Not connected, Your IP: 18.219.63.90
lorenbenjo
Eddie on Win7 connection problem
I see that problem too. It happens every time after Windows has started. When everything has settled down and I start Eddie client for the first time, it won't be able to connect anywhere. You might get it to connect this way (works for me):
Cancel that 'restart loop' and exit Eddie client. Quit it completely, so that Eddie isn't running anymore.
Download BleachBit and install it:
https://en.wikipedia.org/wiki/BleachBit , https://www.bleachbit.org/
I've chosen to clean pretty much everything else but cookies, passwords and 'Free disk space'. I don't know exactly which options will make the positive result (I haven't tested one by one), but I believe it could be System: MUICache, Logs and Temporary files.
Run 'Clean' and wait for it to complete. Exit BleachBit. Restart Eddie client.
Your computer might be able to connect to AirVPN servers (also IPv6) at this point. At least that works for my computer.
Hey All,
I too have recently begun encountering a new-for-me connection problem on my updated Win 7 machine. This is a machine that I use only every couple of months or so, and Win 7 definitely installed a bunch of updates automagically prior to this my latest attempt series at connecting to AirVPN using Eddie.
Here are a few thoughts before considering my log file:
(1) I was on an older version, I think 2.14.3, early on, but I installed the latest non-experimental version during the course of my trials.
(2) I do have internet connectivity, and, as I'll explain later, the latest version of the PuTTY ssh suite; in fact, I downloaded that latest version of the eddie client using an ssh tunnel connected  browser.
(3) I've tried connecting both using the standard UDP port/method as well as via an ssh tunnel protocol. Neither works, the latter insists that I don't have an appropriate private key in my AirVPN private key-related folder (it even looks later at the one that I've decrypted in my running PuTTY pagent session).
(4) I've tried having the client forget my user/password combo and doing a reset of the Eddie client, but I don't really think that it deletes my cache or temp data in a manner described above; not only does it not help, I can no longer chose among the various protocols as the entire protocol option selections section is grayed out.
So, I turn to the pros here with the hope that maybe someone here can suggest a path forward. I've included a debugging-enabled log file just below. It shows two connection attempts, the first using the ssh protocol over port 22, and the second using the default UDP connection protocol via port 443.
Thanks!
john
! 2018.10.13 08:40:20 - Activation of Network Lock - Windows Filtering Platform
I 2018.10.13 08:41:00 - Session starting.
I 2018.10.13 08:41:01 - Checking authorization ...
! 2018.10.13 08:41:01 - Connecting to Chalawan (United States, Phoenix, Arizona)
. 2018.10.13 08:41:01 - Shell(7) of 'cmd.exe', 2 args: '/c';'route add 193.37.254.18 mask 255.255.255.255 192.168.11.1 if 11';
. 2018.10.13 08:41:01 - Shell(7) done in 78 ms, exit: 0, out: 'OK!'
. 2018.10.13 08:41:01 - Routes, added a new route, 193.37.254.18 for gateway 192.168.11.1
. 2018.10.13 08:41:01 - Shell(8) of 'cmd.exe', 2 args: '/c';'icacls "C:\Users\jrredho\AppData\Local\AirVPN\936e20c2dc974890b1f77f2b0d079943053ce5fa6cab88ae8c2cde28b9d6ef23.tmp.ppk" /c /t /inheritance:d';
. 2018.10.13 08:41:02 - Shell(8) done in 156 ms, exit: 0, out: 'processed file: C:\Users\jrredho\AppData\Local\AirVPN\936e20c2dc974890b1f77f2b0d079943053ce5fa6cab88ae8c2cde28b9d6ef23.tmp.ppk
. 2018.10.13 08:41:02 -     Successfully processed 1 files; Failed processing 0 files'
. 2018.10.13 08:41:02 - Shell(9) of 'cmd.exe', 2 args: '/c';'icacls "C:\Users\jrredho\AppData\Local\AirVPN\936e20c2dc974890b1f77f2b0d079943053ce5fa6cab88ae8c2cde28b9d6ef23.tmp.ppk"  /c /t /remove "NT AUTHORITY\Authenticated Users" "BUILTIN\Users"';
. 2018.10.13 08:41:02 - Shell(9) done in 46 ms, exit: 0, out: 'processed file: C:\Users\jrredho\AppData\Local\AirVPN\936e20c2dc974890b1f77f2b0d079943053ce5fa6cab88ae8c2cde28b9d6ef23.tmp.ppk
. 2018.10.13 08:41:02 - SSH > Looking up host "193.37.254.18"
. 2018.10.13 08:41:02 - SSH > Connecting to 193.37.254.18 port 22
