Not connected, Your IP: 3.140.185.123
kah0922
Eddie will not close on OpenSUSE Tumbleweed
Hello, using the latest experimental Eddie on OpenSUSE Tumbleweed, both on X and Wayland, whenever I try to exit Eddie, the windows will stay open, as if I never hit the close button. The exit prompt does appear, but Eddie will never actually exit, and is still fully operational, which means none of my configurations settings are saved as well.
What's your desktop? Can you launch eddie-ui via terminal (as it posts the log output into STDOUT) and paste it here after closing into spoilers?
Unfortunately there's nothing in the terminal output. I'm running KDE and I was wrong this only happens on Wayland.
Or... not. It closed on X once. Then I tested it on Wayland and would not exit. Now it won't exit on X either.
