seja@nada.email 1 Posted ... (edited) Hello eddie client gets hung up ipv4 and 6 where client keeps trying to connect and tries add up but never succesul using hotspot(1) . But when I switch hotspots to hotspot (2) I can get connected to internet no problem. Hotspot(1) is my primary and used to work. first log entry is from modem that fails and i allowed it to restart once then manually stopped by me. hotspot(1) ps hotspot(1) internet works with out using eddie client I 2019.01.17 21:53:55 - Session starting. I 2019.01.17 21:53:55 - Checking authorization ... ! 2019.01.17 21:53:56 - Connecting to Mensa (United States, Dallas, Texas) . 2019.01.17 21:53:56 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.01.17 21:53:56 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.01.17 21:53:56 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.01.17 21:53:56 - Connection to OpenVPN Management Interface . 2019.01.17 21:53:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.01.17 21:53:56 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 21:53:56 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 21:53:56 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 21:53:56 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 21:53:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.9:443 . 2019.01.17 21:53:56 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.01.17 21:53:56 - OpenVPN > UDP link local: (not bound) . 2019.01.17 21:53:56 - OpenVPN > UDP link remote: [AF_INET]199.249.230.9:443 . 2019.01.17 21:53:56 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.9:443, sid=a2f304dc 139a07bd . 2019.01.17 21:53:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.01.17 21:53:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.01.17 21:53:57 - OpenVPN > VERIFY KU OK . 2019.01.17 21:53:57 - OpenVPN > Validating certificate extended key usage . 2019.01.17 21:53:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.01.17 21:53:57 - OpenVPN > VERIFY EKU OK . 2019.01.17 21:53:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Mensa, emailAddress=info@airvpn.org . 2019.01.17 21:53:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.01.17 21:53:57 - OpenVPN > [Mensa] Peer Connection Initiated with [AF_INET]199.249.230.9:443 . 2019.01.17 21:53:58 - OpenVPN > SENT CONTROL [Mensa]: 'PUSH_REQUEST' (status=1) . 2019.01.17 21:53:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.22.2.1,dhcp-option DNS6 fde6:7a:7d20:1202::1,tun-ipv6,route-gateway 10.22.2.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1202::100f/64 fde6:7a:7d20:1202::1,ifconfig 10.22.2.17 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2019.01.17 21:53:58 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.01.17 21:53:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.01.17 21:53:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.01.17 21:53:58 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 21:53:58 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 21:53:58 - OpenVPN > interactive service msg_channel=0 . 2019.01.17 21:53:58 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=98:5f:d3:f0:5f:5b . 2019.01.17 21:53:58 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.01.17 21:53:58 - OpenVPN > GetBestInterfaceEx() returned if=2 . 2019.01.17 21:53:58 - OpenVPN > GDG6: II=2 DP=::/0 NH=:: . 2019.01.17 21:53:58 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2019.01.17 21:53:58 - OpenVPN > ROUTE6_GATEWAY :: ON_LINK I=2 . 2019.01.17 21:53:58 - OpenVPN > open_tun . 2019.01.17 21:53:59 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{9BD95422-1530-4E9F-B420-A66CA8AE4315}.tap . 2019.01.17 21:53:59 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.01.17 21:53:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.22.2.0/10.22.2.17/255.255.255.0 [sUCCEEDED] . 2019.01.17 21:53:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.22.2.17/255.255.255.0 on interface {9BD95422-1530-4E9F-B420-A66CA8AE4315} [DHCP-serv: 10.22.2.254, lease-time: 31536000] . 2019.01.17 21:53:59 - OpenVPN > Successful ARP Flush on interface [11] {9BD95422-1530-4E9F-B420-A66CA8AE4315} . 2019.01.17 21:53:59 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.01.17 21:54:00 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=11 fde6:7a:7d20:1202::100f store=active . 2019.01.17 21:54:01 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1202::1 validate=no . 2019.01.17 21:54:01 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.01.17 21:54:01 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1202::/64 -> fde6:7a:7d20:1202::100f metric 0) dev Ethernet 2 . 2019.01.17 21:54:01 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1202::/64 interface=11 fe80::8 store=active . 2019.01.17 21:54:01 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:54:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\route.exe ADD 199.249.230.9 MASK 255.255.255.255 192.168.1.1 . 2019.01.17 21:54:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 . 