. 2018.10.13 08:41:02 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.67
. 2018.10.13 08:41:02 - SSH > Server version: SSH-2.0-OpenSSH_7.4p1 Debian-10+deb9u3
. 2018.10.13 08:41:02 - SSH > Using SSH protocol version 2
. 2018.10.13 08:41:02 - SSH > Doing Diffie-Hellman group exchange
. 2018.10.13 08:41:02 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256
. 2018.10.13 08:41:02 - SSH > Host key fingerprint is:
. 2018.10.13 08:41:02 - SSH > ssh-rsa 2048 96:e8:60:88:05:d3:7e:0b:e8:87:38:11:60:93:89:a6
. 2018.10.13 08:41:02 - SSH > Initialised AES-256 SDCTR client->server encryption
. 2018.10.13 08:41:02 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm
. 2018.10.13 08:41:02 - SSH > Initialised AES-256 SDCTR server->client encryption
. 2018.10.13 08:41:02 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm
. 2018.10.13 08:41:03 - SSH > Reading private key file "C:\Users\jrredho\AppData\Local\AirVPN\936e20c2dc974890b1f77f2b0d079943053ce5fa6cab88ae8c2cde28b9d6ef23.tmp.ppk"
. 2018.10.13 08:41:03 - SSH > Pageant is running. Requesting keys.
. 2018.10.13 08:41:03 - SSH > Pageant has 1 SSH-2 keys
. 2018.10.13 08:41:03 - SSH > Configured key file not in Pageant
. 2018.10.13 08:41:03 - SSH > Using username "sshtunnel".
. 2018.10.13 08:41:03 - SSH > Offered public key
. 2018.10.13 08:41:24 - SSH > Network error: Software caused connection abort
. 2018.10.13 08:41:24 - SSH > FATAL ERROR: Network error: Software caused connection abort
! 2018.10.13 08:41:24 - Disconnecting
. 2018.10.13 08:41:24 - Shell(10) of 'cmd.exe', 2 args: '/c';'route delete 193.37.254.18 mask 255.255.255.255 192.168.11.1 if 11';
. 2018.10.13 08:41:24 - Shell(10) done in 47 ms, exit: 0, out: 'OK!'
. 2018.10.13 08:41:24 - Routes, removed a route previously added, 193.37.254.18 for gateway 192.168.11.1
. 2018.10.13 08:41:24 - Connection terminated.
I 2018.10.13 08:41:27 - Cancel requested.
! 2018.10.13 08:41:27 - Session terminated.
! 2018.10.13 08:41:30 - Deactivation of Network Lock
. 2018.10.13 08:41:36 - Shutdown in progress
! 2018.10.13 08:41:36 - Logged out.
. 2018.10.13 08:41:37 - Shutdown complete
. 2018.10.13 09:02:58 - Command line arguments (1): path="home"
. 2018.10.13 09:02:58 - Profile path: C:\Users\jrredho\AppData\Local\AirVPN\default.xml
. 2018.10.13 09:02:58 - Shell(1) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.10.13 09:02:58 - Shell(1) done in 250 ms, exit: 0, out: '===========================================================================
. 2018.10.13 09:02:58 -     Interface List
. 2018.10.13 09:02:58 -     12...00 ff f9 d4 71 19 ......TAP-Windows Adapter V9
. 2018.10.13 09:02:58 -     11...bc 30 5b ea 3f 05 ......Broadcom NetXtreme 57xx Gigabit Controller
. 2018.10.13 09:02:58 -     1...........................Software Loopback Interface 1
. 2018.10.13 09:02:58 -     14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
. 2018.10.13 09:02:58 -     15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
. 2018.10.13 09:02:58 -     13...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
. 2018.10.13 09:02:58 -     ===========================================================================
. 2018.10.13 09:02:58 -     IPv4 Route Table
. 2018.10.13 09:02:58 -     Active Routes:
. 2018.10.13 09:02:58 -     Network Destination        Netmask          Gateway       Interface  Metric
. 2018.10.13 09:02:58 -     0.0.0.0          0.0.0.0     192.168.11.1   192.168.11.201     20
. 2018.10.13 09:02:58 -     127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
. 2018.10.13 09:02:58 -     127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
. 2018.10.13 09:02:58 -     127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
. 2018.10.13 09:02:58 -     192.168.11.0    255.255.255.0         On-link    192.168.11.201    276
. 2018.10.13 09:02:58 -     192.168.11.201  255.255.255.255         On-link    192.168.11.201    276
. 2018.10.13 09:02:58 -     192.168.11.255  255.255.255.255         On-link    192.168.11.201    276
. 2018.10.13 09:02:58 -     224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
. 2018.10.13 09:02:58 -     224.0.0.0        240.0.0.0         On-link    192.168.11.201    276
. 2018.10.13 09:02:58 -     255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
