Scone 0 Posted ... This has been a problem since the latest client update. Connecting to TOR worked perfectly with the old client, but now the newest version wont connect. Here's my log from my last two attempts at connecting to TOR with the 1.7 client. 8/30/2012 - 3:31 PM AirVPN client version: 1.7 8/30/2012 - 3:31 PM Reading options from C:\Users\me\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml 8/30/2012 - 3:31 PM OpenVPN bundle version: OpenVPN 2.2.2 8/30/2012 - 3:31 PM OpenVPN current version: OpenVPN 2.2.2 8/30/2012 - 3:31 PM Ready. 8/30/2012 - 3:34 PM Login... 8/30/2012 - 3:34 PM Login success. 8/30/2012 - 3:34 PM Contacting service... 8/30/2012 - 3:34 PM Connecting... 8/30/2012 - 3:34 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 8/30/2012 - 3:34 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 8/30/2012 - 3:34 PM LZO compression initialized 8/30/2012 - 3:34 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 8/30/2012 - 3:34 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 8/30/2012 - 3:34 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 8/30/2012 - 3:34 PM Local Options hash (VER=V4): '22188c5b' 8/30/2012 - 3:34 PM Expected Remote Options hash (VER=V4): 'a8f55717' 8/30/2012 - 3:34 PM Attempting to establish TCP connection with 127.0.0.1:9050 8/30/2012 - 3:34 PM TCP connection established with 127.0.0.1:9050 8/30/2012 - 3:34 PM recv_socks_reply: Socks proxy returned bad reply 8/30/2012 - 3:34 PM TCP/UDP: Closing socket 8/30/2012 - 3:34 PM SIGTERM[soft,init_instance] received, process exiting 8/30/2012 - 3:34 PM Failed to start. 8/30/2012 - 3:34 PM Login... 8/30/2012 - 3:34 PM Login success. 8/30/2012 - 3:34 PM Contacting service... 8/30/2012 - 3:34 PM Connecting... 8/30/2012 - 3:34 PM OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 8/30/2012 - 3:34 PM NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 8/30/2012 - 3:34 PM LZO compression initialized 8/30/2012 - 3:34 PM Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 8/30/2012 - 3:34 PM Socket Buffers: R=[8192->8192] S=[8192->8192] 8/30/2012 - 3:34 PM Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 8/30/2012 - 3:34 PM Local Options hash (VER=V4): '22188c5b' 8/30/2012 - 3:34 PM Expected Remote Options hash (VER=V4): 'a8f55717' 8/30/2012 - 3:34 PM Attempting to establish TCP connection with 127.0.0.1:9050 8/30/2012 - 3:34 PM TCP connection established with 127.0.0.1:9050 8/30/2012 - 3:34 PM recv_socks_reply: Socks proxy returned bad reply 8/30/2012 - 3:34 PM TCP/UDP: Closing socket 8/30/2012 - 3:34 PM SIGTERM[soft,init_instance] received, process exiting 8/30/2012 - 3:34 PM Failed to start. Quote Share this post Link to post
Staff 9751 Posted ... Hello! We don't detect any problem. Can you please make sure that the proxy type you select (http or socks) matches the proxy type you're using for TOR? Kind regards Quote Share this post Link to post
MrConducter 11 Posted ... I came here to ask the same question. Just tried connecting for 30 minutes and every time it says "failed to start" and kicks me off. Worked fine awhile ago. I haven't changed anything. Quote Share this post Link to post
Staff 9751 Posted ... I came here to ask the same question. Just tried connecting for 30 minutes and every time it says "failed to start" and kicks me off. Worked fine awhile ago. I haven't changed anything.Hello!Can you please send us the logs?Kind regards Quote Share this post Link to post
