Not connected, Your IP: 3.128.199.88
DonTurco
Nexus 6P Eddie Does not Connect
I have mailed support 2 times with my logs and did not get a reply. I cannot connect with my Nexus 6P, which makes the services useless.
Eddie Log created on 23 Jan 2019 03:47:12 UTC
Eddie for Android 2.0.1 Version Code 14
Eddie Library 1.3.1 - 5 November 2018
Eddie Library API level 5
Architecture: arm64-v8a (Arm 64 bit)
Platform: Android
Manufacturer: Huawei
Model: Nexus 6P
Device: angler
Brand: google
Product: angler
Android API Level: 27
Android Version Release: 8.1.0
23 Jan 2019 03:44:44 UTC [info] Initializing eddie library
23 Jan 2019 03:44:44 UTC [info] Eddie Library 1.3.1 - 5 November 2018
23 Jan 2019 03:44:44 UTC [info] Eddie Library API level 5
23 Jan 2019 03:44:44 UTC [info] Architecture: arm64-v8a (Arm 64 bit)
23 Jan 2019 03:44:44 UTC [info] Platform: Android
23 Jan 2019 03:44:44 UTC [info] Manufacturer: Huawei
23 Jan 2019 03:44:44 UTC [info] Model: Nexus 6P
23 Jan 2019 03:44:44 UTC [info] Device: angler
23 Jan 2019 03:44:44 UTC [info] Brand: google
23 Jan 2019 03:44:44 UTC [info] Product: angler
23 Jan 2019 03:44:44 UTC [info] Android API Level: 27
23 Jan 2019 03:44:44 UTC [info] Android Version Release: 8.1.0
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN initialization succeeded
23 Jan 2019 03:44:44 UTC [info] Requesting user IP and country to AirVPN ipleak.net via secure connection
23 Jan 2019 03:44:44 UTC [info] Setting manifest to default instance
23 Jan 2019 03:44:44 UTC [info] AirVPN ipleak.net: User IP is 176.40.33.88
23 Jan 2019 03:44:44 UTC [info] AirVPN ipleak.net: User country is TR
23 Jan 2019 03:44:44 UTC [info] Requesting manifest document to AirVPN
23 Jan 2019 03:44:44 UTC [info] Network is connected to WIFI
23 Jan 2019 03:44:44 UTC [Debug] VPNService.networkStatusChanged(): action='SYSTEM_RESUME'
23 Jan 2019 03:44:44 UTC [info] Successfully received manifest document from AirVPN
23 Jan 2019 03:44:44 UTC [info] Setting manifest to the instance downloaded from AirVPN server
23 Jan 2019 03:44:44 UTC [info] Requesting user document to AirVPN
23 Jan 2019 03:44:44 UTC [info] Successfully received user document from AirVPN
23 Jan 2019 03:44:44 UTC [info] Setting user profile to the instance downloaded from AirVPN server
23 Jan 2019 03:44:44 UTC [info] Logged in to AirVPN as user DonTurco
23 Jan 2019 03:44:44 UTC [info] Trying to quick connect favorite AirVPN server Alamak at Bucharest, Romania - Protocol TCP, Port 443
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Successfully created a new OpenVPN client
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'tls_version_min' set to 'tls_1_0'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'protocol' set to ''
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'ipv6' set to ''
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'timeout' set to '0'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'tun_persist' set to 'true'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'compression_mode' set to 'yes'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'synchronous_dns_lookup' set to 'false'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'autologin_sessions' set to 'true'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'disable_client_cert' set to 'false'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'ssl_debug_level' set to '0'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'default_key_direction' set to '-1'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'force_aes_cbc_ciphersuites' set to 'false'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client: option 'tls_cert_profile' set to ''
23 Jan 2019 03:44:44 UTC [info] Starting VPN thread
23 Jan 2019 03:44:44 UTC [info] Eddie Library: starting openVPNClient
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Client::start(): Loading profile
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.protoOverride:
