oldfart 0 Posted ... Hi support et al, I have :- 1. Paid a subscription 2. Downloaded a AirVPN Windows 32 Client + Open VPN 3. I installed Open VPN 4. I ran AirVPN 5. I have logged in through AirVPN - I assume successfully Now what happens ? If I run a web browser it still uses/detects my normal IP ? I may be old and nearly deaf - but I'm not blind and I haven't been able to find any detailed installation info for AirVPN. Another thing I have noticed is that "TAP-Windows Adapter V9" is continually "Acquiring a Network address". I have created some *.ovpn from AirVPN and tried running OpenVPN directly - but it won't authenticate. Some suggestions would certainly be appreciated. BTW: I have never used a VPN before. cheers OldFart :? Quote Share this post Link to post
Staff 10397 Posted ... Hello! Thank you for your susbscription. The Air client is a stand-alone executable, it does not need installation. OpenVPN requires installation. Instructions for supported systems are in menu "Enter". Direct link for Windows: https://airvpn.org/windows After you have launched the Air client browse to https://airvpn.org and check the central bottom box. If your system is connected it's green, otherwise it's red. Please send us your client logs after an attempted connection: right-click on the Air dock icon, select "Logs", click on "Copy to clipboard" and paste in a message. Kind regards Quote Share this post Link to post
oldfart 0 Posted ... Hi Support aka admin, Thank you for your rapid response and tips. I will suggest that you make a "sticky" in your forums for Installation i.e. to the "Enter" web page - as once I had registered - I "tended" to ignore the "Enter" Tab and only looked at the "Support" and "Member Area" links/Tabs. But back on topic - I have just run up IE and checked my IP and - yep - it sure ain't mine I am still posting this from FireFox and just checked my IP - and yep - it too isn't mine - lol I am guessing my problem was that I opened the *.zip file and then ran the OpenVNC install and then tried using the AirVPN client. I will try again tomorrow using my VM version of Ubuntu and see if I can get it correct there as well. I must say I appreciate the very quick response! Kudos to you guys! cheers OldFart Quote Share this post Link to post
