Not connected, Your IP: 18.191.240.243
emilysplace
Keeps disconnecting after establishing connection
Hi Guys,
For some reason i can connect but after 10 seconds or so it disconnects, then repeats
I'm a noob at this.
E
2013-02-06 20:33:20 *Tunnelblick: OS X 10.8.2; Tunnelblick 3.2.8 (build 2891.3099)
2013-02-06 20:33:21 *Tunnelblick: Attempting connection with AirVPN SG Sagittarii - UDP 443; Set nameserver = 1; monitoring connection
2013-02-06 20:33:21 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ SG\ Sagittarii\ -\ UDP\ 443.ovpn 1337 1 0 0 0 49 -atDASNGWrdasngw
2013-02-06 20:33:21 *Tunnelblick: openvpnstart: /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Users/emily/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/emily/Library/Application Support/Tunnelblick/Configurations/AirVPN SG Sagittarii - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Semily-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN SG Sagittarii -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw --up-restart
2013-02-06 20:33:22 *Tunnelblick: openvpnstart message: Loading tun.kext
2013-02-06 20:33:22 *Tunnelblick: Established communication with OpenVPN
2013-02-06 20:33:22 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Aug 10 2012
2013-02-06 20:33:22 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2013-02-06 20:33:22 Need hold release from management interface, waiting...
2013-02-06 20:33:22 MANAGEMENT: Client connected from 127.0.0.1:1337
2013-02-06 20:33:22 MANAGEMENT: CMD 'pid'
2013-02-06 20:33:22 MANAGEMENT: CMD 'state on'
2013-02-06 20:33:22 MANAGEMENT: CMD 'state'
2013-02-06 20:33:22 MANAGEMENT: CMD 'hold release'
2013-02-06 20:33:22 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-02-06 20:33:22 WARNING: file 'user.key' is group or others accessible
2013-02-06 20:33:22 LZO compression initialized
2013-02-06 20:33:22 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-02-06 20:33:22 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-02-06 20:33:22 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-02-06 20:33:22 Local Options hash (VER=V4): '22188c5b'
2013-02-06 20:33:22 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-02-06 20:33:22 UDPv4 link local: [undef]
2013-02-06 20:33:22 UDPv4 link remote: 119.81.1.122:443
2013-02-06 20:33:22 MANAGEMENT: >STATE:1360143202,WAIT,,,
2013-02-06 20:33:23 MANAGEMENT: >STATE:1360143203,AUTH,,,
2013-02-06 20:33:23 TLS: Initial packet from 119.81.1.122:443, sid=285ea20f 4528c96c
2013-02-06 20:33:25 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-02-06 20:33:25 VERIFY OK: nsCertType=SERVER
2013-02-06 20:33:25 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-02-06 20:33:31 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-02-06 20:33:31 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-02-06 20:33:31 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-02-06 20:33:31 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-02-06 20:33:31 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-02-06 20:33:31 [server] Peer Connection Initiated with 119.81.1.122:443
2013-02-06 20:33:32 MANAGEMENT: >STATE:1360143212,GET_CONFIG,,,
2013-02-06 20:33:33 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-02-06 20:33:38 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-02-06 20:33:39 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.10.86 10.4.10.85'
2013-02-06 20:33:39 OPTIONS IMPORT: timers and/or timeouts modified
2013-02-06 20:33:39 OPTIONS IMPORT: LZO parms modified
2013-02-06 20:33:39 OPTIONS IMPORT: --ifconfig/up options modified
2013-02-06 20:33:39 OPTIONS IMPORT: route options modified
2013-02-06 20:33:39 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-02-06 20:33:39 ROUTE default_gateway=10.0.0.1
