Soupcan Sam Hootkins 13 Posted ... Hey, everyone.Just reinstalled Windows 10 and Eddie (2.16.3) on my computer, don't have any antivirus besides Windows Defender installed, and websites won't load with network lock enabled. It's currently set to "automatic," which is where it's always been and never had any problems before. It was working just fine that way yesterday, so I'm not entirely sure why it wouldn't be working now. Anyone have a recommendation?Thank you, Quote Share this post Link to post
go558a83nk 352 Posted ... It sounds like you aren't connected to the VPN Quote Share this post Link to post
OpenSourcerer 1359 Posted ... An active forum member like you should know better - where is your log? Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Soupcan Sam Hootkins 13 Posted ... I just reinstalled AirVPN today. It connected to a few servers, but websites wouldn't load again. I disconnected from the servers, and now it won't even connect to anything. Here is the log:. 2018.09.19 13:27:21 - Eddie version: 2.16.3 / windows_x64, System: Windows, Name: Windows 10 Pro, Version: Microsoft Windows NT 10.0.17134.0, Mono/.Net: v4.0.30319. 2018.09.19 13:27:21 - Reading options from C:\Users\Kevin\AppData\Local\AirVPN\default.xml. 2018.09.19 13:27:21 - Profile options not found, using defaults.. 2018.09.19 13:27:22 - Command line arguments (1): path="home". 2018.09.19 13:27:22 - Profile path: C:\Users\Kevin\AppData\Local\AirVPN\default.xml. 2018.09.19 13:27:23 - Cannot find tunnel adapter.E 2018.09.19 13:27:25 - OpenVPN Driver - Not available - Will be installed at next connection.. 2018.09.19 13:27:25 - OpenVPN - Version: 2.4.6 - OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe). 2018.09.19 13:27:25 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe). 2018.09.19 13:27:25 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe). 2018.09.19 13:27:25 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe). 2018.09.19 13:27:25 - Certification Authorities: C:\Program Files\AirVPN\res\cacert.pem. 2018.09.19 13:27:26 - Updating systems & servers data ...I 2018.09.19 13:27:26 - Ready. 2018.09.19 13:27:27 - Systems & servers data update completedI 2018.09.19 13:27:38 - Checking login ...! 2018.09.19 13:27:39 - Logged in.! 2018.09.19 13:27:47 - Activation of Network Lock - Windows Filtering PlatformI 2018.09.19 13:27:49 - Session starting.. 2018.09.19 13:27:49 - Cannot find tunnel adapter.! 2018.09.19 13:27:49 - Installing tunnel driverI 2018.09.19 13:27:55 - Checking authorization .... 2018.09.19 13:27:56 - IPv6 disabled with packet filtering.! 2018.09.19 13:27:56 - Connecting to Cynosura (Canada, Vancouver). 2018.09.19 13:27:56 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:27:56 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:27:56 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:27:56 - Connection to OpenVPN Management Interface. 2018.09.19 13:27:56 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:27:56 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:27:56 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:27:56 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.21:443. 2018.09.19 13:27:56 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:27:56 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:27:56 - OpenVPN > UDP link remote: [AF_INET]71.19.252.21:443. 2018.09.19 13:27:56 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=dc3b261a 5c8156a3. 2018.09.19 13:27:56 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:27:56 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:27:56 - OpenVPN > VERIFY KU OK. 2018.09.19 13:27:56 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:27:56 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:27:56 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:27:56 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cynosura, emailAddress=info@airvpn.org. 2018.09.19 13:27:56 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:27:56 - OpenVPN > [Cynosura] Peer Connection Initiated with [AF_INET]71.19.252.21:443. 2018.09.19 13:27:57 - OpenVPN > SENT CONTROL [Cynosura]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:27:57 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.15.8.1,route-gateway 10.15.8.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.15.8.161 255.255.255.0,peer-id 8,cipher AES-256-GCM'. 2018.09.19 13:27:57 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:27:57 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:27:57 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:27:57 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:27:57 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:27:57 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:27:57 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:27:57 - OpenVPN > open_tun. 2018.09.19 13:27:58 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:27:58 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:27:58 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.15.8.0/10.15.8.161/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:27:58 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.15.8.161/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.15.8.254, lease-time: 31536000]. 2018.09.19 13:27:58 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:27:58 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2018.09.19 13:28:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:28:02 - OpenVPN > C:\Windows\system32\route.exe ADD 71.19.252.21 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:28:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:28:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:28:02 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:28:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:28:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:28:02 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:28:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:28:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:28:02 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:28:02 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:28:02 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:28:03 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.15.8.1). 2018.09.19 13:28:03 - Routes, added a new route, 71.19.252.22 for gateway 10.15.8.1. 2018.09.19 13:28:03 - Flushing DNSI 2018.09.19 13:28:06 - Checking route IPv4I 2018.09.19 13:28:09 - Checking DNS! 2018.09.19 13:28:10 - Connected.. 2018.09.19 13:28:10 - OpenVPN > Initialization Sequence Completed! 2018.09.19 13:31:29 - Disconnecting. 2018.09.19 13:31:29 - Routes, removed a route previously added, 71.19.252.22 for gateway 10.15.8.1. 2018.09.19 13:31:29 - Sending management termination signal. 2018.09.19 13:31:29 - Management - Send 'signal SIGTERM'. 