noddy4life 0 Posted ... Hi i seem to be only ever connected once then i disconnected because i wanted a different country i am running windows 64bit i have done run with administrator and i paid for 3 month access here is my log for openvpn Mon Sep 26 19:52:53 2011 OpenVPN 2.2.1 Win32-MSVC++ [sSL] [LZO2] built on Jul 1 2011 Mon Sep 26 19:52:53 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:52:53 2011 LZO compression initialized Mon Sep 26 19:52:53 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:52:53 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:52:53 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:52:53 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:52:53 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:52:53 2011 UDPv4 link local: [undef] Mon Sep 26 19:52:53 2011 UDPv4 link remote: 174.140.166.91:443 Mon Sep 26 19:53:54 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Mon Sep 26 19:53:54 2011 TLS Error: TLS handshake failed Mon Sep 26 19:53:54 2011 TCP/UDP: Closing socket Mon Sep 26 19:53:54 2011 SIGUSR1[soft,tls-error] received, process restarting Mon Sep 26 19:53:54 2011 Restart pause, 2 second(s) Mon Sep 26 19:53:56 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:53:56 2011 Re-using SSL/TLS context Mon Sep 26 19:53:56 2011 LZO compression initialized Mon Sep 26 19:53:56 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:53:56 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:53:56 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:53:56 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:53:56 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:53:56 2011 UDPv4 link local: [undef] Mon Sep 26 19:53:56 2011 UDPv4 link remote: 174.140.166.91:443 Mon Sep 26 19:54:56 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Mon Sep 26 19:54:56 2011 TLS Error: TLS handshake failed Mon Sep 26 19:54:56 2011 TCP/UDP: Closing socket Mon Sep 26 19:54:56 2011 SIGUSR1[soft,tls-error] received, process restarting Mon Sep 26 19:54:56 2011 Restart pause, 2 second(s) Mon Sep 26 19:54:59 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:54:59 2011 Re-using SSL/TLS context Mon Sep 26 19:54:59 2011 LZO compression initialized Mon Sep 26 19:54:59 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:54:59 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:54:59 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:54:59 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:54:59 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:54:59 2011 UDPv4 link local: [undef] Mon Sep 26 19:54:59 2011 UDPv4 link remote: 174.140.166.91:443 Mon Sep 26 19:55:59 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Mon Sep 26 19:55:59 2011 TLS Error: TLS handshake failed Mon Sep 26 19:55:59 2011 TCP/UDP: Closing socket Mon Sep 26 19:55:59 2011 SIGUSR1[soft,tls-error] received, process restarting Mon Sep 26 19:55:59 2011 Restart pause, 2 second(s) Mon Sep 26 19:56:01 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:56:01 2011 Re-using SSL/TLS context Mon Sep 26 19:56:01 2011 LZO compression initialized Mon Sep 26 19:56:01 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:56:01 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:56:01 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:56:01 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:56:01 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:56:01 2011 UDPv4 link local: [undef] Mon Sep 26 19:56:01 2011 UDPv4 link remote: 174.140.166.91:443 Mon Sep 26 19:57:01 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Mon Sep 26 19:57:01 2011 TLS Error: TLS handshake failed Mon Sep 26 19:57:01 2011 TCP/UDP: Closing socket Mon Sep 26 19:57:01 2011 SIGUSR1[soft,tls-error] received, process restarting Mon Sep 26 19:57:01 2011 Restart pause, 2 second(s) Mon Sep 26 19:57:03 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:57:03 2011 Re-using SSL/TLS context Mon Sep 26 19:57:03 2011 LZO compression initialized Mon Sep 26 19:57:03 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:57:03 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:57:03 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:57:03 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:57:03 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:57:03 2011 UDPv4 link local: [undef] Mon Sep 26 19:57:03 2011 UDPv4 link remote: 174.140.166.91:443 Mon Sep 26 19:58:03 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Mon Sep 26 19:58:03 2011 TLS Error: TLS handshake failed Mon Sep 26 19:58:03 2011 TCP/UDP: Closing socket Mon Sep 26 19:58:03 2011 SIGUSR1[soft,tls-error] received, process restarting Mon Sep 26 19:58:03 2011 Restart pause, 2 second(s) Mon Sep 26 19:58:05 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:58:05 2011 Re-using SSL/TLS context Mon Sep 26 19:58:05 2011 LZO compression initialized Mon Sep 26 19:58:05 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:58:05 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:58:05 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:58:05 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:58:05 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:58:05 2011 UDPv4 link local: [undef] Mon Sep 26 19:58:05 2011 UDPv4 link remote: 174.140.166.91:443 Mon Sep 26 19:59:05 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Mon Sep 26 19:59:05 2011 TLS Error: TLS handshake failed Mon Sep 26 19:59:05 2011 TCP/UDP: Closing socket Mon Sep 26 19:59:05 2011 SIGUSR1[soft,tls-error] received, process restarting Mon Sep 26 19:59:05 2011 Restart pause, 2 second(s) Mon Sep 26 19:59:07 2011 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables Mon Sep 26 19:59:07 2011 Re-using SSL/TLS context Mon Sep 26 19:59:07 2011 LZO compression initialized Mon Sep 26 19:59:07 2011 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ] Mon Sep 26 19:59:07 2011 Socket Buffers: R=[8192->8192] S=[8192->8192] Mon Sep 26 19:59:07 2011 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ] Mon Sep 26 19:59:07 2011 Local Options hash (VER=V4): '22188c5b' Mon Sep 26 19:59:07 2011 Expected Remote Options hash (VER=V4): 'a8f55717' Mon Sep 26 19:59:07 2011 UDPv4 link local: [undef] Mon Sep 26 19:59:07 2011 UDPv4 link remote: 174.140.166.91:443 Quote Share this post Link to post
Staff 9691 Posted ... >>> Mon Sep 26 19:58:03 2011 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity) Hello! It seems there's a TLS negotiation problem. Can you please check that you have copied all the files in the air.zip archive inside your OpenVPN configuration directory? Can you please check your network connectivity - it might be that connections of that kind are disrupted by your ISP - please try a connection on port 80 TCP, or on port 53 TCP. Feel free to open a ticket if the problem is not solved on port 80 TCP and on port 53 TCP. Kind regards AirVPN admins Quote Share this post Link to post
jmsrie 0 Posted ... Hi, anybody can help me. I went to OpenVPN Configuration Generator page and it says "No modes available, sorry.". how can i generate the config file? Please help. Thanks! Quote Share this post Link to post
Staff 9691 Posted ... jmsrie wrote:Hi, anybody can help me. I went to OpenVPN Configuration Generator page and it says "No modes available, sorry.". how can i generate the config file?Please help. Thanks!Hello!Can you please make sure that your account is on "premium" status? You need to subscribe to connect to the VPN servers.Do not hesitate to write again for any further information.Kind regardsAirVPN admins Quote Share this post Link to post