2013-02-06 20:33:39 TUN/TAP device /dev/tun0 opened
2013-02-06 20:33:39 MANAGEMENT: >STATE:1360143219,ASSIGN_IP,,10.4.10.86,
2013-02-06 20:33:39 /sbin/ifconfig tun0 delete
ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
2013-02-06 20:33:39 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-02-06 20:33:39 /sbin/ifconfig tun0 10.4.10.86 10.4.10.85 mtu 1500 netmask 255.255.255.255 up
2013-02-06 20:33:39 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.10.86 10.4.10.85 init
No such key
2013-02-06 20:33:42 *Tunnelblick: Flushed the DNS cache
2013-02-06 20:33:42 /sbin/route add -net 119.81.1.122 10.0.0.1 255.255.255.255
add net 119.81.1.122: gateway 10.0.0.1
2013-02-06 20:33:42 /sbin/route add -net 0.0.0.0 10.4.10.85 128.0.0.0
add net 0.0.0.0: gateway 10.4.10.85
2013-02-06 20:33:42 /sbin/route add -net 128.0.0.0 10.4.10.85 128.0.0.0
add net 128.0.0.0: gateway 10.4.10.85
2013-02-06 20:33:42 MANAGEMENT: >STATE:1360143222,ADD_ROUTES,,,
2013-02-06 20:33:42 /sbin/route add -net 10.4.0.1 10.4.10.85 255.255.255.255
add net 10.4.0.1: gateway 10.4.10.85
2013-02-06 20:33:42 Initialization Sequence Completed
2013-02-06 20:33:42 MANAGEMENT: >STATE:1360143222,CONNECTED,SUCCESS,10.4.10.86,119.81.1.122
2013-02-06 20:33:42 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and WINS server(s) [ ] and using default domain name [ openvpn ]
2013-02-06 20:33:42 *Tunnelblick client.up.tunnelblick.sh: Up to two 'No such key' warnings are normal and may be ignored
2013-02-06 20:33:42 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and WINS configurations for later use
2013-02-06 20:33:42 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with process-network-changes
2013-02-06 20:33:54 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.10.86 10.4.10.85'
2013-02-06 20:33:55 Replay-window backtrack occurred [1]
2013-02-06 20:34:18 *Tunnelblick process-network-changes: SearchDomains changed from
* to
* <array> {
* 0 : openvpn
* pre-VPN was
2013-02-06 20:34:18 *Tunnelblick process-network-changes: SearchDomains changed; sending USR1 to OpenVPN (process ID 79646) to restart the connection.
2013-02-06 20:34:19 event_wait : Interrupted system call (code=4)
2013-02-06 20:34:19 TCP/UDP: Closing socket
2013-02-06 20:34:19 /sbin/route delete -net 10.4.0.1 10.4.10.85 255.255.255.255
delete net 10.4.0.1: gateway 10.4.10.85
2013-02-06 20:34:19 /sbin/route delete -net 119.81.1.122 10.0.0.1 255.255.255.255
delete net 119.81.1.122: gateway 10.0.0.1
2013-02-06 20:34:19 /sbin/route delete -net 0.0.0.0 10.4.10.85 128.0.0.0
delete net 0.0.0.0: gateway 10.4.10.85
2013-02-06 20:34:19 /sbin/route delete -net 128.0.0.0 10.4.10.85 128.0.0.0
delete net 128.0.0.0: gateway 10.4.10.85
2013-02-06 20:34:19 Closing TUN/TAP interface
2013-02-06 20:34:19 /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atDASNGWrdasngw tun0 1500 1558 10.4.10.86 10.4.10.85 init
2013-02-06 20:34:19 *Tunnelblick client.down.tunnelblick.sh: Cancelled monitoring of system configuration changes
2013-02-06 20:34:19 *Tunnelblick client.down.tunnelblick.sh: Restored the DNS and WINS configurations
2013-02-06 20:34:19 SIGUSR1[hard,] received, process restarting
2013-02-06 20:34:19 MANAGEMENT: >STATE:1360143259,RECONNECTING,SIGUSR1,,
2013-02-06 20:34:19 MANAGEMENT: CMD 'hold release'
2013-02-06 20:34:19 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-02-06 20:34:19 WARNING: file 'user.key' is group or others accessible
2013-02-06 20:34:19 LZO compression initialized
2013-02-06 20:34:19 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-02-06 20:34:19 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-02-06 20:34:19 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-02-06 20:34:19 Local Options hash (VER=V4): '22188c5b'
