chiwou
Port Forwarding and DD-WRT
HI! I'm new to AirVPN and VPN generally, I managed with help from the Tut to get the OpenVPN running on my DD-WRT router after I downgraded to the old stable release.
But now I got a small problem with my Torrent client.
I created a port in the member area and changed the port in my Torrent client, but do I need to open the port on my router, because now I got this error message if I check the port:
"Not reachable on server IP over the external port xxxxx, tcp protocol. Error : 111 - Connection refused"
and my Client says too that the port is closed...
Thanks and take care
Hi, im trying to setup the exact same thing and ive been banging my head all week trying to get the forwards working to no avail. I assume you tinkered with the firewall script using IPTABLES? Would you be so kind to paste your firewall script so I can see where I might be going wrong. This is mine so far:
iptables -I FORWARD -i br0 -o tun0 -j ACCEPT iptables -I FORWARD -i tun0 -o br0 -j ACCEPT iptables -I INPUT -i tun0 -j REJECT
iptables -t nat -A POSTROUTING -o tun0 -j MASQUERADE
iptables -t nat -I PREROUTING -i tun0 -p tcp --dport 53540 -j DNAT --to-destination 192.168.1.3:4080
iptables -t nat -I PREROUTING -i tun0 -p udp --dport 53540 -j DNAT --to-destination 192.168.1.3:4080
I've obviously created the necessary port forward on the airvpn page.
Regards
sorry but I'm currently not at home, but I think
you should remove the ports to your destination ips