2019.01.17 21:54:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.22.2.1 . 2019.01.17 21:54:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 21:54:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.22.2.1 . 2019.01.17 21:54:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 21:54:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:54:07 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1202::1 metric -1) dev Ethernet 2 . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=11 fe80::8 store=active . 2019.01.17 21:54:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:54:07 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1202::1 metric -1) dev Ethernet 2 . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:54:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:54:07 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1202::1 metric -1) dev Ethernet 2 . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:54:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:54:07 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1202::1 metric -1) dev Ethernet 2 . 2019.01.17 21:54:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 21:54:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:54:07 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4 . 2019.01.17 21:54:07 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6 . 2019.01.17 21:54:07 - DNS leak protection with packet filtering enabled. . 2019.01.17 21:54:08 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.22.2.1) . 2019.01.17 21:54:08 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1202::1) . 2019.01.17 21:54:08 - Routes, added a new route, 199.249.230.7 for gateway 10.22.2.1 . 2019.01.17 21:54:08 - Routes, added a new route, 2620:7:6001:40b8:ceb4:2489:665e:d101 for gateway fde6:7a:7d20:1202::1 . 2019.01.17 21:54:08 - Flushing DNS I 2019.01.17 21:54:11 - Checking route IPv4 . 2019.01.17 21:54:31 - curl: (28) Operation timed out after 20015 milliseconds with 0 out of 0 bytes received . 2019.01.17 21:54:31 - Checking route (2° try) . 2019.01.17 21:54:52 - curl: (28) Operation timed out after 20016 milliseconds with 0 out of 0 bytes received . 2019.01.17 21:54:52 - Checking route (3° try) . 2019.01.17 21:55:14 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received E 2019.01.17 21:55:14 - Checking route IPv4 failed. . 2019.01.17 21:55:14 - OpenVPN > Initialization Sequence Completed ! 2019.01.17 21:55:14 - Disconnecting . 2019.01.17 21:55:14 - Routes, removed a route previously added, 199.249.230.7 for gateway 10.22.2.1 . 2019.01.17 21:55:15 - Routes, removed a route previously added, 2620:7:6001:40b8:ceb4:2489:665e:d101 for gateway fde6:7a:7d20:1202::1 . 2019.01.17 21:55:15 - Sending management termination signal . 2019.01.17 21:55:15 - Management - Send 'signal SIGTERM' . 2019.01.17 21:55:15 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.01.17 21:55:15 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.01.17 21:55:20 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.249.230.9 MASK 255.255.255.255 192.168.1.1 . 2019.01.17 21:55:20 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:55:20 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.22.2.1 . 2019.01.17 21:55:20 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:55:20 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.22.2.1 . 2019.01.17 21:55:20 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:55:20 - OpenVPN > delete_route_ipv6(::/3) . 2019.01.17 21:55:20 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=11 fe80::8 store=active . 2019.01.17 21:55:20 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:21 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.01.17 21:55:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:55:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:21 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.01.17 21:55:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:55:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:21 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.01.17 21:55:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 21:55:21 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:21 - OpenVPN > Closing TUN/TAP interface . 2019.01.17 21:55:21 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1202::/64) . 2019.01.17 21:55:21 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1202::/64 interface=11 fe80::8 store=active . 2019.01.17 21:55:21 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1202::100f store=active . 2019.01.17 21:55:21 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all . 2019.01.17 21:55:21 - OpenVPN > TAP: DHCP address released . 2019.01.17 21:55:21 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.01.17 21:55:21 - Connection terminated. . 2019.01.17 21:55:21 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 21:55:21 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 21:55:21 - DNS leak protection with packet filtering disabled. . 2019.01.17 21:55:21 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4 . 