blueruin39 0 Posted ... Not reachable on server IP over the external port [xxxxx], tcp protocol. Error : 111 - Connection refused. Why am I getting this error message when I test forwarded ports? I've tried troubleshooting by eliminating variables such as changing servers, creating new forwarded ports, restarting, ect., but when I test forwarded ports I continue to get the above error message (when I hover over the black circle after the test). Quote Share this post Link to post
Staff 9691 Posted ... Hello! Error 111 means "connection refused" and you get that error when packets from the Internet through our VPN server reach your node properly and are actively refused. The most common cause is a firewall dropping packets. Kind regards Quote Share this post Link to post
blueruin39 0 Posted ... Hello! Error 111 means "connection refused" and you get that error when packets from the Internet through our VPN server reach your node properly and are actively refused. The most common cause is a firewall dropping packets. Kind regards A firewall on my end? Because I don't have one running. What steps should I take to troubleshoot this from here? Quote Share this post Link to post
go558a83nk 343 Posted ... Hello! Error 111 means "connection refused" and you get that error when packets from the Internet through our VPN server reach your node properly and are actively refused. The most common cause is a firewall dropping packets. Kind regards A firewall on my end? Because I don't have one running. What steps should I take to troubleshoot this from here? Are you using Eddie and is the listening server on the same machine running Eddie? Quote Share this post Link to post
blueruin39 0 Posted ... I am using Eddie, yes. The listening server is whatever server that AirVPN uses to test open ports on the Portforwarding page, but I also used canyouseeme.org. The weird thing is that this problem is replicated across two of my systems (Linux and Mac), but on a third system (Linux), three ports are currently open and green. So I am able to port-forward on one system, but not on the other two? What is the common factor that would cause this to occur... Quote Share this post Link to post
go558a83nk 343 Posted ... I am using Eddie, yes. The listening server is whatever server that AirVPN uses to test open ports on the Portforwarding page, but I also used canyouseeme.org. The weird thing is that this problem is replicated across two of my systems (Linux and Mac), but on a third system (Linux), three ports are currently open and green. So I am able to port-forward on one system, but not on the other two? What is the common factor that would cause this to occur... No, the listening server is whatever you're trying to forward a port to. If that's not up and running and listening on the port you've assigned in the port forwarding rule the test will fail. Quote Share this post Link to post
blueruin39 0 Posted ... Roger that...because the port test cannot tell if the port is open if no traffic is flow through it? Quote Share this post Link to post
