Not connected, Your IP: 18.221.235.209
KilanOr
Can't connect plz help me !
Hi ! When i use my smartphone to get connection via an Mobile Hotspot, i can't connect ! (Only on my phone, who use FREE mobile) With other phone/operator, it's working. (SFR)
Plz what can i do.
Log:
. 2018.10.10 08:24:32 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319
. 2018.10.10 08:24:32 - Reading options from C:\Users\pacha\AppData\Local\AirVPN\default.xml
. 2018.10.10 08:24:33 - Command line arguments (1): path="home"
. 2018.10.10 08:24:33 - Profile path: C:\Users\pacha\AppData\Local\AirVPN\default.xml
. 2018.10.10 08:24:36 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
. 2018.10.10 08:24:36 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
. 2018.10.10 08:24:36 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
. 2018.10.10 08:24:36 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
. 2018.10.10 08:24:36 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
. 2018.10.10 08:24:36 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem
W 2018.10.10 08:24:37 - Recovery. Unexpected crash?
. 2018.10.10 08:24:37 - Routes, remove 213.152.162.10 for gateway 10.19.152.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.162.94 for gateway 10.17.216.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.180.5 for gateway 10.16.56.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.162.170 for gateway 10.12.132.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.162.94 for gateway 10.17.196.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.161.35 for gateway 10.19.68.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.162.181 for gateway 10.20.100.1 failed: Network interface no more available.
. 2018.10.10 08:24:37 - Routes, remove 213.152.161.40 for gateway 10.18.144.1 failed: Network interface no more available.
. 2018.10.10 08:24:38 - Routes, remove 213.152.161.138 for gateway 10.31.16.1 failed: Network interface no more available.
. 2018.10.10 08:24:38 - Routes, remove 213.152.161.149 for gateway 10.32.224.1 failed: Network interface no more available.
. 2018.10.10 08:24:38 - Routes, remove 213.152.161.239 for gateway 10.25.224.1 failed: Network interface no more available.
. 2018.10.10 08:24:38 - Routes, remove 213.152.161.25 for gateway 10.24.248.1 failed: Network interface no more available.
. 2018.10.10 08:24:38 - Routes, remove 2a00:1678:2470:41:56ef:1b83:3b7c:e518 for gateway fde6:7a:7d20:14f8::1 failed: Network interface no more available.
. 2018.10.10 08:24:38 - Routes, remove 213.152.162.109 for gateway 10.19.220.1 failed: La suppression de l'itin‚raire a ‚chou‚ÿ: l‚ment introuvable
. 2018.10.10 08:24:38 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:24:38 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:24:39 - Updating systems & servers data ...
I 2018.10.10 08:24:39 - Ready
. 2018.10.10 08:24:40 - Systems & servers data update completed
I 2018.10.10 08:25:18 - Session starting.
I 2018.10.10 08:25:18 - Checking authorization ...
! 2018.10.10 08:25:18 - Connecting to Gianfar (Netherlands, Alblasserdam)
. 2018.10.10 08:25:21 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:25:21 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:25:21 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:25:21 - Connection to OpenVPN Management Interface
. 2018.10.10 08:25:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:25:21 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:25:21 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:25:21 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.100:443
. 2018.10.10 08:25:21 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:25:21 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:25:21 - OpenVPN > UDP link remote: [AF_INET]213.152.161.100:443
. 2018.10.10 08:25:21 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.100:443, sid=26335842 14ce3979
. 2018.10.10 08:25:21 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.10.10 08:25:21 - OpenVPN > VERIFY KU OK
. 2018.10.10 08:25:21 - OpenVPN > Validating certificate extended key usage
. 2018.10.10 08:25:21 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.10.10 08:25:21 - OpenVPN > VERIFY EKU OK
. 2018.10.10 08:25:21 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.10.10 08:25:21 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.10.10 08:25:21 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.100:443
. 2018.10.10 08:25:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.10.10 08:25:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.17.160.1,dhcp-option DNS6 fde6:7a:7d20:da0::1,tun-ipv6,route-gateway 10.17.160.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:da0::1028/64 fde6:7a:7d20:da0::1,ifconfig 10.17.160.42 255.255.255.0,peer-id 3,cipher AES-256-GCM'
. 2018.10.10 08:25:21 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.10.10 08:25:21 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.10.10 08:25:21 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.10.10 08:25:21 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:25:21 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:25:21 - OpenVPN > interactive service msg_channel=0
. 2018.10.10 08:25:21 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 I=7 HWADDR=cc:b0:da:83:3c:9d
. 2018.10.10 08:25:21 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.10.10 08:25:21 - OpenVPN > NOTE: GetBestInterfaceEx returned error: lment introuvable.   (code=1168)
. 2018.10.10 08:25:21 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.10.10 08:25:21 - OpenVPN > open_tun
. 2018.10.10 08:25:21 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{03C2576A-84C9-4A21-85DC-6C2385476ED7}.tap
. 2018.10.10 08:25:21 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.10.10 08:25:21 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.17.160.0/10.17.160.42/255.255.255.0 [sUCCEEDED]
. 2018.10.10 08:25:21 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.17.160.42/255.255.255.0 on interface {03C2576A-84C9-4A21-85DC-6C2385476ED7} [DHCP-serv: 10.17.160.254, lease-time: 31536000]
. 2018.10.10 08:25:21 - OpenVPN > Successful ARP Flush on interface [2] {03C2576A-84C9-4A21-85DC-6C2385476ED7}
. 2018.10.10 08:25:21 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.10.10 08:25:22 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:25:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=2 fde6:7a:7d20:da0::1028 store=active
. 2018.10.10 08:25:23 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:da0::1 validate=no
. 2018.10.10 08:25:24 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.10.10 08:25:24 - OpenVPN > add_route_ipv6(fde6:7a:7d20:da0::/64 -> fde6:7a:7d20:da0::1028 metric 0) dev Ethernet 2
. 2018.10.10 08:25:24 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:da0::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:25:24 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:25:30 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.100 MASK 255.255.255.255 192.168.43.1
. 2018.10.10 08:25:30 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2018.10.10 08:25:30 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:25:30 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:25:30 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:25:30 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:25:30 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:25:30 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:25:30 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:25:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:25:30 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.10.10 08:25:30 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.10.10 08:25:30 - DNS leak protection with packet filtering enabled.