2019.01.17 21:55:21 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6 I 2019.01.17 21:55:25 - Checking authorization ... ! 2019.01.17 21:55:25 - Connecting to Vulpecula (United States, Dallas, Texas) . 2019.01.17 21:55:25 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.01.17 21:55:25 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.01.17 21:55:25 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.01.17 21:55:25 - Connection to OpenVPN Management Interface . 2019.01.17 21:55:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.01.17 21:55:25 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 21:55:25 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 21:55:25 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 21:55:25 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 21:55:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.4:443 . 2019.01.17 21:55:25 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.01.17 21:55:25 - OpenVPN > UDP link local: (not bound) . 2019.01.17 21:55:25 - OpenVPN > UDP link remote: [AF_INET]199.249.230.4:443 . 2019.01.17 21:55:25 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.01.17 21:55:25 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.4:443, sid=60f47b86 238ed717 . 2019.01.17 21:55:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.01.17 21:55:25 - OpenVPN > VERIFY KU OK . 2019.01.17 21:55:25 - OpenVPN > Validating certificate extended key usage . 2019.01.17 21:55:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.01.17 21:55:25 - OpenVPN > VERIFY EKU OK . 2019.01.17 21:55:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Vulpecula, emailAddress=info@airvpn.org . 2019.01.17 21:55:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.01.17 21:55:26 - OpenVPN > [Vulpecula] Peer Connection Initiated with [AF_INET]199.249.230.4:443 . 2019.01.17 21:55:27 - OpenVPN > SENT CONTROL [Vulpecula]: 'PUSH_REQUEST' (status=1) . 2019.01.17 21:55:30 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.98.1,dhcp-option DNS6 fde6:7a:7d20:1c62::1,tun-ipv6,route-gateway 10.32.98.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1c62::101a/64 fde6:7a:7d20:1c62::1,ifconfig 10.32.98.28 255.255.255.0,peer-id 0,cipher AES-256-GCM' . 2019.01.17 21:55:30 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.01.17 21:55:30 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.01.17 21:55:30 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.01.17 21:55:30 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 21:55:30 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 21:55:30 - OpenVPN > interactive service msg_channel=0 . 2019.01.17 21:55:30 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=98:5f:d3:f0:5f:5b . 2019.01.17 21:55:30 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.01.17 21:55:30 - OpenVPN > GetBestInterfaceEx() returned if=2 . 2019.01.17 21:55:30 - OpenVPN > GDG6: II=2 DP=::/0 NH=:: . 2019.01.17 21:55:30 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2019.01.17 21:55:30 - OpenVPN > ROUTE6_GATEWAY :: ON_LINK I=2 . 2019.01.17 21:55:30 - OpenVPN > open_tun . 2019.01.17 21:55:30 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{9BD95422-1530-4E9F-B420-A66CA8AE4315}.tap . 2019.01.17 21:55:30 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.01.17 21:55:30 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.32.98.0/10.32.98.28/255.255.255.0 [sUCCEEDED] . 2019.01.17 21:55:30 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.32.98.28/255.255.255.0 on interface {9BD95422-1530-4E9F-B420-A66CA8AE4315} [DHCP-serv: 10.32.98.254, lease-time: 31536000] . 2019.01.17 21:55:30 - OpenVPN > Successful ARP Flush on interface [11] {9BD95422-1530-4E9F-B420-A66CA8AE4315} . 2019.01.17 21:55:30 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.01.17 21:55:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=11 fde6:7a:7d20:1c62::101a store=active . 2019.01.17 21:55:32 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1c62::1 validate=no . 2019.01.17 21:55:32 - Detected an OpenVPN bug (On-Link route on VPN range), autofix. . 2019.01.17 21:55:33 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1c62::/64 -> fde6:7a:7d20:1c62::101a metric 0) dev Ethernet 2 . 2019.01.17 21:55:33 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1c62::/64 interface=11 fe80::8 store=active . 2019.01.17 21:55:33 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:37 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\route.exe ADD 199.249.230.4 MASK 255.255.255.255 192.168.1.1 . 2019.01.17 21:55:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 . 2019.01.17 21:55:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.32.98.1 . 2019.01.17 21:55:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 21:55:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.32.98.1 . 2019.01.17 21:55:37 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 21:55:37 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:55:37 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=11 fe80::8 store=active . 