auzaar
IP address problem
I connected using Air VPN client and I got IP address 76.103.103.3 , shouldn't it be in 10.4... range ?
I use that range to set comodo firewall rules.
When you connect to a AirVPN server your IP shown to the internet will be the IP address shown on the AirVPN client (above the country name). Alternatively whilst connected click https://airvpn.org/details/ to see your current IP (Exit-IP). You can verify this with any "What is my IP" website on the net.
10.4.0.0 - 10.9.255.255 is the internal IP range for the VPN's TAP network adapter I believe. This is similar to the internal IP range of your router/modem usually 192.168.X.X. It's internal meaning not displayed to the outside world.
Make sure to have read through the FAQ and set up the Comodo Firewall rules accordingly to prevent leaking of your real IP address and DNS: https://airvpn.org/index.php?option=com_kunena&func=view&catid=3&id=3405&Itemid=142
Next time you create a post, try to be more descriptive.
