Not connected, Your IP: 216.73.217.178
grapefruit88
NEW User: Having problems connecting with my iPhone on LTE
For some reason, when my iPhone is on LTE (cellular Internet), I can't connect. I don't have any problems when my phone
is on WiFi. It connects fine. Here is the log:
2018-12-04 02:28:06 1
2018-12-04 02:28:06 ----- OpenVPN Start -----
OpenVPN core 3.2 ios arm64 64-bit PT_PROXY built on Oct 3 2018 06:35:04
2018-12-04 02:28:06 Frame=512/2048/512 mssfix-ctrl=1250
2018-12-04 02:28:06 UNUSED OPTIONS
3 [resolv-retry] [infinite]
4 [nobind]
5 [persist-key]
6 [persist-tun]
7 [auth-nocache]
8 [verb] [3]
9 [explicit-exit-notify] [5]
2018-12-04 02:28:06 EVENT: RESOLVE
2018-12-04 02:28:06 Contacting [96.47.229.58]:443/UDP via UDP
2018-12-04 02:28:06 EVENT: WAIT
2018-12-04 02:28:06 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-12-04 02:28:16 Server poll timeout, trying next remote entry...
2018-12-04 02:28:16 EVENT: RECONNECTING
2018-12-04 02:28:16 EVENT: RESOLVE
2018-12-04 02:28:16 Contacting [96.47.229.58]:443/UDP via UDP
2018-12-04 02:28:16 EVENT: WAIT
2018-12-04 02:28:16 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-12-04 02:28:27 Server poll timeout, trying next remote entry...
2018-12-04 02:28:27 EVENT: RECONNECTING
2018-12-04 02:28:27 EVENT: RESOLVE
2018-12-04 02:28:27 Contacting [96.47.229.58]:443/UDP via UDP
2018-12-04 02:28:27 EVENT: WAIT
2018-12-04 02:28:27 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-12-04 02:28:36 EVENT: CONNECTION_TIMEOUT [ERR]
2018-12-04 02:28:36 Raw stats on disconnect:
BYTES_OUT : 1176
PACKETS_OUT : 28
CONNECTION_TIMEOUT : 1
N_RECONNECT : 2
2018-12-04 02:28:36 Performance stats on disconnect:
CPU usage (microseconds): 49211
Network bytes per CPU second: 23897
Tunnel bytes per CPU second: 0
2018-12-04 02:28:36 EVENT: DISCONNECTED
BYTES_OUT : 1176
PACKETS_OUT : 28
N_RECONNECT : 2
2018-30-04 02:30:17 Server poll timeout, trying next remote entry...
2018-30-04 02:30:17 EVENT: RECONNECTING
2018-30-04 02:30:17 EVENT: RESOLVE
2018-30-04 02:30:17 Contacting [96.47.229.58]:443/UDP via UDP
2018-30-04 02:30:17 EVENT: WAIT
2018-30-04 02:30:17 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-30-04 02:30:28 Server poll timeout, trying next remote entry...
2018-30-04 02:30:28 EVENT: RECONNECTING
2018-30-04 02:30:28 EVENT: RESOLVE
2018-30-04 02:30:28 Contacting [96.47.229.58]:443/UDP via UDP
2018-30-04 02:30:28 EVENT: WAIT
2018-30-04 02:30:28 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-30-04 02:30:39 Server poll timeout, trying next remote entry...
2018-30-04 02:30:39 EVENT: RECONNECTING
2018-30-04 02:30:39 EVENT: RESOLVE
2018-30-04 02:30:39 Contacting [96.47.229.58]:443/UDP via UDP
2018-30-04 02:30:39 EVENT: WAIT
2018-30-04 02:30:39 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-30-04 02:30:50 Server poll timeout, trying next remote entry...
2018-30-04 02:30:50 EVENT: RECONNECTING
2018-30-04 02:30:50 EVENT: RESOLVE
2018-30-04 02:30:50 Contacting [96.47.229.58]:443/UDP via UDP
2018-30-04 02:30:50 EVENT: WAIT
2018-30-04 02:30:50 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-31-04 02:31:00 Server poll timeout, trying next remote entry...
2018-31-04 02:31:00 EVENT: RECONNECTING
2018-31-04 02:31:00 EVENT: RESOLVE
2018-31-04 02:31:00 Contacting [96.47.229.58]:443/UDP via UDP
2018-31-04 02:31:00 EVENT: WAIT
2018-31-04 02:31:00 Connecting to [96.47.229.58]:443 (96.47.229.58) via UDPv4
2018-31-04 02:31:07 EVENT: CONNECTION_TIMEOUT [ERR]
2018-31-04 02:31:07 Raw stats on disconnect:
BYTES_OUT : 2352
PACKETS_OUT : 56
N_RECONNECT : 5
2018-31-04 02:31:07 Performance stats on disconnect:
CPU usage (microseconds): 72907
Network bytes per CPU second: 32260
2018-31-04 02:31:07 EVENT: DISCONNECTED
BYTES_OUT : 2352
PACKETS_OUT : 56
N_RECONNECT : 5
Thanks.
I think your LTE provider blocks the protocol you are currently using "UDP". Try using TCP protocol instead of UDP
Thanks, that worked! Thanks.
