Not connected, Your IP: 216.73.216.28
routeninja
Android box CPU OpenVPN?
Hello everyone,
I am a bit of a newb when it comes to this kind of stuff so please bear with me.
I am currently using a Linux desktop computer to stream IPTV and Plex to my TV. I have to use Air because my ISP throttles my connection. This is working out OK, but I would like to replace it with something more energy efficient.
I purchased this: https://www.aliexpress.com/item/Tanix-TX3-Mini-Smart-Android-7-1-TV-Box-S905W-2GB-RAM-DDR3-16GB-ROM-eMMC/32841900292.html?spm=a2g0s.9042311.0.0.19d04c4dSfxxOD
It runs on Android 7.1 and has very good reviews. Is this something that you think I would be able to run Air on? I am concerned that the CPU might not be enough to handle to connection. Does anyone have any experience with this? I assume I would just download the main OpenVPN app and load a ovpn file on it. Will it ask for a password everytime? I would like it just to autoconnect everytime. Any tips would be most welcome.
Thank you!
Hello everyone,
Thank you!
you could try running the AirVPN Android beta on it.
Hello everyone,
Thank you!
Is that this one? https://play.google.com/store/apps/details?id=net.openvpn.openvpn
