Gavtherocker 0 Posted ... Hello, I have used port forwarding with your site and u torrent for almost a year with no problems. Since about last Friday however it has been almost impossible to get it working. Nothing has changed my end.When I connect to a server, I use port forwarding which now gives you a double token check, one in black the other blank. When you perform a check the other will turn black. If you add another port, another double will come up. And so on. After re-booting the machine and connecting to a different server I may strike lucky (i think anyway) and get one black port and one green.My download speeds on u torrent are all over the place though.I took a screen shot but it says uploading is not allowed? and won't upload the capture (217 kb) I've just used copy and paste 11692 0 seconds ago. Reachable on server IP over the external port 11692, tcp protocol. 11692 3029 seconds ago. Not reachable on server IP over the external port 11692, tcp protocol. Error : 110 - Connection timed out Quote Share this post Link to post
Staff 9751 Posted ... (Issue handled in the support ticket system) Quote Share this post Link to post
