LZ4 compression. is it safe/suggested to use with Airvpn?
compression
Best Answer Staff, 08 December 2018 - 02:13 PM
Currently our VPN servers are configured to not use compression, so you can't use LZO or LZ4 with AirVPN. Some old compression vulnerability is therefore resolved at its roots. Furthermore, the incompatibility between "comp-lzo" and "compress" directives (a mutual incompatibility which sooner or later might have a dramatic impact) should be more easily solved in due time.
Go to the full post
  • Please log in to reply
1 reply to this topic
#1 Air4141841
Air4141841
    Advanced Member
  • Members2
  • PipPipPip
  • 101 posts
Posted 08 December 2018 - 01:49 PM
I've read several places its not suggested to use LZ4 compression.   i have also verified with the Eddie client lzo compression is  turned OFF.
using my pfsense router should i try Lz4  or is this not suggested going forward?    or any links in explaining this i would appreciate it
thank you
#2 Staff
Staff
    Advanced Member
  • Staff
  • PipPipPip
  • 7856 posts
Posted 08 December 2018 - 02:13 PM   Best Answer
Similar Topics Collapse
Also tagged with one or more of these keywords: compression
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
Servers online. Online Sessions: 14473 - BW: 45478 Mbit/sYour IP: 54.198.92.22Guest Access.
