Not connected, Your IP: 3.149.233.72
cse
At Last! Eddie 2.17.2 solves the "takes forever to connect" issue when Network Lock is engaged issue
I'm running PCLOS (Plasma 5). Prior versions, especially 2.16.x, took FOREVER to connect, when the Network Lock was engaged (typically, 5 to 8 minutes). The latest 2.17.2 release completely solves the problem. It now takes about 5 seconds. Marvelous job guys!
cse
I went back to an old version of Eddie from 2017 and got my old AirVPN.xml settings file as well. It makes things run much better. There is something with the new version of Eddie that is screwing with connections.
