Crowgasm 2 Posted ... Hi folks, I'm new to this and having problems. I managed to connect last week for a while but had awfully slow speeds. On retrying last night, I'm completely unable to connect. I can log in with the Air VPN application without any issue, so long as I select 'Socks' as the Proxy Type in preferences. I can then select a server in my region but it cycles indefinitely when trying to connect. No luck all night last night. If I select HTTP in Proxy Type then it reports 'Unable to connect to the remote server'. The Host and Port entries are left at default. I've made no changes to my router. No ports forwarded, etc. I'm using a TP Link TL-R860 router. I've tried disabling my AV and Firewall which I'm obviously not keen to do. No change. Using Windows 7 64x. I've posted a log below. Any help much appreciated. ----------------------------------------- 12/17/2012 - 11:41 PM AirVPN client version: 1.7 12/17/2012 - 11:41 PM Reading options from C:\Users\Steve\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 12/17/2012 - 11:41 PM OpenVPN bundle version: OpenVPN 2.2.2 12/17/2012 - 11:41 PM OpenVPN current version: OpenVPN 2.2.2 12/17/2012 - 11:41 PM Ready. 12/17/2012 - 11:41 PM Login... 12/17/2012 - 11:41 PM Login success. 12/17/2012 - 11:41 PM Contacting service... 12/17/2012 - 11:41 PM Connecting... 12/17/2012 - 11:41 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 12/17/2012 - 11:41 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 12/17/2012 - 11:41 PM LZO compression initialized 12/17/2012 - 11:41 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 12/17/2012 - 11:41 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 12/17/2012 - 11:41 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 12/17/2012 - 11:41 PM Local Options hash (VER=V4): '22188c5b' 12/17/2012 - 11:41 PM Expected Remote Options hash (VER=V4): 'a8f55717' 12/17/2012 - 11:41 PM Attempting to establish TCP connection with 127.0.0.1:9050 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:41 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:42 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:43 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:43 PM TCP: connect to 127.0.0.1:9050 failed, will try again in 5 seconds: Connection refused (WSAECONNREFUSED) 12/17/2012 - 11:43 PM Disconnecting... 12/17/2012 - 11:43 PM Disconnected. Quote Share this post Link to post
Staff 9751 Posted ... Hello! Your proxy is not responding or refusing connections on port 9050. Please make sure that your proxy is running AND listening to port 9050. What proxy are you using? Kind regards Quote Share this post Link to post
Crowgasm 2 Posted ... Hello there, thanks for the quick reply. If you mean what info is in the Air VPN Settings box when I right click the icon in the system tray (?) then it shows the following: Proxy Type: Socks Host: 127.0.0.1 Port: 9050 If that's now what you're asking then let me know how to find it. Quote Share this post Link to post
Staff 9751 Posted ... Hello! You can activate that option if you wish to connect over OpenVPN over a proxy. If you don't have a proxy, do not activate it, otherwise OpenVPN will try a connection toward a proxy that simply does not exist. Usually, you use a connection over Air over a proxy if you want to hide to our servers your real IP address even while you are connected to the VPN server(s), or if your ISP disrupts OpenVPN connections. A significant example: https://airvpn.org/tor Kind regards Quote Share this post Link to post
Crowgasm 2 Posted ... I see, I think. If I open up OpenVPN's GUI tool, it's set to 'Use OpenVPN Config-file Settings' and the HTTP Proxy and SOCKS Proxy fields are ghosted out. What am I missing? Should I set Proxy Type to Socks or HTTP or None? Should I edit the corresponding Host and/or Port fields? If so, how do I find what to use there? I'm sorry - as I say, I'm new to using this tool. Quote Share this post Link to post
Staff 9751 Posted ... I see, I think.If I open up OpenVPN's GUI tool, it's set to 'Use OpenVPN Config-file Settings' and the HTTP Proxy and SOCKS Proxy fields are ghosted out. What am I missing? Should I set Proxy Type to Socks or HTTP or None? Should I edit the corresponding Host and/or Port fields? If so, how do I find what to use there? I'm sorry - as I say, I'm new to using this tool.Hello!If you don't have a proxy, please do not activate that option in the Air client.If you use the OpenVPN GUI, or OpenVPN directly, generate the configuration(s) you wish with our configuration generator (menu "Member Area"-->"Access without our client"). As above, do not tell the configuration generator the you use a proxy if you don't have one.Usage of proxies implies a severe performance degradation.Kind regards Quote Share this post Link to post
Crowgasm 2 Posted ... I believe I have it working. I set the OpenVPN Proxy Settings tool to 'Use OpenVPN Config-file settings' (as it was, originally) and then I set the Proxy type in the Air VPN tool to None. It then logged in as usual and also managed to connect to a server, albeit after 30 seconds. The speed test (here on airvpn.org) shows a decent speed and the previously red Not Connected node on this site now shows green with 'Connected' and an IP clearly not my own/usual/geographic location. Should I assume all is working well? If so - many thanks for your speedy assistance! Quote Share this post Link to post
Staff 9751 Posted ... I believe I have it working. I set the OpenVPN Proxy Settings tool to 'Use OpenVPN Config-file settings' (as it was, originally) and then I set the Proxy type in the Air VPN tool to None. It then logged in as usual and also managed to connect to a server, albeit after 30 seconds. The speed test (here on airvpn.org) shows a decent speed and the previously red Not Connected node on this site now shows green with 'Connected' and an IP clearly not my own/usual/geographic location. Should I assume all is working well? If so - many thanks for your speedy assistance!Hello!Yes, it's just fine. Also, 30 seconds for an OpenVPN client to connect to an OpenVPN server with gateway and routing tables pushes are totally normal.Kind regards Quote Share this post Link to post
Crowgasm 2 Posted ... Great - thanks. Your support here is fantastic, btw. Quote Share this post Link to post
