Not connected, Your IP: 3.144.172.115
swoboda.wolnosc
Linux openvpn airvpn and ip route - not working connection
Hi. My connection to the vpn does not work.
ifconfig:
http://pastebin.com/Qd2eD38W
ip route:
http://pastebin.com/J8Cs7eSs
openvpn output:
http://pastebin.com/jPY2b1Uh
Then I run "openvpn AirVPN\ SG\ Columbae\ -\ UDP\ 443.ovpn"
"ping google.pl" - unknow host
"ping 10.4.10.246" - 3 packets transmitted, 0 received, 100% packet loss, time 1999ms
"ping 10.4.10.245" - 3 packets transmitted, 0 received, 100% packet loss, time 1999ms
These two IP addresses(10.4.10.245/10.4.10.246) is the tun0 interface inet and destination
The connection is working then I type the following commands:
"ip route del defaults"
"ip route add defaults via 10.64.64.64" - ppp0 destination
"openvpn Air...blablabla"
but when the ppp(wvdial) connection broke/restart, my real IP is leaking(it is a problem) :/ and then ip route says:
"default dev ppp0 scope link
10.64.64.64 dev ppp0 proto kernel scope link src 10.138.144.180"
I use arch linux.
Sorry for my english :]