. 2018.10.10 08:25:31 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.17.160.1)
. 2018.10.10 08:25:31 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:da0::1)
. 2018.10.10 08:25:31 - Routes, added a new route, 213.152.161.101 for gateway 10.17.160.1
. 2018.10.10 08:25:32 - Routes, added a new route, 2a00:1678:2470:2a:4b7c:f79c:87e:8029 for gateway fde6:7a:7d20:da0::1
. 2018.10.10 08:25:32 - Flushing DNS
I 2018.10.10 08:25:35 - Checking route IPv4
. 2018.10.10 08:25:55 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:25:55 - Checking route (2° try)
. 2018.10.10 08:26:16 - curl: (28) Operation timed out after 20015 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:26:16 - Checking route (3° try)
. 2018.10.10 08:26:38 - curl: (28) Connection timed out after 20016 milliseconds
. 2018.10.10 08:26:38 - OpenVPN > Initialization Sequence Completed
! 2018.10.10 08:26:38 - Disconnecting
. 2018.10.10 08:26:38 - Routes, removed a route previously added, 213.152.161.101 for gateway 10.17.160.1
. 2018.10.10 08:26:39 - Routes, removed a route previously added, 2a00:1678:2470:2a:4b7c:f79c:87e:8029 for gateway fde6:7a:7d20:da0::1
. 2018.10.10 08:26:39 - Sending management termination signal
. 2018.10.10 08:26:39 - Management - Send 'signal SIGTERM'
. 2018.10.10 08:26:39 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.10 08:26:39 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.100 MASK 255.255.255.255 192.168.43.1
W 2018.10.10 08:26:44 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.43.1
. 2018.10.10 08:26:44 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2018.10.10 08:26:44 - OpenVPN > Route deletion fallback to route.exe
. 2018.10.10 08:26:44 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:26:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:26:44 - OpenVPN > delete_route_ipv6(::/3)
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:26:44 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:26:44 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:26:44 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:26:44 - OpenVPN > Closing TUN/TAP interface
. 2018.10.10 08:26:44 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:da0::/64)
. 2018.10.10 08:26:44 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:da0::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:26:44 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:da0::1028 store=active
. 2018.10.10 08:26:45 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.10.10 08:26:45 - OpenVPN > TAP: DHCP address released
. 2018.10.10 08:26:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.10 08:26:45 - Connection terminated.
. 2018.10.10 08:26:45 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:26:46 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:26:46 - DNS leak protection with packet filtering disabled.
. 2018.10.10 08:26:46 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.10.10 08:26:46 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.10.10 08:26:46 - Cancel requested.
! 2018.10.10 08:26:46 - Session terminated.
I 2018.10.10 08:26:56 - Session starting.
I 2018.10.10 08:26:56 - Checking authorization ...