. 2018.10.13 09:02:58 -     255.255.255.255  255.255.255.255         On-link    192.168.11.201    276
. 2018.10.13 09:02:58 -     Persistent Routes:
. 2018.10.13 09:02:58 -     None'
. 2018.10.13 09:02:58 - Shell(2) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.10.13 09:02:58 - Shell(2) done in 62 ms, exit: 0, out: '===========================================================================
. 2018.10.13 09:02:58 -     IPv6 Route Table
. 2018.10.13 09:02:58 -     If Metric Network Destination      Gateway
. 2018.10.13 09:02:58 -     1    306 ::1/128                  On-link
. 2018.10.13 09:02:58 -     11    276 fe80::/64                On-link
. 2018.10.13 09:02:58 -     11    276 fe80::a861:f35f:27ba:604f/128
. 2018.10.13 09:02:58 -     On-link
. 2018.10.13 09:02:58 -     1    306 ff00::/8                 On-link
. 2018.10.13 09:02:58 -     11    276 ff00::/8                 On-link
. 2018.10.13 09:02:59 - Shell(3) of 'C:\Program Files\AirVPN\openvpn.exe', 1 args: '--version';
. 2018.10.13 09:03:00 - Shell(3) done in 468 ms, exit: 1, out: 'OpenVPN 2.4.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.13 09:03:00 -     library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.13 09:03:00 -     Windows version 6.1 (Windows 7) 32bit
. 2018.10.13 09:03:00 -     Originally developed by James Yonan
. 2018.10.13 09:03:00 -     Copyright © 2002-2018 OpenVPN Inc <sales@openvpn.net>
. 2018.10.13 09:03:00 -     Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto=yes enable_crypto_ofb_cfb=yes enable_debug=yes enable_def_auth=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=needless enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_multihome=yes enable_pam_dlopen=no enable_pedantic=no enable_pf=yes enable_pkcs11=yes enable_plugin_auth_pam=no enable_plugin_down_root=no enable_plugins=yes enable_port_share=yes enable_selinux=no enable_server=yes enable_shared=yes enable_shared_with_static_runtimes=yes enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_special_build= with_sysroot=no'
. 2018.10.13 09:03:00 - Shell(4) of 'C:\Program Files\AirVPN\plink.exe', 1 args: '-V';
. 2018.10.13 09:03:00 - Shell(4) done in 93 ms, exit: 1, out: 'plink: Release 0.67'
. 2018.10.13 09:03:00 - Shell(5) of 'C:\Program Files\AirVPN\stunnel.exe', 1 args: '-version';
. 2018.10.13 09:03:00 - Shell(5) done in 219 ms, exit: 0, err: 'stunnel 5.40 on x86-pc-mingw32-gnu platform
. 2018.10.13 09:03:00 -     Compiled/running with OpenSSL 1.0.2k  26 Jan 2017
. 2018.10.13 09:03:00 -     Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI
. 2018.10.13 09:03:00 -     Global options:
. 2018.10.13 09:03:00 -     RNDbytes               = 64
. 2018.10.13 09:03:00 -     RNDoverwrite           = yes
. 2018.10.13 09:03:00 -     taskbar                = yes
. 2018.10.13 09:03:00 -     Service-level options:
. 2018.10.13 09:03:00 -     ciphers                = HIGH:!DH:!aNULL:!SSLv2
. 2018.10.13 09:03:00 -     curve                  = prime256v1
. 2018.10.13 09:03:00 -     debug                  = notice
. 2018.10.13 09:03:00 -     logId                  = sequential
. 2018.10.13 09:03:00 -     options                = NO_SSLv2
. 2018.10.13 09:03:00 -     options                = NO_SSLv3
. 2018.10.13 09:03:00 -     sessionCacheSize       = 1000
. 2018.10.13 09:03:00 -     sessionCacheTimeout    = 300 seconds
. 2018.10.13 09:03:00 -     stack                  = 65536 bytes
. 2018.10.13 09:03:00 -     TIMEOUTbusy            = 300 seconds
. 2018.10.13 09:03:00 -     TIMEOUTclose           = 60 seconds
. 2018.10.13 09:03:00 -     TIMEOUTconnect         = 10 seconds
. 2018.10.13 09:03:00 -     TIMEOUTidle            = 43200 seconds
. 2018.10.13 09:03:00 -     verify                 = none'
. 2018.10.13 09:03:00 - Shell(6) of 'C:\Program Files\AirVPN\curl.exe', 1 args: '--version';
. 2018.10.13 09:03:00 - Shell(6) done in 218 ms, exit: 0, out: 'curl 7.54.1 (i386-pc-win32) libcurl/7.54.1 OpenSSL/1.1.0f zlib/1.2.11 WinIDN libssh2/1.8.0 nghttp2/1.23.1
. 2018.10.13 09:03:00 -     Release-Date: 2017-06-14
. 2018.10.13 09:03:00 -     Protocols: dict file ftp ftps gopher http https imap imaps ldap ldaps pop3 pop3s rtsp scp sftp smtp smtps telnet tftp
