Not connected, Your IP: 3.128.199.210
milkaca
UpnP \ DLNA not wokring with Network Lock
Hi, I am using minidlna on my Raspberry pi with latest stable version of Eddie.
When I start Eddie and turn on Network Lock, my Raspberry is no longer visible on the network.
Is it possible to configure it some how to work under the Network Lock, I guess it is related to iptable rules?
I managed to connect to my DLNA on the network and from there all worked, browsing folders, playing videos... But discovery on the network stopped to work, so every time when I need to connect again I must restart the service. Maybe if I add restart of the service every few seconds it will work.
Can I apply iptables rules in addition after Network Lock?
Like this:
sudo iptables -A INPUT -p tcp -m tcp -s 192.168.188.1/24 --dport 8200 -j ACCEPT
sudo iptables -A INPUT -p udp -m udp -s 192.168.188.1/24 --dport 8200 -j ACCEPT
sudo iptables -A INPUT -i eth0 -s 0.0.0.0/32 -d 224.0.0.1/32 -p igmp -j ACCEPT
sudo iptables -A INPUT -i eth0 -d 239.0.0.0/8 -p igmp -j ACCEPT
Ok, I will stop using Network Lock feature and try to figure out some alternative solution.
