Not connected, Your IP: 3.234.177.119
TheMentalClub
ANSWERED Continuous loop of trying to connect and disconnecting
Hi there.
I'm a new user and trying to sort all this out.  The first day or so my AIRVpn was working delightfully, and then I don't know what happened, but now it's in the continuous loop of trying to connect but not ever connecting.  It'll switch to another server, but the same thing happens over and over.
I'm wondering if anyone can help.
My logs are below.
. 2018.10.23 13:12:15 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319
. 2018.10.23 13:12:15 - Reading options from C:\Users\maril\AppData\Local\AirVPN\default.xml
. 2018.10.23 13:12:15 - Command line arguments (1): path="home"
. 2018.10.23 13:12:15 - Profile path: C:\Users\maril\AppData\Local\AirVPN\default.xml
. 2018.10.23 13:12:19 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2018.10.23 13:12:19 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2018.10.23 13:12:19 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2018.10.23 13:12:19 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2018.10.23 13:12:19 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2018.10.23 13:12:19 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
. 2018.10.23 13:12:20 - Updating systems & servers data ...
I 2018.10.23 13:12:20 - Ready
. 2018.10.23 13:12:26 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 9151: Connection refused - with 'socks' (always) proxy and 'none' auth)
I 2018.10.23 13:12:36 - Session starting.
I 2018.10.23 13:12:37 - Checking authorization ...
W 2018.10.23 13:12:42 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 127.0.0.1 port 9151: Connection refused - with 'socks' (always) proxy and 'none' auth)
! 2018.10.23 13:12:42 - Connecting to Sualocin (Canada, Toronto, Ontario)
. 2018.10.23 13:12:42 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.23 13:12:42 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.23 13:12:42 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.23 13:12:42 - Connection to OpenVPN Management Interface
. 2018.10.23 13:12:42 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.23 13:12:42 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.23 13:12:42 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.23 13:12:42 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:9151
. 2018.10.23 13:12:42 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.23 13:12:42 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:9151 [nonblock]
. 2018.10.23 13:12:43 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2018.10.23 13:12:56 - Disconnecting
. 2018.10.23 13:12:56 - Sending management termination signal
. 2018.10.23 13:12:56 - Management - Send 'signal SIGTERM'
. 2018.10.23 13:12:56 - OpenVPN > MANAGEMENT: CMD '619884afc09c930009e559166e3e228fa35c8d1afe6e6abf2dc56d5c8ce5c647'
. 2018.10.23 13:13:06 - Sending management termination signal
. 2018.10.23 13:13:06 - Management - Send 'signal SIGTERM'
. 2018.10.23 13:13:06 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.23 13:13:06 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2018.10.23 13:13:06 - Connection terminated.
I 2018.10.23 13:13:06 - Cancel requested.
! 2018.10.23 13:13:06 - Session terminated.
. 2018.10.23 13:23:08 - Updating systems & servers data ...
. 2018.10.23 13:23:14 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 9151: Connection refused - with 'socks' (always) proxy and 'none' auth)
. 2018.10.23 13:33:52 - Updating systems & servers data ...
. 2018.10.23 13:33:57 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 9151: Connection refused - with 'socks' (always) proxy and 'none' auth)
I 2018.10.23 13:44:00 - Session starting.
I 2018.10.23 13:44:00 - Retrieving manifest
F 2018.10.23 13:44:00 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 9151: Connection refused - with 'socks' (always) proxy and 'none' auth)
. 2018.10.23 13:44:00 - Updating systems & servers data ...
. 2018.10.23 13:44:12 - Cannot retrieve systems & servers data. (curl: (7) Failed to connect to 127.0.0.1 port 9151: Connection refused - with 'socks' (always) proxy and 'none' auth)
Please see here:
and here:
You have configured Eddie to connect over some proxy running in your system but your proxy is either not running or not listening to localhost port 9151. Please check your proxy settings. If you did not mean to have Eddie and OpenVPN connect to some proxy, check the settings you have modified in "Preferences" > "Proxy/Tor".
I'm experiencing the same problems every now and then. Under Eddi Preferences "Proxy/Tor" is turned off, in System Pereferences > Network > ... > Proxies nothing activated either. Would be super nice to fix this
my logs look like this:
I 2018.10.25 20:40:27 - Checking authorization ...
! 2018.10.25 20:40:28 - Connecting to Helvetios (United States, Dallas, Texas)
! 2018.10.25 20:40:28 - Disconnecting
. 2018.10.25 20:40:28 - Connection terminated.
I 2018.10.25 20:40:31 - Checking authorization ...
! 2018.10.25 20:40:32 - Connecting to Helvetios (United States, Dallas, Texas)
! 2018.10.25 20:40:32 - Disconnecting
. 2018.10.25 20:40:32 - Connection terminated.
I 2018.10.25 20:40:35 - Checking authorization ...
! 2018.10.25 20:40:36 - Connecting to Helvetios (United States, Dallas, Texas)
! 2018.10.25 20:40:36 - Disconnecting
. 2018.10.25 20:40:36 - Connection terminated.
Same thing here. I just install Eddie 2.16.3 on Linux Mint 18.3 and everything went fine. However I cannot get the utility to login to any server. It goes into a loop.
... connecting to server blabla
flushing DNS
checking route IPV4
checking route IPV6
disconnecting
I can't use this.
. 2018.11.18 10:57:25 - Eddie version: 2.16.3 / linux_x64, System: Linux, Name: Linux Mint 18.3 Sylvia \n \l, Version: Linux Mint181Sandra 4.15.0-38-generic #41~16.04.1-Ubuntu SMP Wed Oct 10 20:16:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux, Mono/.Net: 4.2.1 (Debian 4.2.1.102+dfsg2-7ubuntu4); Framework: v4.0.30319
. 2018.11.18 10:57:25 - Reading options from /home/maurice/.airvpn/default.xml
. 2018.11.18 10:57:26 - Command line arguments (5): path="/home/maurice/.airvpn" path.resources="/usr/share/eddie-ui" path.exec="/usr/bin/eddie-ui" console.mode="none" linux.dbus="unix:abstract=/tmp/dbus-cIKaXdGTnI,guid=0652ccb2ce73e70484cf419f5bf18313"
. 2018.11.18 10:57:26 - Profile path: /home/maurice/.airvpn/default.xml
. 2018.11.18 10:57:27 - OpenVPN Driver - Found, /dev/net/tun
. 2018.11.18 10:57:27 - OpenVPN - Version: 2.3.10 - OpenSSL 1.0.2g  1 Mar 2016, LZO 2.08 (/usr/sbin/openvpn)
. 2018.11.18 10:57:27 - SSH - Version: OpenSSH_7.2p2 Ubuntu-4ubuntu2.6, OpenSSL 1.0.2g  1 Mar 2016 (/usr/bin/ssh)
. 2018.11.18 10:57:27 - SSL - Version: stunnel 5.30 (/usr/bin/stunnel4)
. 2018.11.18 10:57:27 - curl - Version: 7.47.0 (/usr/bin/curl)
. 2018.11.18 10:57:27 - Certification Authorities: /usr/share/eddie-ui/cacert.pem
. 2018.11.18 10:57:27 - Updating systems & servers data ...
I 2018.11.18 10:57:27 - Ready
. 2018.11.18 10:57:31 - Systems & servers data update completed