! 2018.10.10 08:26:57 - Connecting to Gianfar (Netherlands, Alblasserdam)
. 2018.10.10 08:26:57 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:26:57 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:26:57 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:26:57 - Connection to OpenVPN Management Interface
. 2018.10.10 08:26:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:26:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:26:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:26:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.100:443
. 2018.10.10 08:26:57 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:26:57 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:26:57 - OpenVPN > UDP link remote: [AF_INET]213.152.161.100:443
. 2018.10.10 08:26:57 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:26:57 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.100:443, sid=b17ca353 20eeec0b
. 2018.10.10 08:26:57 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.10.10 08:26:57 - OpenVPN > VERIFY KU OK
. 2018.10.10 08:26:57 - OpenVPN > Validating certificate extended key usage
. 2018.10.10 08:26:57 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.10.10 08:26:57 - OpenVPN > VERIFY EKU OK
. 2018.10.10 08:26:57 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.10.10 08:26:58 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.10.10 08:26:58 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.100:443
. 2018.10.10 08:26:59 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.10.10 08:26:59 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.17.160.1,dhcp-option DNS6 fde6:7a:7d20:da0::1,tun-ipv6,route-gateway 10.17.160.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:da0::1028/64 fde6:7a:7d20:da0::1,ifconfig 10.17.160.42 255.255.255.0,peer-id 6,cipher AES-256-GCM'
. 2018.10.10 08:26:59 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.10.10 08:26:59 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.10.10 08:26:59 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.10.10 08:26:59 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:26:59 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:26:59 - OpenVPN > interactive service msg_channel=0
. 2018.10.10 08:26:59 - OpenVPN > ROUTE_GATEWAY 192.168.43.1/255.255.255.0 I=7 HWADDR=cc:b0:da:83:3c:9d
. 2018.10.10 08:26:59 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.10.10 08:26:59 - OpenVPN > NOTE: GetBestInterfaceEx returned error: lment introuvable.   (code=1168)
. 2018.10.10 08:26:59 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.10.10 08:26:59 - OpenVPN > open_tun
. 2018.10.10 08:27:00 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{03C2576A-84C9-4A21-85DC-6C2385476ED7}.tap
. 2018.10.10 08:27:00 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.10.10 08:27:00 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.17.160.0/10.17.160.42/255.255.255.0 [sUCCEEDED]
. 2018.10.10 08:27:00 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.17.160.42/255.255.255.0 on interface {03C2576A-84C9-4A21-85DC-6C2385476ED7} [DHCP-serv: 10.17.160.254, lease-time: 31536000]
. 2018.10.10 08:27:00 - OpenVPN > Successful ARP Flush on interface [2] {03C2576A-84C9-4A21-85DC-6C2385476ED7}
. 2018.10.10 08:27:00 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.10.10 08:27:00 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=2 fde6:7a:7d20:da0::1028 store=active
. 2018.10.10 08:27:01 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:da0::1 validate=no
. 2018.10.10 08:27:02 - OpenVPN > add_route_ipv6(fde6:7a:7d20:da0::/64 -> fde6:7a:7d20:da0::1028 metric 0) dev Ethernet 2
. 2018.10.10 08:27:02 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:da0::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:27:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:27:07 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.100 MASK 255.255.255.255 192.168.43.1
. 2018.10.10 08:27:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=55 and dwForwardType=4
. 2018.10.10 08:27:07 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:27:07 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:27:07 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:27:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:27:07 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:27:07 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:27:07 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:da0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:27:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:27:08 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.10.10 08:27:08 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.10.10 08:27:08 - DNS leak protection with packet filtering enabled.
. 2018.10.10 08:27:08 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.17.160.1)
. 2018.10.10 08:27:08 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:da0::1)
. 2018.10.10 08:27:08 - Routes, added a new route, 213.152.161.101 for gateway 10.17.160.1
. 2018.10.10 08:27:09 - Routes, added a new route, 2a00:1678:2470:2a:4b7c:f79c:87e:8029 for gateway fde6:7a:7d20:da0::1
. 2018.10.10 08:27:09 - Flushing DNS
I 2018.10.10 08:27:12 - Checking route IPv4
. 2018.10.10 08:27:32 - curl: (28) Operation timed out after 20016 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:27:32 - Checking route (2° try)
. 2018.10.10 08:27:53 - curl: (28) Operation timed out after 20015 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:27:53 - Checking route (3° try)
. 2018.10.10 08:28:15 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
E 2018.10.10 08:28:15 - Checking route IPv4 failed.
. 2018.10.10 08:28:15 - OpenVPN > Initialization Sequence Completed
! 2018.10.10 08:28:15 - Disconnecting
. 2018.10.10 08:28:16 - Routes, removed a route previously added, 213.152.161.101 for gateway 10.17.160.1
. 2018.10.10 08:28:17 - Routes, removed a route previously added, 2a00:1678:2470:2a:4b7c:f79c:87e:8029 for gateway fde6:7a:7d20:da0::1
. 2018.10.10 08:28:17 - Sending management termination signal
. 2018.10.10 08:28:17 - Management - Send 'signal SIGTERM'
. 2018.10.10 08:28:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.10 08:28:17 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.100 MASK 255.255.255.255 192.168.43.1
W 2018.10.10 08:28:22 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.43.1
. 2018.10.10 08:28:22 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2018.10.10 08:28:22 - OpenVPN > Route deletion fallback to route.exe
. 2018.10.10 08:28:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:28:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.17.160.1
. 2018.10.10 08:28:22 - OpenVPN > delete_route_ipv6(::/3)
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:28:22 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:28:22 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:28:22 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.10.10 08:28:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:28:23 - OpenVPN > Closing TUN/TAP interface
. 2018.10.10 08:28:23 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:da0::/64)
. 2018.10.10 08:28:23 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:da0::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:28:23 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:da0::1028 store=active
. 2018.10.10 08:28:23 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.10.10 08:28:23 - OpenVPN > TAP: DHCP address released
. 2018.10.10 08:28:23 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.10 08:28:24 - Connection terminated.
. 2018.10.10 08:28:24 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:28:24 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:28:24 - DNS leak protection with packet filtering disabled.
. 2018.10.10 08:28:24 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.10.10 08:28:24 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.10.10 08:28:27 - Checking authorization ...