2019.01.17 21:55:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:37 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:55:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:37 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:55:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:37 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:55:37 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 21:55:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:55:37 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4 . 2019.01.17 21:55:37 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6 . 2019.01.17 21:55:37 - DNS leak protection with packet filtering enabled. . 2019.01.17 21:55:38 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.32.98.1) . 2019.01.17 21:55:38 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1c62::1) . 2019.01.17 21:55:38 - Routes, added a new route, 199.249.230.2 for gateway 10.32.98.1 . 2019.01.17 21:55:38 - Routes, added a new route, 2620:7:6001:cfa5:3f91:f92:f654:c7b9 for gateway fde6:7a:7d20:1c62::1 . 2019.01.17 21:55:38 - Flushing DNS I 2019.01.17 21:55:41 - Checking route IPv4 . 2019.01.17 21:56:01 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received . 2019.01.17 21:56:01 - Checking route (2° try) . 2019.01.17 21:56:23 - curl: (28) Operation timed out after 20016 milliseconds with 0 out of 0 bytes received . 2019.01.17 21:56:23 - Checking route (3° try) . 2019.01.17 21:56:45 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received E 2019.01.17 21:56:45 - Checking route IPv4 failed. . 2019.01.17 21:56:45 - OpenVPN > Initialization Sequence Completed ! 2019.01.17 21:56:45 - Disconnecting . 2019.01.17 21:56:45 - Routes, removed a route previously added, 199.249.230.2 for gateway 10.32.98.1 . 2019.01.17 21:56:45 - Routes, removed a route previously added, 2620:7:6001:cfa5:3f91:f92:f654:c7b9 for gateway fde6:7a:7d20:1c62::1 . 2019.01.17 21:56:45 - Sending management termination signal . 2019.01.17 21:56:45 - Management - Send 'signal SIGTERM' . 2019.01.17 21:56:45 - OpenVPN > MANAGEMENT: CMD '8350b0b1313fc28f8dc9d7ee714a4672556110c0d3044a18a4aead466cdf1258' . 2019.01.17 21:56:54 - Sending management termination signal . 2019.01.17 21:56:54 - Management - Send 'signal SIGTERM' . 2019.01.17 21:56:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.01.17 21:56:54 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.01.17 21:56:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.249.230.4 MASK 255.255.255.255 192.168.1.1 . 2019.01.17 21:56:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:56:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.32.98.1 . 2019.01.17 21:56:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:56:59 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.32.98.1 . 2019.01.17 21:56:59 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:56:59 - OpenVPN > delete_route_ipv6(::/3) . 2019.01.17 21:56:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=11 fe80::8 store=active . 2019.01.17 21:56:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:56:59 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.01.17 21:56:59 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:56:59 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:00 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.01.17 21:57:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:57:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:00 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.01.17 21:57:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 21:57:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:00 - OpenVPN > Closing TUN/TAP interface . 2019.01.17 21:57:00 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1c62::/64) . 2019.01.17 21:57:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1c62::/64 interface=11 fe80::8 store=active . 2019.01.17 21:57:00 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1c62::101a store=active . 2019.01.17 21:57:00 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all . 2019.01.17 21:57:00 - OpenVPN > TAP: DHCP address released . 2019.01.17 21:57:00 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.01.17 21:57:00 - Connection terminated. . 2019.01.17 21:57:01 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 21:57:01 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 21:57:01 - DNS leak protection with packet filtering disabled. . 2019.01.17 21:57:01 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4 . 2019.01.17 21:57:01 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6 I 2019.01.17 21:57:04 - Checking authorization ... ! 2019.01.17 21:57:07 - Connecting to Equuleus (United States, Dallas, Texas) . 2019.01.17 21:57:07 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.01.17 21:57:07 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.01.17 21:57:07 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.01.17 21:57:07 - Connection to OpenVPN Management Interface . 