Not connected, Your IP: 34.224.33.93
NaDre
ANSWERED problem with new features for Config Generator
We're glad to inform you that the Configuration Generator has been re-designed and that new features have been added:
  • Operating System selection
  • SSH & SSL support to OS X
  • Bundle executables with OS X
  • Advanced option -> File prefix
  • Advanced option -> Custom directives
  • Added explanation tooltips
  • SSH & SSL guides updated to OS X
  • Minor fixes
Kind regards & datalove
AirVPN Staff
I encountered a problem using the new "Advanced option -> Custom directives" feature. I specified that I wanted this line to be appended:
config ../AirVPN_include/2_myroute.ovpni
But what I got was:
This off course did not work.
Also, I discovered that the new "Advanced option -> File prefix" places an underscore character (_) between the prefix and the rest of the file name. I had included an underscore already at the end of my prefix, so I got two underscore characters. Perhaps the help box that you get when you hover the mouse over the text box should warn that it will do this?
Thanks, the encoding problem has been fixed.
Also, an additional underscore is not added now if one is already entered in the field.
AirVPN Support Team
Hello all
could someone send for us beginners some link where is explained what to tick and choose from connection mode (on left side) and what in Proxy (on right side) ?
should I choose "Direct, protocol TCP, port 53" or "port 80" or more ports in advanced mode?? and Proxy http or socks? and Authentication " none?" because it is easier or better is to have password?
thank you in advance
OpenVPN has the ability to connect over a socks 4/5 or http proxy. Connections may or may not require authentication, according to how the proxy is configured. You need to connect over a proxy if you're behind a proxy (according to your questions, very probably you are not). You might like to connect over a proxy, even if you're not behind a proxy, in special cases (a didactic example is here https://airvpn.org/tor).
Please spend 2 minutes to read the instructions in the configuration generator page. If you click on "More help" on the configuration generator page, you will see the answers to your questions. FAQ are also an important resource for more details.
FAQ are available here: https://airvpn.org/forum/24-frequently-asked-questions