W 2018.10.10 08:28:28 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 52.48.66.85 port 80: Host unreachable)
! 2018.10.10 08:28:28 - Connecting to Alphecca (Netherlands, Alblasserdam)
. 2018.10.10 08:28:28 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:28:28 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:28:28 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:28:28 - Connection to OpenVPN Management Interface
. 2018.10.10 08:28:28 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:28:28 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:28:28 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:28:28 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.4:443
. 2018.10.10 08:28:28 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:28:28 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:28:28 - OpenVPN > UDP link remote: [AF_INET]109.202.107.4:443
. 2018.10.10 08:28:28 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:29:00 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2018.10.10 08:29:00 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:29:05 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2018.10.10 08:29:05 - Disconnecting
. 2018.10.10 08:29:05 - Connection terminated.
I 2018.10.10 08:29:08 - Checking authorization ...
W 2018.10.10 08:29:08 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 52.48.66.85 port 80: Host unreachable)
! 2018.10.10 08:29:08 - Connecting to Alzirr (Netherlands, Alblasserdam)
. 2018.10.10 08:29:08 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:29:08 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:29:08 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:29:08 - Connection to OpenVPN Management Interface
. 2018.10.10 08:29:08 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:29:09 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:29:09 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:29:09 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.14:443
. 2018.10.10 08:29:09 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:29:09 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:29:09 - OpenVPN > UDP link remote: [AF_INET]109.202.107.14:443
. 2018.10.10 08:29:09 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:29:40 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2018.10.10 08:29:40 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:29:45 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2018.10.10 08:29:45 - Disconnecting
. 2018.10.10 08:29:45 - Connection terminated.
I 2018.10.10 08:29:48 - Checking authorization ...
W 2018.10.10 08:29:48 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 52.48.66.85 port 80: Host unreachable)
! 2018.10.10 08:29:48 - Connecting to Alphirk (Netherlands, Alblasserdam)
. 2018.10.10 08:29:48 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:29:48 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:29:48 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:29:48 - Connection to OpenVPN Management Interface
. 2018.10.10 08:29:48 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:29:48 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:29:48 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:29:48 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.202.107.146:443
. 2018.10.10 08:29:48 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:29:48 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:29:48 - OpenVPN > UDP link remote: [AF_INET]109.202.107.146:443
. 2018.10.10 08:29:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:30:20 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2018.10.10 08:30:20 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:30:25 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2018.10.10 08:30:25 - Disconnecting
. 2018.10.10 08:30:25 - Connection terminated.
I 2018.10.10 08:30:28 - Checking authorization ...
W 2018.10.10 08:30:29 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 52.48.66.85 port 80: Host unreachable)
! 2018.10.10 08:30:29 - Connecting to Matar (Netherlands, Alblasserdam)
. 2018.10.10 08:30:29 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:30:29 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:30:29 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:30:29 - Connection to OpenVPN Management Interface
. 2018.10.10 08:30:29 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:30:29 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:30:29 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:30:29 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.137:443
. 2018.10.10 08:30:29 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:30:29 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:30:29 - OpenVPN > UDP link remote: [AF_INET]109.232.227.137:443
. 2018.10.10 08:30:29 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
! 2018.10.10 08:30:50 - Disconnecting
. 2018.10.10 08:30:50 - Sending management termination signal
. 2018.10.10 08:30:50 - Management - Send 'signal SIGTERM'
. 2018.10.10 08:30:50 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.10 08:30:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:30:56 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.10 08:30:56 - Connection terminated.
I 2018.10.10 08:30:56 - Cancel requested.
! 2018.10.10 08:30:56 - Session terminated.
I 2018.10.10 08:31:09 - Session starting.
I 2018.10.10 08:31:09 - Checking authorization ...
W 2018.10.10 08:31:10 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 52.48.66.85 port 80: Host unreachable)
! 2018.10.10 08:31:10 - Connecting to Matar (Netherlands, Alblasserdam)
! 2018.10.10 08:31:33 - Disconnecting
. 2018.10.10 08:31:33 - Sending soft termination signal
. 2018.10.10 08:31:43 - Sending hard termination signal
. 2018.10.10 08:31:43 - Connection terminated.
I 2018.10.10 08:31:43 - Cancel requested.
! 2018.10.10 08:31:43 - Session terminated.
I 2018.10.10 08:32:52 - Session starting.
I 2018.10.10 08:32:53 - Checking authorization ...