2019.01.17 21:57:07 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.01.17 21:57:07 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 21:57:07 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 21:57:07 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 21:57:07 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 21:57:07 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.39:443 . 2019.01.17 21:57:07 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.01.17 21:57:07 - OpenVPN > UDP link local: (not bound) . 2019.01.17 21:57:07 - OpenVPN > UDP link remote: [AF_INET]199.249.230.39:443 . 2019.01.17 21:57:08 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.01.17 21:57:08 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.39:443, sid=d73a9e47 fcb6adc6 . 2019.01.17 21:57:08 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.01.17 21:57:08 - OpenVPN > VERIFY KU OK . 2019.01.17 21:57:08 - OpenVPN > Validating certificate extended key usage . 2019.01.17 21:57:08 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.01.17 21:57:08 - OpenVPN > VERIFY EKU OK . 2019.01.17 21:57:08 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Equuleus, emailAddress=info@airvpn.org . 2019.01.17 21:57:08 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.01.17 21:57:08 - OpenVPN > [Equuleus] Peer Connection Initiated with [AF_INET]199.249.230.39:443 . 2019.01.17 21:57:09 - OpenVPN > SENT CONTROL [Equuleus]: 'PUSH_REQUEST' (status=1) . 2019.01.17 21:57:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.16.98.1,dhcp-option DNS6 fde6:7a:7d20:c62::1,tun-ipv6,route-gateway 10.16.98.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:c62::101d/64 fde6:7a:7d20:c62::1,ifconfig 10.16.98.31 255.255.255.0,peer-id 1,cipher AES-256-GCM' . 2019.01.17 21:57:12 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.01.17 21:57:12 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.01.17 21:57:12 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.01.17 21:57:12 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 21:57:12 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 21:57:12 - OpenVPN > interactive service msg_channel=0 . 2019.01.17 21:57:12 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=10 HWADDR=98:5f:d3:f0:5f:5b . 2019.01.17 21:57:12 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.01.17 21:57:12 - OpenVPN > GetBestInterfaceEx() returned if=2 . 2019.01.17 21:57:12 - OpenVPN > GDG6: II=2 DP=::/0 NH=:: . 2019.01.17 21:57:12 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2019.01.17 21:57:12 - OpenVPN > ROUTE6_GATEWAY :: ON_LINK I=2 . 2019.01.17 21:57:12 - OpenVPN > open_tun . 2019.01.17 21:57:12 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{9BD95422-1530-4E9F-B420-A66CA8AE4315}.tap . 2019.01.17 21:57:12 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.01.17 21:57:12 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.16.98.0/10.16.98.31/255.255.255.0 [sUCCEEDED] . 2019.01.17 21:57:12 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.16.98.31/255.255.255.0 on interface {9BD95422-1530-4E9F-B420-A66CA8AE4315} [DHCP-serv: 10.16.98.254, lease-time: 31536000] . 2019.01.17 21:57:12 - OpenVPN > Successful ARP Flush on interface [11] {9BD95422-1530-4E9F-B420-A66CA8AE4315} . 2019.01.17 21:57:12 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.01.17 21:57:13 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=11 fde6:7a:7d20:c62::101d store=active . 2019.01.17 21:57:14 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:c62::1 validate=no . 2019.01.17 21:57:14 - OpenVPN > add_route_ipv6(fde6:7a:7d20:c62::/64 -> fde6:7a:7d20:c62::101d metric 0) dev Ethernet 2 . 2019.01.17 21:57:14 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:c62::/64 interface=11 fe80::8 store=active . 2019.01.17 21:57:14 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:19 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\route.exe ADD 199.249.230.39 MASK 255.255.255.255 192.168.1.1 . 2019.01.17 21:57:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4 . 2019.01.17 21:57:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.16.98.1 . 2019.01.17 21:57:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 21:57:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.16.98.1 . 2019.01.17 21:57:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 21:57:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 21:57:19 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=11 fe80::8 store=active . 2019.01.17 21:57:19 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:19 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:57:19 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:19 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:57:19 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:19 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:c62::1 metric -1) dev Ethernet 2 . 2019.01.17 21:57:19 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 21:57:19 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:57:19 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4 . 