chuckens 1 Posted ... Not sure if I am selecting the correct package for El Capitan 10.11.6. When I open "Eddie" it loads up in dock but after a few seconds the app goes grey. Take a look at the screen shot I can't enter in any details etc?? Help!! ;-) Quote Share this post Link to post
LZ1 662 Posted ... Hello! Which Eddie client is this? I'm not sure how it works on Mac, but if the Stable release doesn't work, you could try the Beta client. Instructions can be found in my signature . 1 chuckens reacted to this Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
chuckens 1 Posted ... https://gyazo.com/260de87177b99aa7e5c9c6e952132127 Not really sure!! Quote Share this post Link to post
LZ1 662 Posted ... If you've just downloaded it from: https://airvpn.org/macos/ Then as you can see, it's version 2.16.3. Under the nearby Other Versions link, you can download the experimental client if you wish. Quote Hide LZ1's signature Hide all signatures Hi there, are you new to AirVPN? Many of your questions are already answered in this guide. You may also read the Eddie Android FAQ. Moderators do not speak on behalf of AirVPN. Only the Official Staff account does. Please also do not run Tor Exit Servers behind AirVPN, thank you. Did you make a guide or how-to for something? Then contact me to get it listed in my new user guide's Guides Section, so that the community can find it more easily. Share this post Link to post
chuckens 1 Posted ... Ok it tried them all. Still the same issue. Be grand... I don't really use the MAC that much. Thanks for your help ;-) Quote Share this post Link to post
Staff 9751 Posted ... Hello! Maybe Eddie starts minimized: if you click the tray icon (the tiny icon with a cloud in a circle you should have on the right of your top Desktop bar after you have started Eddie) a contextual menu should appear which shows the item "Show Main Window". If so, select it and Eddie main window should appear. Kind regards Quote Share this post Link to post
chuckens 1 Posted ... Hello! Maybe Eddie starts minimized: if you click the tray icon (the tiny icon with a cloud in a circle you should have on the right of your top Desktop bar after you have started Eddie) a contextual menu should appear which shows the item "Show Main Window". If so, select it and Eddie main window should appear. Kind regardsYou the man.!!! I never even seen that menu. hah What a dope! Thanks working A1 now ;-) 1 Staff reacted to this Quote Share this post Link to post
