melotten 1 Posted ... Hi All, I connected a machine running a service to airvpn and I want to access to it just via Airvpn. So, I added a port forwarding via Airvpn portal. If I connect via https://ipaddress:port/nameoftheservice it opens properly. if Use the DDNS name assigned to that port, I get a timeout. the TCP test is positive and I waited a whole day for replication. there is anything that I am missing or doing wrong? thanks for your help! Quote Share this post Link to post
Staff 9759 Posted ... Hello, can you please check whether your *.airdns.org name resolves properly into the exit-IP address of the last VPN server you connected to? Also keep in mind that TTL is 1 hour. Kind regards Quote Share this post Link to post
OpenSourcerer 1359 Posted ... if Use the DDNS name assigned to that port, I get a timeout. Are you not forgetting the :port after the DDNS name? I did that once. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
melotten 1 Posted ... Hello, can you please check whether your *.airdns.org name resolves properly into the exit-IP address of the last VPN server you connected to? Also keep in mind that TTL is 1 hour. Kind regards running an nslookup of the *.airdns.org address, is resolving in the ip address of the machine that I am using but not the one of the machine that is connected to airvpn and is actually running the service I want to reach. I hope I am clear am I doing something wrong or I did not understand how this works? Quote Share this post Link to post
melotten 1 Posted ... if Use the DDNS name assigned to that port, I get a timeout. Are you not forgetting the :port after the DDNS name? I did that once. I did the RTFM phase since I normally stuck there as in the best of the stories 1 OpenSourcerer reacted to this Quote Share this post Link to post
melotten 1 Posted ... any other help I can use on this one? I really don't want to use a third party ddns service Quote Share this post Link to post