2018.09.19 13:31:29 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:31:29 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:31:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 71.19.252.21 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:31:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:31:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:31:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:31:34 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:31:34 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:31:34 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:31:34 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:31:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:31:34 - Connection terminated.. 2018.09.19 13:31:34 - IPv6 restored with packet filtering.. 2018.09.19 13:31:34 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:31:34 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:31:34 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:31:34 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6I 2018.09.19 13:31:34 - Checking authorization .... 2018.09.19 13:31:35 - IPv6 disabled with packet filtering.! 2018.09.19 13:31:35 - Connecting to Persei (United States, Fremont, California). 2018.09.19 13:31:35 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:31:35 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:31:35 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:31:35 - Connection to OpenVPN Management Interface. 2018.09.19 13:31:35 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:31:35 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:31:35 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:31:35 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]94.100.23.162:443. 2018.09.19 13:31:35 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:31:35 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:31:35 - OpenVPN > UDP link remote: [AF_INET]94.100.23.162:443. 2018.09.19 13:31:35 - OpenVPN > TLS: Initial packet from [AF_INET]94.100.23.162:443, sid=c6cae421 dedc2212. 2018.09.19 13:31:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:31:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:31:35 - OpenVPN > VERIFY KU OK. 2018.09.19 13:31:35 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:31:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:31:35 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:31:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2018.09.19 13:31:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:31:35 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]94.100.23.162:443. 2018.09.19 13:31:36 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:31:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.26.104.1,route-gateway 10.26.104.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.26.104.169 255.255.255.0,peer-id 0,cipher AES-256-GCM'. 2018.09.19 13:31:36 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:31:36 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:31:36 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:31:36 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:31:36 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:31:36 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:31:37 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:31:37 - OpenVPN > open_tun. 2018.09.19 13:31:37 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:31:37 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:31:37 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.26.104.0/10.26.104.169/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:31:37 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.26.104.169/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.26.104.254, lease-time: 31536000]. 2018.09.19 13:31:37 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:31:37 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2018.09.19 13:31:42 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:31:42 - OpenVPN > C:\Windows\system32\route.exe ADD 94.100.23.162 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:31:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:31:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:31:42 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.26.104.1. 2018.09.19 13:31:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:31:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:31:42 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.26.104.1. 2018.09.19 13:31:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:31:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:31:42 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:31:42 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:31:42 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:31:42 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.26.104.1). 2018.09.19 13:31:42 - Routes, added a new route, 94.100.23.163 for gateway 10.26.104.1. 2018.09.19 13:31:42 - Flushing DNSI 2018.09.19 13:31:45 - Checking route IPv4I 2018.09.19 13:31:46 - Checking DNS! 2018.09.19 13:31:46 - Connected.. 2018.09.19 13:31:46 - OpenVPN > Initialization Sequence Completed! 2018.09.19 13:32:44 - Disconnecting. 2018.09.19 13:32:44 - Routes, removed a route previously added, 94.100.23.163 for gateway 10.26.104.1. 2018.09.19 13:32:44 - Sending management termination signal. 2018.09.19 13:32:44 - Management - Send 'signal SIGTERM'. 2018.09.19 13:32:44 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:32:44 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:32:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 94.100.23.162 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:32:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:32:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.26.104.1. 2018.09.19 13:32:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:32:49 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.26.104.1. 2018.09.19 13:32:49 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:32:49 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:32:49 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:32:49 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:32:49 - Connection terminated.. 2018.09.19 13:32:49 - IPv6 restored with packet filtering.. 2018.09.19 13:32:50 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:32:50 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:32:50 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:32:50 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6I 2018.09.19 13:32:50 - Checking authorization ...! 2018.09.19 13:32:50 - Connecting to Sabik (United States, Los Angeles). 2018.09.19 13:32:50 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:32:50 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:32:50 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:32:50 - Connection to OpenVPN Management Interface. 