! 2018.10.10 08:32:53 - Connecting to Matar (Netherlands, Alblasserdam)
. 2018.10.10 08:33:10 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:33:10 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:33:10 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:33:10 - Connection to OpenVPN Management Interface
. 2018.10.10 08:33:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:33:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:33:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:33:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.137:443
. 2018.10.10 08:33:10 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:33:10 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:33:10 - OpenVPN > UDP link remote: [AF_INET]109.232.227.137:443
. 2018.10.10 08:33:10 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.137:443, sid=2e247ec1 86fe6bc1
. 2018.10.10 08:33:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.10.10 08:33:10 - OpenVPN > VERIFY KU OK
. 2018.10.10 08:33:10 - OpenVPN > Validating certificate extended key usage
. 2018.10.10 08:33:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.10.10 08:33:10 - OpenVPN > VERIFY EKU OK
. 2018.10.10 08:33:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.10.10 08:33:10 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.10.10 08:33:10 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]109.232.227.137:443
. 2018.10.10 08:33:10 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.10.10 08:33:10 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.21.96.1,dhcp-option DNS6 fde6:7a:7d20:1160::1,tun-ipv6,route-gateway 10.21.96.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1160::1000/64 fde6:7a:7d20:1160::1,ifconfig 10.21.96.2 255.255.255.0,peer-id 2,cipher AES-256-GCM'
. 2018.10.10 08:33:10 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.10.10 08:33:10 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.10.10 08:33:10 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.10.10 08:33:10 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:33:10 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:33:10 - OpenVPN > interactive service msg_channel=0
. 2018.10.10 08:33:10 - OpenVPN > ROUTE_GATEWAY 192.168.42.129/255.255.255.0 I=57 HWADDR=02:01:05:56:35:38
. 2018.10.10 08:33:10 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.10.10 08:33:10 - OpenVPN > NOTE: GetBestInterfaceEx returned error: lment introuvable.   (code=1168)
. 2018.10.10 08:33:10 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.10.10 08:33:10 - OpenVPN > open_tun
. 2018.10.10 08:33:10 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{03C2576A-84C9-4A21-85DC-6C2385476ED7}.tap
. 2018.10.10 08:33:10 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.10.10 08:33:10 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.21.96.0/10.21.96.2/255.255.255.0 [sUCCEEDED]
. 2018.10.10 08:33:10 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.21.96.2/255.255.255.0 on interface {03C2576A-84C9-4A21-85DC-6C2385476ED7} [DHCP-serv: 10.21.96.254, lease-time: 31536000]
. 2018.10.10 08:33:10 - OpenVPN > Successful ARP Flush on interface [2] {03C2576A-84C9-4A21-85DC-6C2385476ED7}
. 2018.10.10 08:33:10 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.10.10 08:33:10 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:33:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=2 fde6:7a:7d20:1160::1000 store=active
. 2018.10.10 08:33:12 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1160::1 validate=no
. 2018.10.10 08:33:12 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.10.10 08:33:13 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1160::/64 -> fde6:7a:7d20:1160::1000 metric 0) dev Ethernet 2
. 2018.10.10 08:33:13 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1160::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:33:13 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:33:17 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.10.10 08:33:17 - OpenVPN > C:\Windows\system32\route.exe ADD 109.232.227.137 MASK 255.255.255.255 192.168.42.129
. 2018.10.10 08:33:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.10.10 08:33:17 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.10.10 08:33:17 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.21.96.1
. 2018.10.10 08:33:17 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.10.10 08:33:17 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.21.96.1
. 2018.10.10 08:33:17 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1160::1 metric -1) dev Ethernet 2
. 2018.10.10 08:33:17 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:33:17 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:33:17 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1160::1 metric -1) dev Ethernet 2
. 2018.10.10 08:33:17 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:33:18 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1160::1 metric -1) dev Ethernet 2
. 2018.10.10 08:33:18 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:33:18 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:33:18 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1160::1 metric -1) dev Ethernet 2
. 2018.10.10 08:33:18 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:33:18 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.10.10 08:33:18 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.10.10 08:33:18 - DNS leak protection with packet filtering enabled.
. 2018.10.10 08:33:19 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.21.96.1)
. 2018.10.10 08:33:19 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1160::1)
. 2018.10.10 08:33:19 - Routes, added a new route, 109.232.227.138 for gateway 10.21.96.1
. 2018.10.10 08:33:20 - Routes, added a new route, 2a00:1678:2470:15:edc0:d33d:672d:5f19 for gateway fde6:7a:7d20:1160::1
. 2018.10.10 08:33:20 - Flushing DNS
I 2018.10.10 08:33:23 - Checking route IPv4
. 2018.10.10 08:33:43 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:33:43 - Checking route (2° try)
. 2018.10.10 08:34:04 - curl: (28) Operation timed out after 20016 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:34:04 - OpenVPN > Initialization Sequence Completed
! 2018.10.10 08:34:04 - Disconnecting
. 2018.10.10 08:34:04 - Routes, removed a route previously added, 109.232.227.138 for gateway 10.21.96.1
. 2018.10.10 08:34:05 - Routes, removed a route previously added, 2a00:1678:2470:15:edc0:d33d:672d:5f19 for gateway fde6:7a:7d20:1160::1
. 2018.10.10 08:34:05 - OpenVPN > write UDP: Unknown error (code=10055)
. 2018.10.10 08:34:05 - Sending management termination signal
. 2018.10.10 08:34:05 - Management - Send 'signal SIGTERM'
. 2018.10.10 08:34:05 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.10 08:34:05 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:34:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.232.227.137 MASK 255.255.255.255 192.168.42.129
W 2018.10.10 08:34:10 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.42.129
. 2018.10.10 08:34:10 - OpenVPN > Route deletion via IPAPI failed [adaptive]
. 2018.10.10 08:34:10 - OpenVPN > Route deletion fallback to route.exe
. 2018.10.10 08:34:10 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:34:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.21.96.1
. 2018.10.10 08:34:10 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.10.10 08:34:10 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.21.96.1
. 2018.10.10 08:34:10 - OpenVPN > delete_route_ipv6(::/3)
. 2018.10.10 08:34:10 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:34:11 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.10.10 08:34:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:34:11 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:34:11 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.10.10 08:34:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:34:11 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.10.10 08:34:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:34:11 - OpenVPN > Closing TUN/TAP interface
. 2018.10.10 08:34:11 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1160::/64)
. 2018.10.10 08:34:11 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1160::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:34:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1160::1000 store=active
. 2018.10.10 08:34:11 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.10.10 08:34:12 - OpenVPN > TAP: DHCP address released
. 2018.10.10 08:34:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.10 08:34:12 - Connection terminated.