2019.01.17 21:57:19 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6 . 2019.01.17 21:57:20 - DNS leak protection with packet filtering enabled. . 2019.01.17 21:57:20 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.16.98.1) . 2019.01.17 21:57:20 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:c62::1) . 2019.01.17 21:57:20 - Routes, added a new route, 199.249.230.37 for gateway 10.16.98.1 . 2019.01.17 21:57:20 - Routes, added a new route, 2620:7:6001:b0ec:2f3a:a3d0:966f:e483 for gateway fde6:7a:7d20:c62::1 . 2019.01.17 21:57:20 - Flushing DNS I 2019.01.17 21:57:23 - Checking route IPv4 . 2019.01.17 21:57:44 - curl: (28) Operation timed out after 20016 milliseconds with 0 out of 0 bytes received . 2019.01.17 21:57:44 - Checking route (2° try) . 2019.01.17 21:58:05 - curl: (28) Operation timed out after 20015 milliseconds with 0 out of 0 bytes received . 2019.01.17 21:58:05 - Checking route (3° try) . 2019.01.17 21:58:27 - curl: (28) Operation timed out after 20015 milliseconds with 0 out of 0 bytes received E 2019.01.17 21:58:27 - Checking route IPv4 failed. . 2019.01.17 21:58:27 - OpenVPN > Initialization Sequence Completed ! 2019.01.17 21:58:27 - Disconnecting . 2019.01.17 21:58:27 - Routes, removed a route previously added, 199.249.230.37 for gateway 10.16.98.1 . 2019.01.17 21:58:27 - Routes, removed a route previously added, 2620:7:6001:b0ec:2f3a:a3d0:966f:e483 for gateway fde6:7a:7d20:c62::1 . 2019.01.17 21:58:27 - Sending management termination signal . 2019.01.17 21:58:27 - Management - Send 'signal SIGTERM' . 2019.01.17 21:58:27 - OpenVPN > MANAGEMENT: CMD '028a97c2bf3a04660cf9fc7e21a56030e7ce2c7d1f16142aac96e960952add4a' . 2019.01.17 21:58:36 - Sending management termination signal . 2019.01.17 21:58:36 - Management - Send 'signal SIGTERM' . 2019.01.17 21:58:36 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.01.17 21:58:36 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.249.230.39 MASK 255.255.255.255 192.168.1.1 . 2019.01.17 21:58:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.16.98.1 . 2019.01.17 21:58:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.16.98.1 . 2019.01.17 21:58:42 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 21:58:42 - OpenVPN > delete_route_ipv6(::/3) . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=11 fe80::8 store=active . 2019.01.17 21:58:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:58:42 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:58:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:58:42 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 21:58:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:58:42 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 21:58:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 21:58:42 - OpenVPN > Closing TUN/TAP interface . 2019.01.17 21:58:42 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:c62::/64) . 2019.01.17 21:58:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:c62::/64 interface=11 fe80::8 store=active . 2019.01.17 21:58:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:c62::101d store=active . 2019.01.17 21:58:42 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all . 2019.01.17 21:58:42 - OpenVPN > TAP: DHCP address released . 2019.01.17 21:58:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.01.17 21:58:42 - Connection terminated. . 2019.01.17 21:58:43 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 21:58:43 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 21:58:43 - DNS leak protection with packet filtering disabled. . 2019.01.17 21:58:43 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4 . 2019.01.17 21:58:43 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6 I 2019.01.17 21:58:45 - Cancel requested. ! 2019.01.17 21:58:45 - Session terminated. this log is from hotspot(2) that works and is disconnected only after successful connection I 2019.01.17 22:02:55 - Session starting. I 2019.01.17 22:02:56 - Checking authorization ... ! 2019.01.17 22:02:56 - Connecting to Volans (United States, Dallas, Texas) . 2019.01.17 22:02:57 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018 . 2019.01.17 22:02:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2019.01.17 22:02:57 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 . 2019.01.17 22:02:57 - Connection to OpenVPN Management Interface . 2019.01.17 22:02:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2019.01.17 22:02:57 - OpenVPN > Outgoing Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 22:02:57 - OpenVPN > Outgoing Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 22:02:57 - OpenVPN > Incoming Control Channel Encryption: Cipher 'AES-256-CTR' initialized with 256 bit key . 2019.01.17 22:02:57 - OpenVPN > Incoming Control Channel Encryption: Using 256 bit message hash 'SHA256' for HMAC authentication . 2019.01.17 22:02:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.34:443 . 2019.01.17 22:02:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2019.01.17 22:02:57 - OpenVPN > UDP link local: (not bound) . 