Not connected, Your IP: 3.141.200.180
marcmv1
LAN access on Eddie for Android
I'm unable to access resources on my LAN or use Chromecast when connected via the Android Eddie client. How do I exclude my LAN from being part of the VPN? This feature is available in the desktop windows & Linux versions.
FYI I've tried excluding via route in "Custom directives" and that doesn't work even though the OpenVPN logs say the route is excluded. I'd also like to exclude T-Mobile's /16 so I can make/receive wifi calls not over the VPN.
route 192.168.1.0 255.255.255.0 net_gateway
I side loaded android eddie 2.0 on my Nvidia shield tv and everything works fine, except I am unable to access my NAS which on my LAN. It looks like all trafic including LAN is being redirect to the VPN and I would like to exclude local traffic from being directed to the VPN. Is there a solution for this?
I'm pretty sure this has something to do with the Eddie Android client using OpenVPN 3. Same thing happens on the normal OpenVPN client when I enable 3, works correctly when I use 2. Would sure be nice to hear from AirVPN staff as my question has been outstanding for around a week now. I do pay for this service so I do expect support when I ask a reasonable question.
