Zxurian 3 Posted ... when I run the AirVpn client, it lets me log in, then when I pick a server, it just says "Connecting" ..... but won't actually finish. Quote Share this post Link to post
Staff 10423 Posted ... when I run the AirVpn client, it lets me log in, then when I pick a server, it just says "Connecting" ..... but won't actually finish.Hello!Can you please send us the connection logs?Kind regards Quote Share this post Link to post
Zxurian 3 Posted ... 2/6/2013 - 3:49 PM AirVPN client version: 1.8 2/6/2013 - 3:49 PM Reading options from C:\Users\Zxurian\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 2/6/2013 - 3:49 PM Uninstalling OpenVPN... 2/6/2013 - 3:49 PM Installing OpenVPN... 2/6/2013 - 3:51 PM OpenVPN installed successfully. 2/6/2013 - 3:51 PM OpenVPN bundle version: OpenVPN 2.3.0 2/6/2013 - 3:51 PM OpenVPN current version: OpenVPN 2.3.0 2/6/2013 - 3:51 PM Ready. 2/6/2013 - 3:52 PM Login... 2/6/2013 - 3:52 PM Login success. 2/6/2013 - 3:52 PM Contacting service... 2/6/2013 - 3:52 PM Connecting... 2/6/2013 - 3:52 PM OpenVPN 2.3.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Jan 8 2013 2/6/2013 - 3:52 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 2/6/2013 - 3:52 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 2/6/2013 - 3:52 PM Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 2/6/2013 - 3:52 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:52 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:53 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:54 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:55 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:56 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:57 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:58 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 3:59 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:00 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:01 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:02 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:03 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:04 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:05 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:06 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:07 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:08 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:09 PM TCP: connect to [AF_INET]127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 2/6/2013 - 4:10 PM Disconnecting... 2/6/2013 - 4:10 PM Disconnected. 2/6/2013 - 4:10 PM Login... 2/6/2013 - 4:10 PM Login success. Quote Share this post Link to post
Staff 10423 Posted ... Hello! The problem is caused by your proxy, either it is not running, refusing connections or not listening to port 9050. Please make sure that your proxy is properly configured and that the proxy type (http or socks) matches the proxy type you have chosen in the client settings. If you don't have a proxy (i.e. you don't want to connect over OpenVPN over a proxy), please set back to default (Proxy-->Type: "None") the Proxy combo box in the Air client "Preferences" window (right-click on the dock icon and select "Preferences"). Kind regards Quote Share this post Link to post
Zxurian 3 Posted ... thank you. I was expiermenting with airvpn over tor and forgot to set it back. Quote Share this post Link to post
