Not connected, Your IP: 3.16.66.206
seedyunder
ANSWERED Ethernet Connection / TAP Adapter / Router / 100Mbps
Hi!
Having a strange issue I could use some help with.
I have a media server that is connected through Gigabit Ethernet to my router
VPN OFF : it connects at full speed and the router ui shows the wired connection is "1000 Mbps"
VPN ON : initially it connects at fast speeds, correctly through the vpn, but after 10-20 minutes it starts getting capped at 100Mbps and the router ui shows wired connection is "100 Mbps"
If I then switch VPN OFF the speed continues to be capped at 100Mbps until I reboot the router.
In windows the TAP adapter "status" show speed is "100 Mbps"
Does this "100 Mbps" status mean anything ?
Is it possible the TAP connection is reporting to the router that it is "100 Mbps" and the router sets it accordingly ?
Thanks for any help
Wow, I was beginning to wonder where they put this list as it wasn't on swupdate.openvpn.net anymore. Thank you for the link!
I have exact the same problem.
I un-installed tap 9.21.2, re-installed 9.22.1 resetted my router, but tap9 is still showing 100mbps
hence very slow system responce.
Switch of AirVpn, and I'm back to normal speed / system responce.