. 2018.10.13 09:03:00 -     Features: AsynchDNS IDN IPv6 Largefile SSPI Kerberos SPNEGO NTLM SSL libz TLS-SRP HTTP2 HTTPS-proxy'
. 2018.10.13 09:03:00 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2018.10.13 09:03:00 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2018.10.13 09:03:00 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2018.10.13 09:03:00 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2018.10.13 09:03:00 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2018.10.13 09:03:00 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
. 2018.10.13 09:03:02 - Updating systems & servers data ...
I 2018.10.13 09:03:02 - Ready
. 2018.10.13 09:03:05 - Systems & servers data update completed
! 2018.10.13 09:03:06 - Activation of Network Lock - Windows Filtering Platform
I 2018.10.13 09:03:43 - Checking login ...
! 2018.10.13 09:03:43 - Logged in.
I 2018.10.13 09:04:04 - Session starting.
I 2018.10.13 09:04:04 - Checking authorization ...
! 2018.10.13 09:04:05 - Connecting to Chamaeleon (United States, Dallas, Texas)
. 2018.10.13 09:04:05 - OpenVPN > OpenVPN 2.4.6 i686-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.13 09:04:05 - OpenVPN > Windows version 6.1 (Windows 7) 32bit
. 2018.10.13 09:04:05 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.13 09:04:05 - Connection to OpenVPN Management Interface
. 2018.10.13 09:04:05 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.13 09:04:05 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.13 09:04:05 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.13 09:04:05 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.249.230.41:41185
. 2018.10.13 09:04:05 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]
. 2018.10.13 09:04:05 - OpenVPN > UDP link local: (not bound)
. 2018.10.13 09:04:05 - OpenVPN > UDP link remote: [AF_INET]199.249.230.41:41185
. 2018.10.13 09:04:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.13 09:04:06 - OpenVPN > TLS: Initial packet from [AF_INET]199.249.230.41:41185, sid=3a3e6097 84aea178
. 2018.10.13 09:04:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.10.13 09:04:06 - OpenVPN > VERIFY KU OK
. 2018.10.13 09:04:06 - OpenVPN > Validating certificate extended key usage
. 2018.10.13 09:04:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.10.13 09:04:06 - OpenVPN > VERIFY EKU OK
. 2018.10.13 09:04:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Chamaeleon, emailAddress=info@airvpn.org
. 2018.10.13 09:04:06 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.10.13 09:04:06 - OpenVPN > [Chamaeleon] Peer Connection Initiated with [AF_INET]199.249.230.41:41185
. 2018.10.13 09:04:07 - OpenVPN > SENT CONTROL [Chamaeleon]: 'PUSH_REQUEST' (status=1)
. 2018.10.13 09:04:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.13.232.1,dhcp-option DNS6 fde6:7a:7d20:9e8::1,tun-ipv6,route-gateway 10.13.232.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:9e8::10e8/64 fde6:7a:7d20:9e8::1,ifconfig 10.13.232.234 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2018.10.13 09:04:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.10.13 09:04:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.10.13 09:04:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.10.13 09:04:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.13 09:04:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.13 09:04:08 - OpenVPN > interactive service msg_channel=0
. 2018.10.13 09:04:08 - OpenVPN > ROUTE_GATEWAY 192.168.11.1/255.255.255.0 I=11 HWADDR=bc:30:5b:ea:3f:05
. 2018.10.13 09:04:08 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.10.13 09:04:08 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found.   (code=1168)
. 2018.10.13 09:04:08 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.10.13 09:04:08 - OpenVPN > open_tun
. 2018.10.13 09:04:08 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{F9D47119-5C00-42CD-9ADB-A7FB58E22F17}.tap
. 2018.10.13 09:04:08 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.10.13 09:04:08 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.13.232.0/10.13.232.234/255.255.255.0 [sUCCEEDED]
. 2018.10.13 09:04:08 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.13.232.234/255.255.255.0 on interface {F9D47119-5C00-42CD-9ADB-A7FB58E22F17} [DHCP-serv: 10.13.232.254, lease-time: 31536000]
