Not connected, Your IP: 3.15.235.196
kah0922
Eddie For Android Quick Connect Does Not Fallback To Other Protocols
I have a network where UDP is completely blocked. When using Eddie for Android's Quick Connect, it hangs on trying UDP 443. Instead, Eddie throws a VPN lock error.
[Error:] OpenVPN3 KEEPALIVE_TIMEOUT: Eddie Library Session invalidated: KEEPALIVE_TIMEOUT
[Info]: VPN error detected. Locking VPN
Quick Connect is set to Automatic.
Connecting via sever select TCP works fine. Connecting via Default options TCP Quick Connect works fine.
Thank you very much for the report. Under investigation. Additional information which can help us remarkably:
  • brand, model and Android version of your device (included anyway in the Eddie log)
  • Eddie log (in the "Log" view you can share log in various ways by tapping the "Share" icon)
  • optionally, the logcat, if you know how to get it and you have time
Thank you very much for the log. We are considering the issue carefully and we wish to resolve it in 2.1 beta 1 already.
