Not connected, Your IP: 3.21.97.61
Shiver Me Whiskers
IP Camera, no port forwarding, How to share VPN connection?
I'll try to be short:
- Bought an IP camera that has a web interface
- The camera knows Fixed IP, PPPoE and a few other protocols, but NO VPN of any kind
- The only way to access it from outside is via port forwarding
- My ISP doesn't give any incoming ports, it's a pure IPv6 connection with IPv4 translation on THEIR side.
- Only router is a Cable Modem/Router provided by the ISP, which, as stated above, creates an IPv4 tunnel
On my Windows computers I broke through the lack of incoming connections by using AirVPN and the Forwarded Ports feature.
However, the camera cannot do that...
So:
How do I share my computer's AirVPN tunnel to the IP camera ?
Something like this:
Internet -> AirVPN server port -> My computer with Eddie -> Camera's IP + Port
Is it even possible ?
Thanks !
Resolved.
I used a 2nd network card in the PC.
Internet Connection Sharing done on the VPN towards the 2nd network
Port forwarded from AirVPN
Port forwarded inside ICS towards the camera's IP with a direct cable in the 2nd network card.
Works !
Checked with a friend in another country, he could see me ;-)