. 2018.10.13 09:04:08 - OpenVPN > Successful ARP Flush on interface [12] {F9D47119-5C00-42CD-9ADB-A7FB58E22F17}
. 2018.10.13 09:04:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.10.13 09:04:09 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=12 fde6:7a:7d20:9e8::10e8 store=active
. 2018.10.13 09:04:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Local Area Connection 2 static fde6:7a:7d20:9e8::1 validate=no
. 2018.10.13 09:04:10 - Shell(7) of 'cmd.exe', 2 args: '/c';'route -6 print';
. 2018.10.13 09:04:10 - Shell(7) done in 47 ms, exit: 0, out: '===========================================================================
. 2018.10.13 09:04:10 -     Interface List
. 2018.10.13 09:04:10 -     12...00 ff f9 d4 71 19 ......TAP-Windows Adapter V9
. 2018.10.13 09:04:10 -     11...bc 30 5b ea 3f 05 ......Broadcom NetXtreme 57xx Gigabit Controller
. 2018.10.13 09:04:10 -     1...........................Software Loopback Interface 1
. 2018.10.13 09:04:10 -     14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
. 2018.10.13 09:04:10 -     15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
. 2018.10.13 09:04:10 -     13...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
. 2018.10.13 09:04:10 -     ===========================================================================
. 2018.10.13 09:04:10 -     IPv6 Route Table
. 2018.10.13 09:04:10 -     Active Routes:
. 2018.10.13 09:04:10 -     If Metric Network Destination      Gateway
. 2018.10.13 09:04:10 -     1    306 ::1/128                  On-link
. 2018.10.13 09:04:10 -     11    276 fe80::/64                On-link
. 2018.10.13 09:04:10 -     12    276 fe80::/64                On-link
. 2018.10.13 09:04:10 -     12    276 fe80::7c38:32da:ea88:83e4/128
. 2018.10.13 09:04:10 -     On-link
. 2018.10.13 09:04:10 -     11    276 fe80::a861:f35f:27ba:604f/128
. 2018.10.13 09:04:10 -     1    306 ff00::/8                 On-link
. 2018.10.13 09:04:10 -     11    276 ff00::/8                 On-link
. 2018.10.13 09:04:10 -     12    276 ff00::/8                 On-link
. 2018.10.13 09:04:10 -     Persistent Routes:
. 2018.10.13 09:04:10 -     None'
. 2018.10.13 09:04:10 - OpenVPN > add_route_ipv6(fde6:7a:7d20:9e8::/64 -> fde6:7a:7d20:9e8::10e8 metric 0) dev Local Area Connection 2
. 2018.10.13 09:04:10 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:9e8::/64 interface=12 fe80::8 store=active
. 2018.10.13 09:04:10 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.13 09:04:15 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.10.13 09:04:15 - OpenVPN > C:\Windows\system32\route.exe ADD 199.249.230.41 MASK 255.255.255.255 192.168.11.1
. 2018.10.13 09:04:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2018.10.13 09:04:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.10.13 09:04:15 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.13.232.1
. 2018.10.13 09:04:15 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.13.232.1
. 2018.10.13 09:04:15 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:9e8::1 metric -1) dev Local Area Connection 2
. 2018.10.13 09:04:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=12 fe80::8 store=active
. 2018.10.13 09:04:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.13 09:04:15 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:9e8::1 metric -1) dev Local Area Connection 2
. 2018.10.13 09:04:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=12 fe80::8 store=active
. 2018.10.13 09:04:16 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:9e8::1 metric -1) dev Local Area Connection 2
. 2018.10.13 09:04:16 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=12 fe80::8 store=active
. 2018.10.13 09:04:16 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.13 09:04:16 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:9e8::1 metric -1) dev Local Area Connection 2
. 2018.10.13 09:04:16 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=12 fe80::8 store=active
. 2018.10.13 09:04:16 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv4
. 2018.10.13 09:04:16 - Interface Local Area Connection 2 metric changed from Automatic to 3, layer IPv6
. 2018.10.13 09:04:16 - DNS leak protection with packet filtering enabled.