2013-02-06 20:34:19 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-02-06 20:34:19 UDPv4 link local: [undef]
2013-02-06 20:34:19 UDPv4 link remote: 119.81.1.122:443
2013-02-06 20:34:19 MANAGEMENT: >STATE:1360143259,WAIT,,,
2013-02-06 20:34:19 MANAGEMENT: >STATE:1360143259,AUTH,,,
2013-02-06 20:34:19 TLS: Initial packet from 119.81.1.122:443, sid=9e7b0d42 77585e21
2013-02-06 20:34:20 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-02-06 20:34:20 VERIFY OK: nsCertType=SERVER
2013-02-06 20:34:20 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-02-06 20:34:22 *Tunnelblick: Disconnecting; user cancelled
2013-02-06 20:34:22 event_wait : Interrupted system call (code=4)
2013-02-06 20:34:22 SIGTERM received, sending exit notification to peer
2013-02-06 20:34:24 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-02-06 20:34:24 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-02-06 20:34:24 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-02-06 20:34:24 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-02-06 20:34:24 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-02-06 20:34:24 [server] Peer Connection Initiated with 119.81.1.122:443
2013-02-06 20:34:24 MANAGEMENT: Client disconnected
2013-02-06 20:34:25 *Tunnelblick: Flushed the DNS cache
2013-02-06 20:34:25 MANAGEMENT: >STATE:1360143265,GET_CONFIG,,,
2013-02-06 20:34:27 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-02-06 20:34:27 TCP/UDP: Closing socket
2013-02-06 20:34:27 SIGTERM[soft,exit-with-notification] received, process exiting
2013-02-06 20:34:27 MANAGEMENT: >STATE:1360143267,EXITING,exit-with-notification,,
Hi Guys,
For some reason i can connect but after 10 seconds or so it disconnects, then repeats :(
I'm a noob at this.
E
Don't worry, it's a problem easily fixable. It is caused by the fact that Tunneblick 3.2.8 is not compatible with Mac OS X 10.8.x.
Please upgrade to Tunnelblick 3.3beta21b:
http://code.google.com/p/tunnelblick/wiki/DownloadsEntry?tm=2
Thanks so much for your reply, i installed the new software and it now establishes a connection but again disconnects immediately. I'm wondering if i have a different issue aswell.
2013-02-10 19:05:03 *Tunnelblick: OS X 10.8.2; Tunnelblick 3.3beta21b (build 3114.3185)
2013-02-10 19:05:03 *Tunnelblick: Attempting connection with AirVPN SG Sagittarii - UDP 443; Set nameserver = 1; monitoring connection
2013-02-10 19:05:03 *Tunnelblick: /Applications/Tunnelblick.app/Contents/Resources/openvpnstart start AirVPN\ SG\ Sagittarii\ -\ UDP\ 443.ovpn 1337 1 0 0 0 49 -atADGNWradsgnw
2013-02-10 19:05:03 *Tunnelblick: openvpnstart starting OpenVPN:
* /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.3-alpha1/openvpn --cd /Users/emily/Library/Application Support/Tunnelblick/Configurations --daemon --management 127.0.0.1 1337 --config /Users/emily/Library/Application Support/Tunnelblick/Configurations/AirVPN SG Sagittarii - UDP 443.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SUsers-Semily-SLibrary-SApplication Support-STunnelblick-SConfigurations-SAirVPN SG Sagittarii -- UDP 443.ovpn.1_0_0_0_49.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -atADGNWradsgnw --up-restart --route-pre-down /Applications/Tunnelblick.app/Contents/Resources/client.route-pre-down.tunnelblick.sh -m -w -d -atADGNWradsgnw
2013-02-10 19:05:04 *Tunnelblick: openvpnstart message: Loading tun.kext
2013-02-10 19:05:04 OpenVPN 2.3-alpha1 i386-apple-darwin10.8.0 [sSL (OpenSSL)] [LZO2] [eurephia] [MH] [PF_INET6] [iPv6 payload 20110522-1 (2.2.0)] built on Oct 27 2012
2013-02-10 19:05:04 MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:1337
2013-02-10 19:05:04 Need hold release from management interface, waiting...
