kbps 26 Posted ... Nunki as had line problems for over a month. Air what is your plan for it? Will it be decommissioned and replaced? Quote Share this post Link to post
Staff 9747 Posted ... Hello! IPv6 problems lead to connection failures when clients try to connect with IPv6 layer unblocked. Nunki will stay down until the datacenter does not restore IPv6 connectivity to Nunki. If such connectivity is not restored within one week from now, Nunki will be withdrawn and then replaced by a different server, also located in the UK of course. Kind regards 1 kbps reacted to this Quote Share this post Link to post
kbps 26 Posted ... Hello! IPv6 problems lead to connection failures when clients try to connect with IPv6 layer unblocked. Nunki will stay down until the datacenter does not restore IPv6 connectivity to Nunki. If such connectivity is not restored within one week from now, Nunki will be withdrawn and then replaced by a different server, also located in the UK of course. Kind regards Any update on this Air? It's been a week and still unreachable. Ill add to this in the fact that it doesn't effect me as there are plenty of other servers available to chose from. I however find it strange that Air have let this go on for so long. They are normally on top of issues like this. Quote Share this post Link to post
Staff 9747 Posted ... Hello! IPv6 problems lead to connection failures when clients try to connect with IPv6 layer unblocked. Nunki will stay down until the datacenter does not restore IPv6 connectivity to Nunki. If such connectivity is not restored within one week from now, Nunki will be withdrawn and then replaced by a different server, also located in the UK of course. Kind regards Any update on this Air? It's been a week and still unreachable. Ill add to this in the fact that it doesn't effect me as there are plenty of other servers available to chose from. I however find it strange that Air have let this go on for so long. They are normally on top of issues like this. Hello! We're very glad to inform you that a replacement server is now operating and under internal testing. Kind regards Quote Share this post Link to post