. 2018.10.13 09:04:16 - Shell(8) of 'cmd.exe', 2 args: '/c';'route -4 PRINT';
. 2018.10.13 09:04:16 - Shell(8) done in 110 ms, exit: 0, out: '===========================================================================
. 2018.10.13 09:04:16 -     Interface List
. 2018.10.13 09:04:16 -     12...00 ff f9 d4 71 19 ......TAP-Windows Adapter V9
. 2018.10.13 09:04:16 -     11...bc 30 5b ea 3f 05 ......Broadcom NetXtreme 57xx Gigabit Controller
. 2018.10.13 09:04:16 -     1...........................Software Loopback Interface 1
. 2018.10.13 09:04:16 -     14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
. 2018.10.13 09:04:16 -     15...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
. 2018.10.13 09:04:16 -     13...00 00 00 00 00 00 00 e0 Teredo Tunneling Pseudo-Interface
. 2018.10.13 09:04:16 -     ===========================================================================
. 2018.10.13 09:04:16 -     IPv4 Route Table
. 2018.10.13 09:04:16 -     Active Routes:
. 2018.10.13 09:04:16 -     Network Destination        Netmask          Gateway       Interface  Metric
. 2018.10.13 09:04:16 -     0.0.0.0          0.0.0.0     192.168.11.1   192.168.11.201     20
. 2018.10.13 09:04:16 -     0.0.0.0        128.0.0.0      10.13.232.1    10.13.232.234      3
. 2018.10.13 09:04:16 -     10.13.232.0    255.255.255.0         On-link     10.13.232.234    259
. 2018.10.13 09:04:16 -     10.13.232.234  255.255.255.255         On-link     10.13.232.234    259
. 2018.10.13 09:04:16 -     10.13.232.255  255.255.255.255         On-link     10.13.232.234    259
. 2018.10.13 09:04:16 -     127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
. 2018.10.13 09:04:16 -     127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
. 2018.10.13 09:04:16 -     127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
. 2018.10.13 09:04:16 -     128.0.0.0        128.0.0.0      10.13.232.1    10.13.232.234      3
. 2018.10.13 09:04:16 -     192.168.11.0    255.255.255.0         On-link    192.168.11.201    276
. 2018.10.13 09:04:16 -     192.168.11.201  255.255.255.255         On-link    192.168.11.201    276
. 2018.10.13 09:04:16 -     192.168.11.255  255.255.255.255         On-link    192.168.11.201    276
. 2018.10.13 09:04:16 -     199.249.230.41  255.255.255.255     192.168.11.1   192.168.11.201     20
. 2018.10.13 09:04:16 -     224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
. 2018.10.13 09:04:16 -     224.0.0.0        240.0.0.0         On-link    192.168.11.201    276
. 2018.10.13 09:04:16 -     224.0.0.0        240.0.0.0         On-link     10.13.232.234    259
. 2018.10.13 09:04:16 -     255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
. 2018.10.13 09:04:16 -     255.255.255.255  255.255.255.255         On-link    192.168.11.201    276
. 2018.10.13 09:04:16 -     255.255.255.255  255.255.255.255         On-link     10.13.232.234    259
. 2018.10.13 09:04:16 -     Persistent Routes:
. 2018.10.13 09:04:16 -     None'
. 2018.10.13 09:04:16 - Shell(9) of 'cmd.exe', 2 args: '/c';'route -6 PRINT';
. 2018.10.13 09:04:16 - Shell(9) done in 62 ms, exit: 0, out: '===========================================================================
. 2018.10.13 09:04:16 -     IPv6 Route Table
. 2018.10.13 09:04:16 -     If Metric Network Destination      Gateway
. 2018.10.13 09:04:16 -     12    259 ::/3                     fe80::8
. 2018.10.13 09:04:16 -     1    306 ::1/128                  On-link
. 2018.10.13 09:04:16 -     12    259 2000::/4                 fe80::8
. 2018.10.13 09:04:16 -     12    259 3000::/4                 fe80::8
. 2018.10.13 09:04:16 -     12    259 fc00::/7                 fe80::8
. 2018.10.13 09:04:16 -     12    259 fde6:7a:7d20:9e8::/64    fe80::8
. 2018.10.13 09:04:16 -     12    259 fde6:7a:7d20:9e8::10e8/128
. 2018.10.13 09:04:16 -     On-link