2013-02-10 19:05:05 MANAGEMENT: Client connected from [AF_INET]127.0.0.1:1337
OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
--cd
--daemon
--management
127.0.0.1
1337
--config
--log
--management-hold
--script-security
2
--up
--down
--up-restart
--route-pre-down
2013-02-10 19:05:11 *Tunnelblick: Established communication with OpenVPN
2013-02-10 19:05:11 MANAGEMENT: CMD 'pid'
2013-02-10 19:05:11 MANAGEMENT: CMD 'state on'
2013-02-10 19:05:11 MANAGEMENT: CMD 'state'
2013-02-10 19:05:11 MANAGEMENT: CMD 'bytecount 1'
2013-02-10 19:05:11 MANAGEMENT: CMD 'hold release'
2013-02-10 19:05:11 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-02-10 19:05:11 WARNING: file 'user.key' is group or others accessible
2013-02-10 19:05:11 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-02-10 19:05:11 UDPv4 link local: [undef]
2013-02-10 19:05:11 UDPv4 link remote: [AF_INET]119.81.1.122:443
2013-02-10 19:05:11 MANAGEMENT: >STATE:1360483511,WAIT,,,
2013-02-10 19:05:11 MANAGEMENT: >STATE:1360483511,AUTH,,,
2013-02-10 19:05:11 TLS: Initial packet from [AF_INET]119.81.1.122:443, sid=5268e224 a1d6a303
2013-02-10 19:05:13 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
2013-02-10 19:05:13 VERIFY OK: nsCertType=SERVER
2013-02-10 19:05:13 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
2013-02-10 19:05:17 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-02-10 19:05:17 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-02-10 19:05:17 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-02-10 19:05:17 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-02-10 19:05:17 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-02-10 19:05:17 [server] Peer Connection Initiated with [AF_INET]119.81.1.122:443
2013-02-10 19:05:18 MANAGEMENT: >STATE:1360483518,GET_CONFIG,,,
2013-02-10 19:05:19 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-02-10 19:05:25 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-02-10 19:05:25 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.10.86 10.4.10.85'
2013-02-10 19:05:25 OPTIONS IMPORT: timers and/or timeouts modified
2013-02-10 19:05:25 OPTIONS IMPORT: LZO parms modified
2013-02-10 19:05:25 OPTIONS IMPORT: --ifconfig/up options modified
2013-02-10 19:05:25 OPTIONS IMPORT: route options modified
2013-02-10 19:05:25 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
2013-02-10 19:05:25 ROUTE_GATEWAY 10.0.0.1/255.255.255.0 IFACE=en1 HWADDR=00:25:00:41:f7:7b
2013-02-10 19:05:25 TUN/TAP device /dev/tun0 opened
2013-02-10 19:05:25 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
2013-02-10 19:05:25 MANAGEMENT: >STATE:1360483525,ASSIGN_IP,,10.4.10.86,
2013-02-10 19:05:25 /sbin/ifconfig tun0 delete
2013-02-10 19:05:25 NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
2013-02-10 19:05:25 /sbin/ifconfig tun0 10.4.10.86 10.4.10.85 mtu 1500 netmask 255.255.255.255 up
2013-02-10 19:05:25 /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -atADGNWradsgnw tun0 1500 1558 10.4.10.86 10.4.10.85 init
net.tunnelblick.openvpn.leasewatch: Already loaded
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: Retrieved name server(s) [ 10.4.0.1 ] and SMB server(s) [ ] and using default domain name [ openvpn ]
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 208.67.222.222 208.67.220.220 } }
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_CONFIG = No such key
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_CONFIG = <dictionary> { ServerAddresses : <array> { 208.67.222.222 208.67.220.220 } }
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_CONFIG = No such key
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_DNS_DN = openvpn; DYN_DNS_SA = 10.4.0.1; DYN_DNS_SD =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: DYN_SMB_NN = ; DYN_SMB_WG = ; DYN_SMB_WA =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_DNS_DN = ; MAN_DNS_SA = 208.67.222.222 208.67.220.220; MAN_DNS_SD =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: MAN_SMB_NN = ; MAN_SMB_WG = ; MAN_SMB_WA =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_DNS_DN = ; CUR_DNS_SA = 208.67.222.222 208.67.220.220; CUR_DNS_SD =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: CUR_SMB_NN = ; CUR_SMB_WG = ; CUR_SMB_WA =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: ServerAddresses '10.4.0.1' ignored because ServerAddresses was set manually