2019.01.17 22:02:57 - OpenVPN > UDP link remote: [AF_INET]199.249.230.34:443 . 2019.01.17 22:02:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2019.01.17 22:02:57 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.34:443, sid=fdee4447 39c4ad30 . 2019.01.17 22:02:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2019.01.17 22:02:57 - OpenVPN > VERIFY KU OK . 2019.01.17 22:02:57 - OpenVPN > Validating certificate extended key usage . 2019.01.17 22:02:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2019.01.17 22:02:57 - OpenVPN > VERIFY EKU OK . 2019.01.17 22:02:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Volans, emailAddress=info@airvpn.org . 2019.01.17 22:02:57 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2019.01.17 22:02:57 - OpenVPN > [Volans] Peer Connection Initiated with [AF_INET]199.249.230.34:443 . 2019.01.17 22:02:58 - OpenVPN > SENT CONTROL [Volans]: 'PUSH_REQUEST' (status=1) . 2019.01.17 22:02:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.32.94.1,dhcp-option DNS6 fde6:7a:7d20:1c5e::1,tun-ipv6,route-gateway 10.32.94.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1c5e::1039/64 fde6:7a:7d20:1c5e::1,ifconfig 10.32.94.59 255.255.255.0,peer-id 3,cipher AES-256-GCM' . 2019.01.17 22:02:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp' . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: compression parms modified . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: peer-id set . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625 . 2019.01.17 22:02:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified . 2019.01.17 22:02:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM' . 2019.01.17 22:02:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 22:02:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key . 2019.01.17 22:02:59 - OpenVPN > interactive service msg_channel=0 . 2019.01.17 22:02:59 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 I=10 HWADDR=98:5f:d3:f0:5f:5b . 2019.01.17 22:02:59 - OpenVPN > GDG6: remote_host_ipv6=n/a . 2019.01.17 22:02:59 - OpenVPN > GetBestInterfaceEx() returned if=2 . 2019.01.17 22:02:59 - OpenVPN > GDG6: II=2 DP=::/0 NH=:: . 2019.01.17 22:02:59 - OpenVPN > GDG6: Metric=256, Loopback=0, AA=1, I=0 . 2019.01.17 22:02:59 - OpenVPN > ROUTE6_GATEWAY :: ON_LINK I=2 . 2019.01.17 22:02:59 - OpenVPN > open_tun . 2019.01.17 22:02:59 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{9BD95422-1530-4E9F-B420-A66CA8AE4315}.tap . 2019.01.17 22:02:59 - OpenVPN > TAP-Windows Driver Version 9.21 . 2019.01.17 22:02:59 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.32.94.0/10.32.94.59/255.255.255.0 [sUCCEEDED] . 2019.01.17 22:02:59 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.32.94.59/255.255.255.0 on interface {9BD95422-1530-4E9F-B420-A66CA8AE4315} [DHCP-serv: 10.32.94.254, lease-time: 31536000] . 2019.01.17 22:02:59 - OpenVPN > Successful ARP Flush on interface [11] {9BD95422-1530-4E9F-B420-A66CA8AE4315} . 2019.01.17 22:02:59 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1 . 2019.01.17 22:03:00 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=11 fde6:7a:7d20:1c5e::1039 store=active . 2019.01.17 22:03:01 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1c5e::1 validate=no . 2019.01.17 22:03:01 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1c5e::/64 -> fde6:7a:7d20:1c5e::1039 metric 0) dev Ethernet 2 . 2019.01.17 22:03:01 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1c5e::/64 interface=11 fe80::8 store=active . 2019.01.17 22:03:01 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:06 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\route.exe ADD 199.249.230.34 MASK 255.255.255.255 192.168.43.1 . 2019.01.17 22:03:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 22:03:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.32.94.1 . 2019.01.17 22:03:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 22:03:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.32.94.1 . 2019.01.17 22:03:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4 . 2019.01.17 22:03:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2019.01.17 22:03:06 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1c5e::1 metric -1) dev Ethernet 2 . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=11 fe80::8 store=active . 2019.01.17 22:03:06 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:06 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1c5e::1 metric -1) dev Ethernet 2 . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 22:03:06 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:06 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1c5e::1 metric -1) dev Ethernet 2 . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 22:03:06 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:06 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1c5e::1 metric -1) dev Ethernet 2 . 