- Install Eddie - OpenVPN GUI for Android from Google Play Store or download the APK from our Eddie web site. Eddie is a free and open source application designed and developed by AirVPN.
- Launch your internet browser.
NOTE: don't use the default Android browser because it has an unresolved bug.
Chrome and Opera have been tested by us and work. - Connect to AirVPN website, login and create the configuration files from our Config Generator.
Choose Android as platform (only direct TCP and UDP connections are supported) and finally click the "Generate" button to download it. - Downloaded .ovpn files may be imported directly into the application but the behavior depends on many factors (employed browser, files manager, Android version, etc).
For simplicity's sake, we assume in this guide that you saved .ovpn generated files under the internal storage directory in the Android filesystem. - Open Eddie - OpenVPN GUI for Android and tap the "Import profile" button:
- Browse to *.ovpn files:
- Tap the "Connect" button:
- Confirm the Android's security prompt dialog:
- Eddie is now connected and the VPN tunnel is now established:
- For advanced options tap the "Menu" icon:
- Tap "Settings" button:
- Advanced settings:
- Activity log:
- When you need to disconnect from the VPN click on the "Disconnect" button:
2 replies to this topic
#1
Posted 28 September 2018 - 01:27 PM
- LZ1 likes this
#3
Posted 29 September 2018 - 09:28 PM
Is there a way to download this without the Play Store? I don't use Google Framework on my LineageOS ROM. Fdroid or the apk itself?
Thank you.
They mentioned they will be on F-Droid pretty soon as well as a direct link to the APK on this site.
https://airvpn.org/topic/29665-eddie-android-edition-10-released/
Also tagged with one or more of these keywords: android, eddie
Community →
Eddie - AirVPN Client →
Persistent tunnel on Android causing problems.Started by cdysthe, 12 Feb 2019 ![]() |
Community →
Howto build eddie-cli for ARMv6?Started by gladde, 05 Feb 2019 ![]() |
![]() Tiny eddie-UIStarted by namefirstlast, 05 Feb 2019 ![]() |
Community →
Interactive Wrapper for Eddie's CLI versionStarted by nwlyoc, 29 Jan 2019 ![]() |
Community →
Restore profile at boot not working ?Started by Guest_pyro.tokyo_* , 25 Jan 2019 ![]() |
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