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: Setting search domains to 'openvpn' because running under OS X 10.6 or higher and the search domains were not set manually and 'Prepend domain name to search domains' was not selected
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_DNS_DN = openvpn; FIN_DNS_SA = 208.67.222.222 208.67.220.220; FIN_DNS_SD = openvpn
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: FIN_SMB_NN = ; FIN_SMB_WG = ; FIN_SMB_WA =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: OS X 10.8 or higher, so will modify DNS settings using Setup: in addition to State:
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_DNS = ; SKP_DNS_SA = ; SKP_DNS_SD = ; SKP_DNS_DN =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SETUP_DNS =
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: SKP_SMB = #; SKP_SMB_NN = #; SKP_SMB_WG = #; SKP_SMB_WA = #
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configuration changes:
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: ServerAddresses 208.67.222.222 208.67.220.220
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: SearchDomains openvpn
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD State: DomainName openvpn
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: ServerAddresses 208.67.222.222 208.67.220.220
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: SearchDomains openvpn
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ADD Setup: DomainName openvpn
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: NetBIOSName
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: Workgroup
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: ##ADD State: WINSAddresses
2013-02-10 19:05:27 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Pause for configuration changes to be propagated to State:/Network/Global/DNS and .../SMB
2013-02-10 19:05:29 /sbin/route add -net 119.81.1.122 10.0.0.1 255.255.255.255
2013-02-10 19:05:29 /sbin/route add -net 0.0.0.0 10.4.10.85 128.0.0.0
2013-02-10 19:05:29 /sbin/route add -net 128.0.0.0 10.4.10.85 128.0.0.0
2013-02-10 19:05:29 MANAGEMENT: >STATE:1360483529,ADD_ROUTES,,,
2013-02-10 19:05:29 /sbin/route add -net 10.4.0.1 10.4.10.85 255.255.255.255
2013-02-10 19:05:29 Initialization Sequence Completed
2013-02-10 19:05:29 MANAGEMENT: >STATE:1360483529,CONNECTED,SUCCESS,10.4.10.86,119.81.1.122
2013-02-10 19:05:29 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.10.86 10.4.10.85'
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG:
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Configurations as read back after changes:
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 208.67.222.222 208.67.220.220 } }
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/.../SMB = No such key
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 208.67.222.222 208.67.220.220 } }
2013-02-10 19:05:29 *Tunnelblick: Flushed the DNS cache
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Setup:/.../SMB = No such key
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 208.67.222.222 208.67.220.220 } }
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/Global/SMB = No such key
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: Expected by process-network-changes:
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/DNS = <dictionary> { DomainName : openvpn SearchDomains : <array> { openvpn } ServerAddresses : <array> { 208.67.222.222 208.67.220.220 } }
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: DEBUG: State:/Network/OpenVPN/SMB = <dictionary> { TunnelblickNoSuchKey : true }
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: Saved the DNS and SMB configurations for later use
2013-02-10 19:05:29 *Tunnelblick client.up.tunnelblick.sh: Set up to monitor system configuration with leasewatch
2013-02-10 19:05:30 *Tunnelblick: Flushed the DNS cache
2013-02-10 19:05:35 *Tunnelblick leasewatch: A system configuration change was ignored because it was not relevant
Just to determine if it's a problem with outbound port 443 UDP (in your ISP infrastructure or in your system) can you please try a connection toward port 80 TCP and 53 UDP and check whether the connection is stable or not?