. 2018.10.13 09:04:16 -     11    276 fe80::/64                On-link
. 2018.10.13 09:04:16 -     12    259 fe80::/64                On-link
. 2018.10.13 09:04:16 -     12    259 fe80::7c38:32da:ea88:83e4/128
. 2018.10.13 09:04:16 -     11    276 fe80::a861:f35f:27ba:604f/128
. 2018.10.13 09:04:16 -     1    306 ff00::/8                 On-link
. 2018.10.13 09:04:16 -     11    276 ff00::/8                 On-link
. 2018.10.13 09:04:16 -     12    259 ff00::/8                 On-link
. 2018.10.13 09:04:16 - Shell(10) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Local Area Connection 2" source=static address=10.13.232.1 register=primary validate=no';
. 2018.10.13 09:04:17 - Shell(10) done in 1342 ms, exit: 0
. 2018.10.13 09:04:17 - DNS IPv4 of a network adapter forced (Local Area Connection 2, from manual (10.50.0.1) to 10.13.232.1)
. 2018.10.13 09:04:17 - Shell(11) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Local Area Connection 2" source=static address=fde6:7a:7d20:9e8::1 register=primary validate=no';
. 2018.10.13 09:04:17 - Shell(11) done in 125 ms, exit: 0
. 2018.10.13 09:04:17 - DNS IPv6 of a network adapter forced (Local Area Connection 2, from automatic to fde6:7a:7d20:9e8::1)
. 2018.10.13 09:04:18 - Shell(12) of 'cmd.exe', 2 args: '/c';'route add 199.249.230.42 mask 255.255.255.255 10.13.232.1 if 12';
. 2018.10.13 09:04:18 - Shell(12) done in 47 ms, exit: 0, out: 'OK!'
. 2018.10.13 09:04:18 - Routes, added a new route, 199.249.230.42 for gateway 10.13.232.1
. 2018.10.13 09:04:18 - Shell(13) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 add route prefix="2620:7:6001:8357:fe79:36f2:31e2:d195/128" interface="12" nexthop="fde6:7a:7d20:9e8::1"';
. 2018.10.13 09:04:18 - Shell(13) done in 109 ms, exit: 0, out: 'Ok.'
. 2018.10.13 09:04:18 - Routes, added a new route, 2620:7:6001:8357:fe79:36f2:31e2:d195 for gateway fde6:7a:7d20:9e8::1
. 2018.10.13 09:04:18 - Flushing DNS
. 2018.10.13 09:04:18 - Shell(14) of 'cmd.exe', 2 args: '/c';'ipconfig /flushdns';
. 2018.10.13 09:04:18 - Shell(14) done in 140 ms, exit: 0, out: 'Windows IP Configuration
. 2018.10.13 09:04:18 -     Successfully flushed the DNS Resolver Cache.'
. 2018.10.13 09:04:18 - Shell(15) of 'cmd.exe', 2 args: '/c';'ipconfig /registerdns';
. 2018.10.13 09:04:21 - Shell(15) done in 3073 ms, exit: 0, out: 'Windows IP Configuration
. 2018.10.13 09:04:21 -     Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.'
I 2018.10.13 09:04:21 - Checking route IPv4
I 2018.10.13 09:04:22 - Checking route IPv6
. 2018.10.13 09:04:22 - curl: (7) Failed to connect to chamaeleon_exit.airservers.org port 89: Bad access - Stack:    at Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.10.13 09:04:22 -     at Eddie.Core.Engine.FetchUrl(HttpRequest request)
. 2018.10.13 09:04:22 -     at Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.10.13 09:04:22 -     at Eddie.Core.Threads.Session.ConnectedStep()
. 2018.10.13 09:04:22 - Checking route (2° try)
. 2018.10.13 09:04:23 - curl: (7) Failed to connect to chamaeleon_exit.airservers.org port 89: Bad access - Stack:    at Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.10.13 09:04:23 -     at Eddie.Core.Engine.FetchUrl(HttpRequest request)
. 2018.10.13 09:04:23 -     at Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.10.13 09:04:23 -     at Eddie.Core.Threads.Session.ConnectedStep()
. 2018.10.13 09:04:23 - Checking route (3° try)
. 2018.10.13 09:04:25 - curl: (7) Failed to connect to chamaeleon_exit.airservers.org port 89: Bad access - Stack:    at Eddie.Core.Tools.Curl.Fetch(HttpRequest request)
. 2018.10.13 09:04:25 -     at Eddie.Core.Engine.FetchUrl(HttpRequest request)
. 2018.10.13 09:04:25 -     at Eddie.Core.Engine.FetchUrlXml(HttpRequest request)
. 2018.10.13 09:04:25 -     at Eddie.Core.Threads.Session.ConnectedStep()
E 2018.10.13 09:04:25 - Checking route IPv6 failed.
