mightymike 0 Posted ... When I try to connect through OpenVPN it says connected, but when I check AirVPN site it says not connected. When I Google the ip address it shows my actual ip address. Quote Share this post Link to post
Staff 9751 Posted ... When I try to connect through OpenVPN it says connected, but when I check AirVPN site it says not connected. When I Google the ip address it shows my actual ip address.Hello!Please send us your client logs (just after a connection to the VPN) at your convenience.What do you mean with "Google the IP address"?Kind regards Quote Share this post Link to post
mightymike 0 Posted ... Sorry but when I try to look at the client log it says it can not locate it and ask if I want to create it. But my connection still states: OpenVPN GUI Connected to AirVPN US Librae - UDP 443 Connected since 2/27/2013 2:22 PM Assigned IP: 10.4.40.98 To answer your question about "Google ip address" I meant I used a program on line to verify my ip address. So I guess to be safe I will continue to use the AirVPN exe Quote Share this post Link to post
mightymike 0 Posted ... Problem solved. After running program compatibility I was required to give administrator priviledge for the program. Quote Share this post Link to post
