Not connected, Your IP: 3.17.28.48
ssamo
OpenVPN problem
I already have OpenVPN and just downloaded the certificates package and copied these certificate files to the /config directory. But after running the OpenVPN client, the tray icon didn't come up, instead this message " OpenVPN GNI is already running" and I can't go ahead and get OpenVPN started. What can I do to solve this problem?
As you said,just turning off the and already running and now it works ok. I appreciate a lot. Thanks