2019.01.17 22:03:06 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 22:03:06 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:06 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4 . 2019.01.17 22:03:06 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6 . 2019.01.17 22:03:06 - DNS leak protection with packet filtering enabled. . 2019.01.17 22:03:07 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.32.94.1) . 2019.01.17 22:03:07 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1c5e::1) . 2019.01.17 22:03:07 - Routes, added a new route, 199.249.230.32 for gateway 10.32.94.1 . 2019.01.17 22:03:07 - Routes, added a new route, 2620:7:6001:87d5:3ae6:f925:2452:94b9 for gateway fde6:7a:7d20:1c5e::1 . 2019.01.17 22:03:07 - Flushing DNS I 2019.01.17 22:03:10 - Checking route IPv4 I 2019.01.17 22:03:11 - Checking route IPv6 I 2019.01.17 22:03:16 - Checking DNS ! 2019.01.17 22:03:16 - Connected. . 2019.01.17 22:03:16 - OpenVPN > Initialization Sequence Completed ! 2019.01.17 22:03:39 - Disconnecting . 2019.01.17 22:03:39 - Routes, removed a route previously added, 199.249.230.32 for gateway 10.32.94.1 . 2019.01.17 22:03:39 - Routes, removed a route previously added, 2620:7:6001:87d5:3ae6:f925:2452:94b9 for gateway fde6:7a:7d20:1c5e::1 . 2019.01.17 22:03:39 - Sending management termination signal . 2019.01.17 22:03:39 - Management - Send 'signal SIGTERM' . 2019.01.17 22:03:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2019.01.17 22:03:39 - OpenVPN > SIGTERM received, sending exit notification to peer . 2019.01.17 22:03:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.249.230.34 MASK 255.255.255.255 192.168.43.1 . 2019.01.17 22:03:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 22:03:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.32.94.1 . 2019.01.17 22:03:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 22:03:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.32.94.1 . 2019.01.17 22:03:45 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2019.01.17 22:03:45 - OpenVPN > delete_route_ipv6(::/3) . 2019.01.17 22:03:45 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=11 fe80::8 store=active . 2019.01.17 22:03:45 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:45 - OpenVPN > delete_route_ipv6(2000::/4) . 2019.01.17 22:03:45 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=11 fe80::8 store=active . 2019.01.17 22:03:45 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:45 - OpenVPN > delete_route_ipv6(3000::/4) . 2019.01.17 22:03:45 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=11 fe80::8 store=active . 2019.01.17 22:03:45 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:45 - OpenVPN > delete_route_ipv6(fc00::/7) . 2019.01.17 22:03:45 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=11 fe80::8 store=active . 2019.01.17 22:03:45 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem . 2019.01.17 22:03:45 - OpenVPN > Closing TUN/TAP interface . 2019.01.17 22:03:45 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1c5e::/64) . 2019.01.17 22:03:45 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1c5e::/64 interface=11 fe80::8 store=active . 2019.01.17 22:03:45 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1c5e::1039 store=active . 2019.01.17 22:03:45 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all . 2019.01.17 22:03:45 - OpenVPN > TAP: DHCP address released . 2019.01.17 22:03:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2019.01.17 22:03:45 - Connection terminated. . 2019.01.17 22:03:46 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 22:03:46 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic) . 2019.01.17 22:03:46 - DNS leak protection with packet filtering disabled. . 2019.01.17 22:03:46 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4 . 2019.01.17 22:03:46 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6 . 2019.01.17 22:03:46 - Flushing DNS ! 2019.01.17 22:03:49 - Session terminated. When I try to use the Openvpn client on hotspot (1) I can connect using config from the generator but have no internet as in sites dont load. Im at a loss nothing like this has ever happened before and Im not even the types who ever asks for help but i need support its been happening for weeks. Edited ... by giganerd Apply LOG formatting to logs Share this post Link to post
OpenSourcerer 1359 Posted ... (edited) Did you try searching for the error on AirVPN? Anyway, what you can try: You masterfully omitted all the output from Eddie before the connection attempts, so we have no info on Eddie and the library versions, therefore try an upgrade of Eddie. To the experimental version also. Of course you already tried different servers, ports and protocols, didn't you? Especially TCP, because it fixes the problem most of the time. Disable all unused network interfaces. Edited ... by giganerd Remove spoiler remark in favor of new LOG format Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
seja@nada.email 1 Posted ... only checked marked the box experimental workarounds...that fixed it. 1 OpenSourcerer reacted to this Share this post Link to post