. 2018.10.10 08:34:12 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:34:13 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:34:13 - DNS leak protection with packet filtering disabled.
. 2018.10.10 08:34:13 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.10.10 08:34:13 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.10.10 08:34:13 - Cancel requested.
! 2018.10.10 08:34:13 - Session terminated.
. 2018.10.10 08:35:33 - Updating systems & servers data ...
. 2018.10.10 08:35:34 - Systems & servers data update completed
I 2018.10.10 08:39:31 - Session starting.
I 2018.10.10 08:39:32 - Checking authorization ...
! 2018.10.10 08:39:32 - Connecting to Alchiba (Netherlands, Alblasserdam)
. 2018.10.10 08:39:32 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:39:32 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:39:32 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:39:32 - Connection to OpenVPN Management Interface
. 2018.10.10 08:39:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:39:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:39:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:39:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.180:443
. 2018.10.10 08:39:32 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:39:32 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:39:32 - OpenVPN > UDP link remote: [AF_INET]213.152.161.180:443
. 2018.10.10 08:39:32 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:39:32 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.180:443, sid=4ab96bef ec542ad3
. 2018.10.10 08:39:32 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.10.10 08:39:32 - OpenVPN > VERIFY KU OK
. 2018.10.10 08:39:32 - OpenVPN > Validating certificate extended key usage
. 2018.10.10 08:39:32 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.10.10 08:39:32 - OpenVPN > VERIFY EKU OK
. 2018.10.10 08:39:32 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2018.10.10 08:39:33 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.10.10 08:39:33 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.180:443
. 2018.10.10 08:39:34 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2018.10.10 08:39:34 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.5.128.1,dhcp-option DNS6 fde6:7a:7d20:180::1,tun-ipv6,route-gateway 10.5.128.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:180::10b9/64 fde6:7a:7d20:180::1,ifconfig 10.5.128.187 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2018.10.10 08:39:34 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.10.10 08:39:34 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.10.10 08:39:34 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.10.10 08:39:34 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:39:34 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:39:34 - OpenVPN > interactive service msg_channel=0
. 2018.10.10 08:39:34 - OpenVPN > ROUTE_GATEWAY 192.168.42.129/255.255.255.0 I=57 HWADDR=02:01:05:56:35:38
. 2018.10.10 08:39:34 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.10.10 08:39:34 - OpenVPN > NOTE: GetBestInterfaceEx returned error: lment introuvable.   (code=1168)
. 2018.10.10 08:39:34 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.10.10 08:39:34 - OpenVPN > open_tun
. 2018.10.10 08:39:35 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{03C2576A-84C9-4A21-85DC-6C2385476ED7}.tap
. 2018.10.10 08:39:35 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.10.10 08:39:35 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.5.128.0/10.5.128.187/255.255.255.0 [sUCCEEDED]
. 2018.10.10 08:39:35 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.5.128.187/255.255.255.0 on interface {03C2576A-84C9-4A21-85DC-6C2385476ED7} [DHCP-serv: 10.5.128.254, lease-time: 31536000]
. 2018.10.10 08:39:35 - OpenVPN > Successful ARP Flush on interface [2] {03C2576A-84C9-4A21-85DC-6C2385476ED7}
. 2018.10.10 08:39:35 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.10.10 08:39:35 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=2 fde6:7a:7d20:180::10b9 store=active
. 2018.10.10 08:39:37 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:180::1 validate=no
. 2018.10.10 08:39:37 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.10.10 08:39:37 - OpenVPN > add_route_ipv6(fde6:7a:7d20:180::/64 -> fde6:7a:7d20:180::10b9 metric 0) dev Ethernet 2
. 2018.10.10 08:39:37 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:180::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:39:37 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:39:42 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.180 MASK 255.255.255.255 192.168.42.129
. 2018.10.10 08:39:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.10.10 08:39:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.5.128.1
. 2018.10.10 08:39:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.5.128.1
. 2018.10.10 08:39:42 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:180::1 metric -1) dev Ethernet 2
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:39:42 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:39:42 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:180::1 metric -1) dev Ethernet 2
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:39:42 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:180::1 metric -1) dev Ethernet 2
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:39:42 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:180::1 metric -1) dev Ethernet 2
. 2018.10.10 08:39:42 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:39:42 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.10.10 08:39:42 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.10.10 08:39:42 - DNS leak protection with packet filtering enabled.
