Not connected, Your IP: 18.188.61.223
alchemy420
Simultaneous connections on the same device
I just logged in to my account from my #2 (office) computer and see that my #1 (home) computer is simultaneously connecting to multiple sessions/servers. If I log out of #2 I wouldn't be able to log back in because #1 will immediately connect to yet another server. In other words computer #1 is connecting to all 5 of my available slots. Disconnecting from the client area does no good as it immediately reconnects. The only way I have found to stop this is to reboot #1. What could be causing this and how do I stop it?
I believe you need to go into Client Area - Devices/Keys and create a key for each device you use to log in. This enables you to use the same server, if desired, for each device.
