Anon123 0 Posted ... I set utorrent to the same port # randomly generated under the Member Area for UDP and TCP. The speed will get up to 600+ kBs, then drop down to 2.8 or lower kBs within 15 seconds time. I picked a AirVPN server that was 13% and selected port 80 on the mode. I followed your p2p directions. My utorrent has Protocol Encryption enabled for outgoing. Enable UnPn port mapping, Enable NAT-PMP port forwarding, Add windows firewall exception are all checked. Randomize port is not checked. Seems to be very slow. How do I fix? Quote Share this post Link to post
Staff 9761 Posted ... I set utorrent to the same port # randomly generated under the Member Area for UDP and TCP. The speed will get up to 600+ kBs, then drop down to 2.8 or lower kBs within 15 seconds time. I picked a AirVPN server that was 13% and selected port 80 on the mode. I followed your p2p directions.My utorrent has Protocol Encryption enabled for outgoing. Enable UnPn port mapping, Enable NAT-PMP port forwarding, Add windows firewall exception are all checked. Randomize port is not checked.Seems to be very slow. How do I fix?Hello!Please try VPN connections to port 53 UDP and port 53 TCP, they might fix the problem.Kind regards Quote Share this post Link to post