. 2018.10.13 09:04:25 - OpenVPN > Initialization Sequence Completed
! 2018.10.13 09:04:25 - Disconnecting
. 2018.10.13 09:04:25 - Shell(16) of 'cmd.exe', 2 args: '/c';'route delete 199.249.230.42 mask 255.255.255.255 10.13.232.1 if 12';
. 2018.10.13 09:04:25 - Shell(16) done in 78 ms, exit: 0, out: 'OK!'
. 2018.10.13 09:04:25 - Routes, removed a route previously added, 199.249.230.42 for gateway 10.13.232.1
. 2018.10.13 09:04:25 - Shell(17) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 del route prefix="2620:7:6001:8357:fe79:36f2:31e2:d195/128" interface="12" nexthop="fde6:7a:7d20:9e8::1"';
. 2018.10.13 09:04:25 - Shell(17) done in 140 ms, exit: 0, out: 'Ok.'
. 2018.10.13 09:04:25 - Routes, removed a route previously added, 2620:7:6001:8357:fe79:36f2:31e2:d195 for gateway fde6:7a:7d20:9e8::1
. 2018.10.13 09:04:25 - Sending management termination signal
. 2018.10.13 09:04:25 - Management - Send 'signal SIGTERM'
. 2018.10.13 09:04:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.13 09:04:26 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.13 09:04:26 - OpenVpn Management > SUCCESS: signal SIGTERM thrown
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.249.230.41 MASK 255.255.255.255 192.168.11.1
. 2018.10.13 09:04:31 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.13.232.1
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.13.232.1
. 2018.10.13 09:04:31 - OpenVPN > delete_route_ipv6(::/3)
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=12 fe80::8 store=active
. 2018.10.13 09:04:31 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.13 09:04:31 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=12 fe80::8 store=active
. 2018.10.13 09:04:31 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=12 fe80::8 store=active
. 2018.10.13 09:04:31 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=12 fe80::8 store=active
. 2018.10.13 09:04:31 - OpenVPN > Closing TUN/TAP interface
. 2018.10.13 09:04:31 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:9e8::/64)
. 2018.10.13 09:04:31 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:9e8::/64 interface=12 fe80::8 store=active
. 2018.10.13 09:04:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Local Area Connection 2 fde6:7a:7d20:9e8::10e8 store=active
. 2018.10.13 09:04:31 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Local Area Connection 2 all
. 2018.10.13 09:04:32 - OpenVPN > TAP: DHCP address released
. 2018.10.13 09:04:32 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.13 09:04:32 - Connection terminated.
. 2018.10.13 09:04:32 - Shell(18) of 'cmd.exe', 2 args: '/c';'netsh interface ipv4 set dns name="Local Area Connection 2" source=static address=10.50.0.1 register=primary validate=no';
. 2018.10.13 09:04:32 - Shell(18) done in 140 ms, exit: 0
. 2018.10.13 09:04:32 - DNS IPv4 of a network adapter restored to original settings (Local Area Connection 2, to 10.50.0.1)
. 2018.10.13 09:04:32 - Shell(19) of 'cmd.exe', 2 args: '/c';'netsh interface ipv6 set dns name="Local Area Connection 2" source=dhcp register=primary validate=no';
. 2018.10.13 09:04:32 - Shell(19) done in 125 ms, exit: 0
. 2018.10.13 09:04:32 - DNS IPv6 of a network adapter restored to original settings (Local Area Connection 2, to automatic)
. 2018.10.13 09:04:32 - DNS leak protection with packet filtering disabled.
. 2018.10.13 09:04:32 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv4
. 2018.10.13 09:04:32 - Interface Local Area Connection 2 metric restored from 3 to Automatic, layer IPv6
I 2018.10.13 09:04:34 - Cancel requested.
! 2018.10.13 09:04:34 - Session terminated.
! 2018.10.13 09:04:36 - Deactivation of Network Lock
. 2018.10.13 09:04:47 - Shutdown in progress
. 2018.10.13 09:04:48 - Shutdown complete
