235, 64728, 205.233.73.66]2013-06-01 23:39:48 Tunnelblick[2096] DEBUG: addActiveIPCheckThread: threadID '46458880-35290989951380' added to the active list2013-06-01 23:39:48 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: Delaying 5.000000 seconds before checking connection2013-06-01 23:39:54 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 903 milliseconds2013-06-01 23:39:54 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [95.211.169.45, 64739, 205.233.73.66]2013-06-01 23:39:54 Tunnelblick[2096] DEBUG: isOnCancellingListIPCheckThread: threadID '46458880-35290989951380' is not on the the cancelling list2013-06-01 23:39:54 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: fetched IP address 95.211.169.452013-06-01 23:39:54 Tunnelblick[2096] DEBUG: haveFinishedIPCheckThread: threadID '46458880-35290989951380' removed from active list2013-06-01 23:43:10 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:43:10 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464588802013-06-01 23:43:10 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: has checked for active daemons2013-06-01 23:43:10 Tunnelblick[2096] DEBUG: includeDaemons = 0; noUnknownOpenVPNsRunning = 1; noActiveDaemons = 1 2013-06-01 23:43:10 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: will use killAll2013-06-01 23:43:10 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: requested killAll2013-06-01 23:43:15 Tunnelblick[2096] openvpnstart stderr from killall: Error: Timeout (5 seconds) waiting for openvpn process(es) to terminate2013-06-01 23:43:15 Tunnelblick[2096] DEBUG: killAllConnectionsIncludingDaemons: killAll finished2013-06-01 23:43:16 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:43:16 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464588802013-06-01 23:43:16 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: Entered2013-06-01 23:43:16 Tunnelblick[2096] DEBUG: cancelAllIPCheckThreadsForConnection: No active threads for connection 464588802013-06-01 23:44:19 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:44:19 authexec[10123] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:44:19 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:44:19. 2 arguments: 0x2001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk removed /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk DEBUG 005: firstPath prefix DID match: /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /Users/Sam/Library/Application Support/Tunnelblick/Configurations removed /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk2013-06-01 23:44:19 Tunnelblick[2096] Uninstalled configuration file /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk2013-06-01 23:44:50 Tunnelblick[2096] Beginning installation or repair2013-06-01 23:44:50 authexec[10133] executing /Applications/Tunnelblick.app/Contents/Resources/installer2013-06-01 23:44:50 Tunnelblick[2096] Installation or repair succeeded; Log: Tunnelblick installer started 2013-06-01 23:44:50. 3 arguments: 0x0001 /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-ahzkuF/NE-CastorVPN.tblk Copied /private/var/folders/d6/5f7zxbjd3yv_j_hl633rnrgh0000gn/T/TunnelblickTemporaryDotTblk-ahzkuF/NE-CastorVPN.tblk to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk.temp to /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed ownership of /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk and its contents to 501:80 Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents Changed permissions from 755 to 750 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources Changed permissions from 644 to 640 on /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Copied /Users/Sam/Library/Application Support/Tunnelblick/Configurations/NE-CastorVPN.tblk to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp Copied /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk.temp to /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk Changed ownership of /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk and its contents to 0:0 Changed permissions from 640 to 600 on /Library/Application Support/Tunnelblick/Users/Sam/NE-CastorVPN.tblk/Contents/Resources/config.ovpn Created secure (shadow) copy of NE-CastorVPN.tblk2013-06-01 23:44:57 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 341 milliseconds2013-06-01 23:44:57 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [68.104.98.235, 64882, 205.233.73.66]2013-06-01 23:45:09 Tunnelblick[2096] DEBUG: addActiveIPCheckThread: threadID '38389248-35612029518245' added to the active list2013-06-01 23:45:09 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: Delaying 5.000000 seconds before checking connection2013-06-01 23:45:15 Tunnelblick[2096] DEBUG: currentIPInfo(Name): IP address info was fetched in 834 milliseconds2013-06-01 23:45:15 Tunnelblick[2096] DEBUG: currentIPInfo(Name): [95.211.169.45, 64894, 205.233.73.66]2013-06-01 23:45:15 Tunnelblick[2096] DEBUG: isOnCancellingListIPCheckThread: threadID '38389248-35612029518245' is not on the the cancelling list2013-06-01 23:45:15 Tunnelblick[2096] DEBUG: checkIPAddressAfterConnectedThread: fetched IP address 95.211.169.45 Quote Share this post Link to post
Staff 9750 Posted ... Hello, it's normal that you get higher performance over UDP. Try also different servers and different ports (in particular 53 UDP, just in case your ISP shapes outbound port 443 UDP) in order to determine the server that can give you the best performance. Since you get 3-5 Mbit/s with internal speedtest (which is performed on the server itself) the alleged 300 kbit/s bandwidth does not seem a problem between your ISP and the server. Kind regards Quote Share this post Link to post
strongbones 0 Posted ... I tried all of the ports and I get similar to lower mbps with all of them. What was interested was that Port 53 UDP speed up the internal test to 10mpbs + but while I actually get 300kbps still. I also get a warning message before the server gets connected that says: WarningAfter 5.0 seconds, gave up trying to fetch IP address information.Tunnelblick will not check that this computer's apparent IP address changes when conected Quote Share this post Link to post
Staff 9750 Posted ... Hello, if the speedtest reports 10 Mbit/s, how do you infer 300 kbit/s? Kind regards Quote Share this post Link to post
strongbones 0 Posted ... I get around 300 kbit/s while downloading anything onto my computer whether it be via torrent or whatever. I only have those 10mbit/s speeds while I am using the speedtest. BTW the warning message I was referring to in my last post has disappeared. I no longer get that error window popping up. Quote Share this post Link to post