2018.09.19 13:32:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:32:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:32:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:32:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.241.147.34:443. 2018.09.19 13:32:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:32:50 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:32:50 - OpenVPN > UDP link remote: [AF_INET]199.241.147.34:443. 2018.09.19 13:32:50 - OpenVPN > TLS: Initial packet from [AF_INET]199.241.147.34:443, sid=9bb8da19 c5cf8aca. 2018.09.19 13:32:51 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:32:51 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:32:51 - OpenVPN > VERIFY KU OK. 2018.09.19 13:32:51 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:32:51 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:32:51 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:32:51 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2018.09.19 13:32:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:32:51 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.241.147.34:443. 2018.09.19 13:32:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:32:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.136.1,dhcp-option DNS6 fde6:7a:7d20:1888::1,tun-ipv6,route-gateway 10.28.136.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1888::1019/64 fde6:7a:7d20:1888::1,ifconfig 10.28.136.27 255.255.255.0,peer-id 6,cipher AES-256-GCM'. 2018.09.19 13:32:52 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:32:52 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:32:52 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:32:52 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:32:52 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:32:52 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:32:52 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:32:52 - OpenVPN > GDG6: remote_host_ipv6=n/a. 2018.09.19 13:32:52 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168). 2018.09.19 13:32:52 - OpenVPN > ROUTE6: default_gateway=UNDEF. 2018.09.19 13:32:52 - OpenVPN > open_tun. 2018.09.19 13:32:52 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:32:52 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:32:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.28.136.0/10.28.136.27/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:32:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.28.136.27/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.28.136.254, lease-time: 31536000]. 2018.09.19 13:32:52 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:32:52 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1. 2018.09.19 13:32:53 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=42 fde6:7a:7d20:1888::1019 store=active. 2018.09.19 13:32:54 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1888::1 validate=no. 2018.09.19 13:32:54 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.. 2018.09.19 13:32:54 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1888::/64 -> fde6:7a:7d20:1888::1019 metric 0) dev Ethernet 2. 2018.09.19 13:32:54 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1888::/64 interface=42 fe80::8 store=active. 2018.09.19 13:32:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:33:00 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\route.exe ADD 199.241.147.34 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:33:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:33:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.28.136.1. 2018.09.19 13:33:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:33:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.28.136.1. 2018.09.19 13:33:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:33:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:33:00 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1888::1 metric -1) dev Ethernet 2. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:33:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:33:00 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1888::1 metric -1) dev Ethernet 2. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:33:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:33:00 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1888::1 metric -1) dev Ethernet 2. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:33:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:33:00 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1888::1 metric -1) dev Ethernet 2. 2018.09.19 13:33:00 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:33:00 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:33:00 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:33:00 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:33:00 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:33:00 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.28.136.1). 2018.09.19 13:33:01 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1888::1). 2018.09.19 13:33:01 - Routes, added a new route, 199.241.147.35 for gateway 10.28.136.1. 2018.09.19 13:33:01 - Routes, added a new route, 2605:8680:12:5:9a76:3402:3e24:834c for gateway fde6:7a:7d20:1888::1. 2018.09.19 13:33:01 - Flushing DNSI 2018.09.19 13:33:04 - Checking route IPv4I 2018.09.19 13:33:04 - Checking route IPv6. 2018.09.19 13:33:24 - curl: (28) Connection timed out after 20015 milliseconds. 2018.09.19 13:33:24 - Checking route (2° try). 2018.09.19 13:33:45 - curl: (28) Connection timed out after 20000 milliseconds. 2018.09.19 13:33:45 - Checking route (3° try). 2018.09.19 13:34:08 - curl: (28) Connection timed out after 20000 millisecondsE 2018.09.19 13:34:08 - Checking route IPv6 failed.. 2018.09.19 13:34:08 - OpenVPN > Initialization Sequence Completed! 2018.09.19 13:34:08 - Disconnecting. 2018.09.19 13:34:08 - Routes, removed a route previously added, 199.241.147.35 for gateway 10.28.136.1. 2018.09.19 13:34:08 - Routes, removed a route previously added, 2605:8680:12:5:9a76:3402:3e24:834c for gateway fde6:7a:7d20:1888::1. 2018.09.19 13:34:08 - Sending management termination signal. 2018.09.19 13:34:08 - Management - Send 'signal SIGTERM'. 2018.09.19 13:34:08 - OpenVPN > MANAGEMENT: CMD '0dd295ca3774e19aef9843b55f34bfe724d87cfbd3e8ed1f08c8819997929738'. 2018.09.19 13:34:17 - Sending management termination signal. 2018.09.19 13:34:17 - Management - Send 'signal SIGTERM'. 2018.09.19 13:34:17 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:34:17 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.241.147.34 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:34:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.28.136.1. 2018.09.19 13:34:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.28.136.1. 2018.09.19 13:34:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:34:22 - OpenVPN > delete_route_ipv6(::/3). 