Not connected, Your IP: 3.144.251.72
gfdgfdgfd454asaakhj
Someone running eddie on Qubes OS?
Qubes OS is security focused OS. I was wondering if eddie can be ran on their network-vpn domain and if there are anything different or special when running it like that?
And while you're at it, you can compile a guide and enter AirVPN's Hall of Fame, also known as LZ1's New Users guide.
I have successfully used eddie-ui in Qubes 4.0...  however, with a caveat... I can only use it on individual APPVm...  not system-wide...  I've had success using ExpressVPN on the netvm System-wide.... albeit with a caveat... the network lock-down only works once a connection is established...  and everything passes the dns leak test...
