ru95 0 Posted ... I realize this maybe more of a youtube issue than a airvpn issue but if anyone can help it would be greatly appreciated. When I use airvpn and try and watch youtube with hd streams over udp it buffers to slow so the playback stops or sometimes the buffer just stops all together. If i switch the protocol over to tcp most of the time the buffer is faster and plays with no issues but torrent speeds are cut in half over tcp. I have tried changing the port with the air. client and my packet timeout setting on my router and nothing helps anyone got any ideas on how i maybe able to fix this? Quote Share this post Link to post
Staff 9761 Posted ... Hello! Normally the opposite is true (UDP over UDP is much better for streaming). Have you checked in the logs if your system experiences packet loss or packet fragmentation? If in doubt do not hesitate to send us your client logs (taken after some minutes your system is connected) for a check. Kind regards Quote Share this post Link to post
ru95 0 Posted ... I think i fixed the issue I was using chrome so I installed firefox and firefox was even worse it even had problems with standard def. video. I decided to try chromium installed the latest stable build and have had no problems at all I don't get it chrome is basically chromium with some google crap installed. ps. There is a issue with chromium I just noticed when you try read the airvpn forums the tab will crash the only way it will open the link is right click and say open in new tab window I have checked other forums as well so far it only appears to do this with airvpn Quote Share this post Link to post
Staff 9761 Posted ... Hello! We don't detect any problem with Chromium:Version 26.0.1410.43 Debian 7.0 (189671) Which Chromium version crashes in your system when you click the "Forums" tab? The differences you detect with YouTube videos are also quite puzzling (we do not detect any difference between Iceweasel (Debian), Firefox (Debian), Chrome (Windows) and Chromium (Debian)), just for information do you play them "in Flash" or "in HTML5"? Kind regards Quote Share this post Link to post
ru95 0 Posted ... Hello! We don't detect any problem with Chromium:Version 26.0.1410.43 Debian 7.0 (189671) Which Chromium version crashes in your system when you click the "Forums" tab? The differences you detect with YouTube videos are also quite puzzling (we do not detect any difference between Iceweasel (Debian), Firefox (Debian), Chrome (Windows) and Chromium (Debian)), just for information do you play them "in Flash" or "in HTML5"? Kind regards I'm using chromium 2982 I'm using flash with youtube chromium is working expect for your website is there a a error log that i can send you? Quote Share this post Link to post
Staff 9761 Posted ... Hello! Yes, please first enable Chromium logging:http://www.chromium.org/for-testers/enable-logging then send us the logs (only those generated when the tab crashes). Also, when you select "About Chromium", what is the displayed version? Kind regards Quote Share this post Link to post