. 2018.10.10 08:39:43 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.5.128.1)
. 2018.10.10 08:39:43 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:180::1)
. 2018.10.10 08:39:43 - Routes, added a new route, 213.152.161.181 for gateway 10.5.128.1
. 2018.10.10 08:39:44 - Routes, added a new route, 2a00:1678:2470:19:9016:df76:43b5:703e for gateway fde6:7a:7d20:180::1
. 2018.10.10 08:39:44 - Flushing DNS
I 2018.10.10 08:39:47 - Checking route IPv4
. 2018.10.10 08:40:07 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:40:07 - Checking route (2° try)
. 2018.10.10 08:40:28 - curl: (28) Operation timed out after 20016 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:40:28 - Checking route (3° try)
. 2018.10.10 08:40:50 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
E 2018.10.10 08:40:50 - Checking route IPv4 failed.
. 2018.10.10 08:40:50 - OpenVPN > Initialization Sequence Completed
! 2018.10.10 08:40:50 - Disconnecting
. 2018.10.10 08:40:51 - Routes, removed a route previously added, 213.152.161.181 for gateway 10.5.128.1
. 2018.10.10 08:40:51 - Routes, removed a route previously added, 2a00:1678:2470:19:9016:df76:43b5:703e for gateway fde6:7a:7d20:180::1
. 2018.10.10 08:40:51 - Sending management termination signal
. 2018.10.10 08:40:51 - Management - Send 'signal SIGTERM'
. 2018.10.10 08:40:51 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.10 08:40:51 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.180 MASK 255.255.255.255 192.168.42.129
. 2018.10.10 08:40:56 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.5.128.1
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.5.128.1
. 2018.10.10 08:40:56 - OpenVPN > delete_route_ipv6(::/3)
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:40:56 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:40:56 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:40:56 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:40:56 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:40:56 - OpenVPN > Closing TUN/TAP interface
. 2018.10.10 08:40:56 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:180::/64)
. 2018.10.10 08:40:56 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:180::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:40:57 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:180::10b9 store=active
. 2018.10.10 08:40:57 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.10.10 08:40:57 - OpenVPN > TAP: DHCP address released
. 2018.10.10 08:40:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.10 08:40:57 - Connection terminated.
. 2018.10.10 08:40:58 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:40:58 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:40:58 - DNS leak protection with packet filtering disabled.
. 2018.10.10 08:40:59 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.10.10 08:40:59 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.10.10 08:41:02 - Checking authorization ...
! 2018.10.10 08:41:02 - Connecting to Cygnus (Netherlands, Alblasserdam)
. 2018.10.10 08:41:02 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018
. 2018.10.10 08:41:02 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.10.10 08:41:02 - OpenVPN > library versions: OpenSSL 1.1.0h  27 Mar 2018, LZO 2.10
. 2018.10.10 08:41:02 - Connection to OpenVPN Management Interface
. 2018.10.10 08:41:02 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.10.10 08:41:02 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:41:02 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.10.10 08:41:02 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.243:443
. 2018.10.10 08:41:02 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.10.10 08:41:02 - OpenVPN > UDP link local: (not bound)
. 2018.10.10 08:41:02 - OpenVPN > UDP link remote: [AF_INET]213.152.161.243:443
. 2018.10.10 08:41:02 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.10.10 08:41:02 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.243:443, sid=23b0ca8b cd09a186
. 2018.10.10 08:41:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.10.10 08:41:03 - OpenVPN > VERIFY KU OK
. 2018.10.10 08:41:03 - OpenVPN > Validating certificate extended key usage
. 2018.10.10 08:41:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.10.10 08:41:03 - OpenVPN > VERIFY EKU OK
. 2018.10.10 08:41:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cygnus, emailAddress=info@airvpn.org
. 2018.10.10 08:41:03 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.10.10 08:41:03 - OpenVPN > [Cygnus] Peer Connection Initiated with [AF_INET]213.152.161.243:443
. 2018.10.10 08:41:04 - OpenVPN > SENT CONTROL [Cygnus]: 'PUSH_REQUEST' (status=1)
. 2018.10.10 08:41:04 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.14.224.1,dhcp-option DNS6 fde6:7a:7d20:ae0::1,tun-ipv6,route-gateway 10.14.224.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:ae0::10cd/64 fde6:7a:7d20:ae0::1,ifconfig 10.14.224.207 255.255.255.0,peer-id 1,cipher AES-256-GCM'
. 2018.10.10 08:41:04 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2018.10.10 08:41:04 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2018.10.10 08:41:04 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2018.10.10 08:41:04 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:41:04 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2018.10.10 08:41:04 - OpenVPN > interactive service msg_channel=0
. 2018.10.10 08:41:04 - OpenVPN > ROUTE_GATEWAY 192.168.42.129/255.255.255.0 I=57 HWADDR=02:01:05:56:35:38
. 2018.10.10 08:41:04 - OpenVPN > GDG6: remote_host_ipv6=n/a
. 2018.10.10 08:41:04 - OpenVPN > NOTE: GetBestInterfaceEx returned error: lment introuvable.   (code=1168)
. 2018.10.10 08:41:04 - OpenVPN > ROUTE6: default_gateway=UNDEF
. 2018.10.10 08:41:04 - OpenVPN > open_tun
. 2018.10.10 08:41:05 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{03C2576A-84C9-4A21-85DC-6C2385476ED7}.tap
. 2018.10.10 08:41:05 - OpenVPN > TAP-Windows Driver Version 9.21
. 2018.10.10 08:41:05 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.14.224.0/10.14.224.207/255.255.255.0 [sUCCEEDED]
. 2018.10.10 08:41:05 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.14.224.207/255.255.255.0 on interface {03C2576A-84C9-4A21-85DC-6C2385476ED7} [DHCP-serv: 10.14.224.254, lease-time: 31536000]
. 2018.10.10 08:41:05 - OpenVPN > Successful ARP Flush on interface [2] {03C2576A-84C9-4A21-85DC-6C2385476ED7}
. 2018.10.10 08:41:05 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1
. 2018.10.10 08:41:05 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=2 fde6:7a:7d20:ae0::10cd store=active
. 2018.10.10 08:41:07 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:ae0::1 validate=no
. 2018.10.10 08:41:07 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.