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.connTimeout: 0
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.compressionMode: yes
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.ipv6:
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.tlsVersionMinOverride: tls_1_0
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.tlsCertProfileOverride:
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.disableClientCert: false
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.proxyHost:
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.proxyPort:
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.proxyAllowCleartextAuth: false
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.defaultKeyDirection: -1
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.forceAesCbcCiphersuites: false
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.sslDebugLevel: 0
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.autologinSessions: true
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.tunPersist: true
23 Jan 2019 03:44:44 UTC [info] Eddie Library: config.synchronousDnsLookup: false
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Client::start(): Profile loaded. Connecting to server
23 Jan 2019 03:44:44 UTC [info] Eddie Library: connect_attach()
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onConnectAttach()
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Frame=512/2048/512 mssfix-ctrl=1250
23 Jan 2019 03:44:44 UTC [Debug] OpenVPN Event: type=4, name=RESOLVE, info=
23 Jan 2019 03:44:44 UTC [info] Eddie Library: connect_pre_run()
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onConnectPreRun()
23 Jan 2019 03:44:44 UTC [info] Eddie Library: connect_run()
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Contacting 91.207.102.165:443 via TCPv4
23 Jan 2019 03:44:44 UTC [Debug] OpenVPN Event: type=5, name=WAIT, info=
23 Jan 2019 03:44:44 UTC [info] Eddie Library: socket_protect(socket=60)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onSocketProtect(socket=60)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Connecting to [91.207.102.165]:443 (91.207.102.165) via TCPv4
23 Jan 2019 03:44:44 UTC [Debug] OpenVPN Event: type=7, name=CONNECTING, info=
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Tunnel Options:V4,dev-type tun,link-mtu 1604,tun-mtu 1500,proto TCPv4_CLIENT,comp-lzo,cipher AES-256-CBC,auth SHA512,keysize 256,key-method 2,tls-client
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Peer Info:
IV_GUI_VER=Eddie Library 1.3.1
IV_VER=3.2
IV_PLAT=android
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO=1
IV_LZO_SWAP=1
IV_LZ4=1
IV_LZ4v2=1
IV_COMP_STUB=1
IV_COMP_STUBv2=1
IV_AUTO_SESS=1
23 Jan 2019 03:44:44 UTC [info] Eddie Library: VERIFY OK : depth=1
cert. version     : 3
serial number     :
issuer name       : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
subject name      : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
issued  on        : 2014-04-11 10:15:45
expires on        : 2024-04-08 10:15:45
signed using      : RSA with SHA1
RSA key size      : 4096 bits
basic constraints : CA=true
23 Jan 2019 03:44:44 UTC [info] Eddie Library: VERIFY OK : depth=0
cert. version     : 3
serial number     : EE
subject name      : C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
issued  on        : 2016-03-10 08:45:31
expires on        : 2026-03-08 08:45:31
basic constraints : CA=false
cert. type        : SSL Server
key usage         : Digital Signature, Key Encipherment
ext key usage     : TLS Web Server Authentication
23 Jan 2019 03:44:44 UTC [info] Eddie Library: SSL Handshake: TLSv1.2/TLS-DHE-RSA-WITH-AES-256-GCM-SHA384
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Session is ACTIVE
23 Jan 2019 03:44:44 UTC [Debug] OpenVPN Event: type=8, name=GET_CONFIG, info=
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Sending PUSH_REQUEST to server...