lollos 0 Posted ... same problem here can't connect to tor 09/09/2012 - 10.05 AirVPN client version: 1,7 09/09/2012 - 10.05 Reading options from C:\Users\xxx\Downloads\air_windows\AirVPN.xml 09/09/2012 - 10.05 OpenVPN bundle version: OpenVPN 2.2.2 09/09/2012 - 10.05 OpenVPN current version: OpenVPN 2.2.2 09/09/2012 - 10.05 Ready. 09/09/2012 - 10.05 Login... 09/09/2012 - 10.05 Login success. 09/09/2012 - 10.05 Contacting service... 09/09/2012 - 10.05 Connecting... 09/09/2012 - 10.05 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 09/09/2012 - 10.05 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 09/09/2012 - 10.05 LZO compression initialized 09/09/2012 - 10.05 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 09/09/2012 - 10.05 Socket Buffers: R=[128000->128000] S=[49152->49152] 09/09/2012 - 10.05 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 09/09/2012 - 10.05 Local Options hash (VER=V4): '22188c5b' 09/09/2012 - 10.05 Expected Remote Options hash (VER=V4): 'a8f55717' 09/09/2012 - 10.05 Attempting to establish TCP connection with 127.0.0.1:9050 09/09/2012 - 10.05 TCP connection established with 127.0.0.1:9050 09/09/2012 - 10.05 recv_socks_reply: Socks proxy returned bad reply 09/09/2012 - 10.05 TCP/UDP: Closing socket 09/09/2012 - 10.05 SIGTERM[soft,init_instance] received, process exiting 09/09/2012 - 10.05 Failed to start. 09/09/2012 - 10.09 Login... 09/09/2012 - 10.09 Login success. 09/09/2012 - 10.09 Contacting service... 09/09/2012 - 10.09 Connecting... 09/09/2012 - 10.09 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 09/09/2012 - 10.09 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 09/09/2012 - 10.09 LZO compression initialized 09/09/2012 - 10.09 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 09/09/2012 - 10.09 Socket Buffers: R=[128000->128000] S=[49152->49152] 09/09/2012 - 10.09 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 09/09/2012 - 10.09 Local Options hash (VER=V4): '22188c5b' 09/09/2012 - 10.09 Expected Remote Options hash (VER=V4): 'a8f55717' 09/09/2012 - 10.09 Attempting to establish TCP connection with 127.0.0.1:9050 09/09/2012 - 10.09 TCP connection established with 127.0.0.1:9050 09/09/2012 - 10.09 recv_socks_reply: Socks proxy returned bad reply 09/09/2012 - 10.09 TCP/UDP: Closing socket 09/09/2012 - 10.09 SIGTERM[soft,init_instance] received, process exiting 09/09/2012 - 10.09 Failed to start. 09/09/2012 - 10.10 Login... 09/09/2012 - 10.10 Login success. 09/09/2012 - 10.10 Contacting service... 09/09/2012 - 10.10 Connecting... 09/09/2012 - 10.10 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011 09/09/2012 - 10.10 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables 09/09/2012 - 10.10 LZO compression initialized 09/09/2012 - 10.10 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:10 ] 09/09/2012 - 10.10 Socket Buffers: R=[128000->128000] S=[49152->49152] 09/09/2012 - 10.10 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:10 AF:3/1 ] 09/09/2012 - 10.10 Local Options hash (VER=V4): '22188c5b' 09/09/2012 - 10.10 Expected Remote Options hash (VER=V4): 'a8f55717' 09/09/2012 - 10.10 Attempting to establish TCP connection with 127.0.0.1:9050 09/09/2012 - 10.10 TCP connection established with 127.0.0.1:9050 09/09/2012 - 10.10 recv_socks_reply: Socks proxy returned bad reply 09/09/2012 - 10.10 TCP/UDP: Closing socket 09/09/2012 - 10.10 SIGTERM[soft,init_instance] received, process exiting 09/09/2012 - 10.10 Failed to start. Quote Share this post Link to post
lollos 0 Posted ... i don't know... now the service work. unistalled air-openair-tor and reinstalled all, not problem now, work fine , sorry Quote Share this post Link to post
Staff 9751 Posted ... i don't know... now the service work. unistalled air-openair-tor and reinstalled all, not problem now, work fine , sorryHello and thank you for the information!Please do not hesitate to send us the OpenVPN logs if the problem occurs again.Kind regards Quote Share this post Link to post