. 2018.10.10 08:41:07 - OpenVPN > add_route_ipv6(fde6:7a:7d20:ae0::/64 -> fde6:7a:7d20:ae0::10cd metric 0) dev Ethernet 2
. 2018.10.10 08:41:07 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:ae0::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:41:07 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:41:12 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.243 MASK 255.255.255.255 192.168.42.129
. 2018.10.10 08:41:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4
. 2018.10.10 08:41:12 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.14.224.1
. 2018.10.10 08:41:12 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.14.224.1
. 2018.10.10 08:41:12 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:ae0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:41:12 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:41:12 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:ae0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:41:12 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:ae0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:41:12 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:ae0::1 metric -1) dev Ethernet 2
. 2018.10.10 08:41:12 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:41:13 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4
. 2018.10.10 08:41:13 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6
. 2018.10.10 08:41:13 - DNS leak protection with packet filtering enabled.
. 2018.10.10 08:41:14 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.14.224.1)
. 2018.10.10 08:41:14 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:ae0::1)
. 2018.10.10 08:41:14 - Routes, added a new route, 213.152.161.244 for gateway 10.14.224.1
. 2018.10.10 08:41:14 - Routes, added a new route, 2a00:1678:2470:49:9349:d7bc:f715:bb08 for gateway fde6:7a:7d20:ae0::1
. 2018.10.10 08:41:14 - Flushing DNS
I 2018.10.10 08:41:18 - Checking route IPv4
. 2018.10.10 08:41:38 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:41:38 - Checking route (2° try)
. 2018.10.10 08:41:59 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
. 2018.10.10 08:41:59 - Checking route (3° try)
. 2018.10.10 08:42:21 - curl: (28) Operation timed out after 20000 milliseconds with 0 out of 0 bytes received
E 2018.10.10 08:42:21 - Checking route IPv4 failed.
. 2018.10.10 08:42:21 - OpenVPN > Initialization Sequence Completed
! 2018.10.10 08:42:21 - Disconnecting
. 2018.10.10 08:42:21 - Routes, removed a route previously added, 213.152.161.244 for gateway 10.14.224.1
. 2018.10.10 08:42:22 - Routes, removed a route previously added, 2a00:1678:2470:49:9349:d7bc:f715:bb08 for gateway fde6:7a:7d20:ae0::1
. 2018.10.10 08:42:22 - Sending management termination signal
. 2018.10.10 08:42:22 - Management - Send 'signal SIGTERM'
. 2018.10.10 08:42:22 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2018.10.10 08:42:22 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.243 MASK 255.255.255.255 192.168.42.129
. 2018.10.10 08:42:27 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.14.224.1
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.14.224.1
. 2018.10.10 08:42:27 - OpenVPN > delete_route_ipv6(::/3)
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=2 fe80::8 store=active
. 2018.10.10 08:42:27 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem
. 2018.10.10 08:42:27 - OpenVPN > delete_route_ipv6(2000::/4)
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:42:27 - OpenVPN > delete_route_ipv6(3000::/4)
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=2 fe80::8 store=active
. 2018.10.10 08:42:27 - OpenVPN > delete_route_ipv6(fc00::/7)
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=2 fe80::8 store=active
. 2018.10.10 08:42:27 - OpenVPN > Closing TUN/TAP interface
. 2018.10.10 08:42:27 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:ae0::/64)
. 2018.10.10 08:42:27 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:ae0::/64 interface=2 fe80::8 store=active
. 2018.10.10 08:42:27 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:ae0::10cd store=active
. 2018.10.10 08:42:28 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all
. 2018.10.10 08:42:28 - OpenVPN > TAP: DHCP address released
. 2018.10.10 08:42:28 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
. 2018.10.10 08:42:28 - Connection terminated.
. 2018.10.10 08:42:29 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:42:29 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic)
. 2018.10.10 08:42:29 - DNS leak protection with packet filtering disabled.
. 2018.10.10 08:42:30 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4
. 2018.10.10 08:42:30 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6
I 2018.10.10 08:42:33 - Cancel requested.
! 2018.10.10 08:42:33 - Session terminated.