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OPTIONS:
0 [comp-lzo] [no]
1 [redirect-gateway] [ipv6] [def1] [bypass-dhcp]
2 [dhcp-option] [DNS] [10.5.31.1]
3 [dhcp-option] [DNS6] [fde6:7a:7d20:11f::1]
4 [tun-ipv6]
5 [route-gateway] [10.5.31.1]
6 [topology] [subnet]
7 [ping] [10]
8 [ping-restart] [60]
9 [ifconfig-ipv6] [fde6:7a:7d20:11f::100f/64] [fde6:7a:7d20:11f::1]
10 [ifconfig] [10.5.31.17] [255.255.255.0]
11 [peer-id] [0]
12 [cipher] [AES-256-GCM]
23 Jan 2019 03:44:44 UTC [info] Eddie Library: PROTOCOL OPTIONS:
  cipher: AES-256-GCM
  digest: SHA512
  compress: LZO_STUB
  peer ID: 0
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_new()
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderNew()
23 Jan 2019 03:44:44 UTC [Debug] OpenVPN Event: type=9, name=ASSIGN_IP, info=
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_add_address(address=10.5.31.17, prefix_length=24, gateway=10.5.31.1, ipv6=false, net30=false)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderAddAddress(address=10.5.31.17, prefix_length=24, gateway=10.5.31.1, ipv6=false, net30=false)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_add_address(address=fde6:7a:7d20:11f::100f, prefix_length=64, gateway=fde6:7a:7d20:11f::1, ipv6=true, net30=false)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderAddAddress(address=fde6:7a:7d20:11f::100f, prefix_length=64, gateway=fde6:7a:7d20:11f::1, ipv6=true, net30=false)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_reroute_gw(ipv4=true, ipv6=true, flags=819)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuildeRerouteGW(ipv4=true, ipv6=true, flags=819)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_add_dns_server(address=10.5.31.1, ipv6=false)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderAddDNSServer(address=10.5.31.1, ipv6=false)
23 Jan 2019 03:44:44 UTC [Debug] VPNContext.doAddDNS(): Adding DNS server '10.5.31.1'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_add_dns_server(address=fde6:7a:7d20:11f::1, ipv6=true)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderAddDNSServer(address=fde6:7a:7d20:11f::1, ipv6=true)
23 Jan 2019 03:44:44 UTC [Debug] VPNContext.doAddDNS(): Adding DNS server 'fde6:7a:7d20:11f::1'
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_set_block_ipv6(block_ipv6=false)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderSetBlockIPV6(block_ipv6=false)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_set_remote_address(address=91.207.102.165, ipv6=false)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderSetRemoteAddress(address=91.207.102.165, ipv6=false)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_set_layer(layer=3)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderSetLayer(layer=3)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_set_session_name(name=91.207.102.165)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderSetSessionName(name=91.207.102.165)
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_establish()
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderEstablish()
23 Jan 2019 03:44:44 UTC [info] Eddie Library: TunPersist: saving tun context:
Session Name: 91.207.102.165
Layer: OSI_LAYER_3
Remote Address: 91.207.102.165
Tunnel Addresses:
  10.5.31.17/24 -> 10.5.31.1
  fde6:7a:7d20:11f::100f/64 -> fde6:7a:7d20:11f::1 [iPv6]
Reroute Gateway: IPv4=1 IPv6=1 flags=[ ENABLE REROUTE_GW DEF1 BYPASS_DHCP IPv4 IPv6 ]
Block IPv6: no
Add Routes:
Exclude Routes:
DNS Servers:
  10.5.31.1
Search Domains:
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Connected via tun
23 Jan 2019 03:44:44 UTC [info] Eddie Library: LZO init swap=0 asym=1
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Comp-stub init swap=0
23 Jan 2019 03:44:44 UTC [info] CONNECTED to VPN (AirVPN server Alamak - Bucharest, Romania)
Defined: 1
User:
Server Host: 91.207.102.165
Server Port: 443
Server Protocol: TCPv4
Server IP: 91.207.102.165
VPN IPv4: 10.5.31.17
VPN IPv6: fde6:7a:7d20:11f::100f
Gateway IPv4: 10.5.31.1
Gateway IPv6: fde6:7a:7d20:11f::1
Tunnel Name: tun
23 Jan 2019 03:44:44 UTC [Debug] EddieBroadcastReceiver.onReceive(action='android.intent.action.BOOT_COMPLETED')
23 Jan 2019 03:44:44 UTC [Debug] EddieBroadcastReceiver.tryRestoreLastProfile()
23 Jan 2019 03:44:44 UTC [Debug] EddieBroadcastReceiver.tryRestoreLastProfile(): Restoring last profile
23 Jan 2019 03:44:44 UTC [Debug] VPNService.onStartCommand(): Received start command
23 Jan 2019 03:44:44 UTC [Error] VPNService.onRevoke()
23 Jan 2019 03:44:44 UTC [info] Eddie Library: Stopping OpenVPN client
23 Jan 2019 03:44:44 UTC [info] Eddie Library: OpenVPN client stopped
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.clearContexts()
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.clearContext(): Disposing context
23 Jan 2019 03:44:44 UTC [info] Eddie Library: tun_builder_teardown(disconnect=true)
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onTunBuilderTeardown(disconnect=true)
23 Jan 2019 03:44:44 UTC [Warning] OpenVPN DISCONNECTED:
23 Jan 2019 03:44:44 UTC [Debug] OpenVPNTunnel.onConnectRun()
23 Jan 2019 03:44:44 UTC [info] VPN thread execution has completed
