ajguil4d 0 Posted ... So I have been looking for an option that would allow me to maintain a good ratio with torrents. I know that some ISPs and definitely Verizon caps that upload. Thus a friend suggested I try AirVPN. I have now been trying to get this set up so that I gould at least get 100kbps upload speeds but with no luck. Currently the maximum I see is about 1-2kbps. I have Verizon ISP and originally I had DNS leaks until I used the automatic fix method found here, http://www.dnsleaktest.com/how-to-fix-a-dns-leak.php . Also according to the site and uTorrent and Tixati the ports are properly forwarding. I really do not know what I am missing here. Does anyone have any advice or has anyone seen this before? Quote Share this post Link to post
Staff 9761 Posted ... Hello! In order to let us provide a preliminary overview, can you please send us your client connection logs? Kind regards Quote Share this post Link to post
ajguil4d 0 Posted ... Here is the openVPN logs fo the server i was connecting too. Let me know if this isnt what you were lookign for or what additional information I can give.AirVPN_US-Librae_UDP-443.txt Quote Share this post Link to post
Staff 9761 Posted ... Hello! The logs are fine. The first thing you can try is a connection to a different port: maybe Verizon performs port shaping on outbound port 443 UDP. Please test connections to 53 UDP and 80 TCP to make a performance comparison test. Kind regards Quote Share this post Link to post
