Not connected, Your IP: 3.135.198.49
So i need guidance to get this work. Im not native english speaker so bare with me.
https://airvpn.org/ports/
xxxxx
Protocol: TCP&UDP
Local port: yyyyy
In uTorrent i have disabled all recommended settings (from faq page) and added incoming port to yyyyy
uTorret still says "not incoming connections" so issue with that yellow triangle.
So secondary thing, i logged in my router and added portforward tcp/udp from yyyyy to 192.168.0.15 (that is my torrenting machine in local network)
So i think that that AirVPN local port yyyyy is now sending packets to 192.168.0.15 but still uTorret still says "not incoming connections" .
I m desperate cause i need really portforward support cause better sharing speeds and connectivity.
It's not necessary for you to engage with your router at all for this. You can also use the TCP test by the way.
Remember to download the testtorrent from ipleak.net to see if you're leaking.
