Not connected, Your IP: 18.189.180.76
GoXRUTD7k8FfZp5jmvNK4uE6
ANSWERED [SOLVED] Port Forwarding Bug: Hitting Enter to Add a Port Removes a Port
When attempting to add a port, typing in the port number followed by the Enter key does not function correctly (submit the port to be added) but in fact deletes a previous port that has been forwarded (the first/lowest port).
This could possibly be a side effect of the recent bugfix.
Also, I'm now getting "Port X already assigned to you." when trying to add a port back even though it's not shown. "You are using 3 of 20 ports available." I see 3, but it's reporting the 4th one is still assigned. Could be temporary.
EDIT: Now showing 4 of 20 and the port has been added back however the main issue of the topic still persists.
Edited ... by GoXRUTD7k8FfZp5jmvNK4uE6