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:34:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:34:22 - OpenVPN > delete_route_ipv6(2000::/4). 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:34:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:34:22 - OpenVPN > delete_route_ipv6(3000::/4). 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:34:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:34:22 - OpenVPN > delete_route_ipv6(fc00::/7). 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:34:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:34:22 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:34:22 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1888::/64). 2018.09.19 13:34:22 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1888::/64 interface=42 fe80::8 store=active. 2018.09.19 13:34:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1888::1019 store=active. 2018.09.19 13:34:22 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all. 2018.09.19 13:34:23 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:34:23 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:34:23 - Connection terminated.. 2018.09.19 13:34:23 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:34:23 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:34:23 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:34:23 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:34:23 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6I 2018.09.19 13:34:26 - Checking authorization .... 2018.09.19 13:34:27 - IPv6 disabled with packet filtering.! 2018.09.19 13:34:27 - Connecting to Cynosura (Canada, Vancouver). 2018.09.19 13:34:27 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:34:27 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:34:27 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:34:27 - Connection to OpenVPN Management Interface. 2018.09.19 13:34:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:34:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:34:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:34:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.21:443. 2018.09.19 13:34:27 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:34:27 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:34:27 - OpenVPN > UDP link remote: [AF_INET]71.19.252.21:443. 2018.09.19 13:34:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:34:27 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=78376a88 1a38575c. 2018.09.19 13:34:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:34:27 - OpenVPN > VERIFY KU OK. 2018.09.19 13:34:27 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:34:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:34:27 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:34:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cynosura, emailAddress=info@airvpn.org. 2018.09.19 13:34:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:34:27 - OpenVPN > [Cynosura] Peer Connection Initiated with [AF_INET]71.19.252.21:443. 2018.09.19 13:34:28 - OpenVPN > SENT CONTROL [Cynosura]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:34:29 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.15.8.1,route-gateway 10.15.8.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.15.8.161 255.255.255.0,peer-id 9,cipher AES-256-GCM'. 2018.09.19 13:34:29 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:34:29 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:34:29 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:34:29 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:34:29 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:34:29 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:34:29 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:34:29 - OpenVPN > open_tun. 2018.09.19 13:34:29 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:34:29 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:34:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.15.8.0/10.15.8.161/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:34:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.15.8.161/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.15.8.254, lease-time: 31536000]. 2018.09.19 13:34:29 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:34:29 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0! 2018.09.19 13:34:31 - Disconnecting. 2018.09.19 13:34:31 - Sending management termination signal. 2018.09.19 13:34:31 - Management - Send 'signal SIGTERM'. 2018.09.19 13:34:31 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:34:31 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:34:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:34:34 - OpenVPN > C:\Windows\system32\route.exe ADD 71.19.252.21 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:34:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:34:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:34:34 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:34:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:34:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:34:34 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:34:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:34:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:34:34 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:34:34 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:34:34 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:34:34 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.15.8.1). 2018.09.19 13:34:34 - Routes, added a new route, 71.19.252.22 for gateway 10.15.8.1. 2018.09.19 13:34:34 - Flushing DNSW 2018.09.19 13:34:37 - Waiting TUN interface. 2018.09.19 13:34:48 - Above log line repeated 4 times moreW 2018.09.19 13:34:48 - Tunnel not ready in 10 seconds, contact our support. Last interface status: Down. 2018.09.19 13:34:48 - OpenVPN > Initialization Sequence Completed. 2018.09.19 13:34:48 - Connection terminated.. 2018.09.19 13:34:48 - IPv6 restored with packet filtering.. 2018.09.19 13:34:48 - Updating systems & servers data .... 2018.09.19 13:34:48 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:34:48 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:34:48 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:34:48 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6. 2018.09.19 13:34:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 71.19.252.21 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:34:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:34:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:34:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:34:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:34:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:34:48 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:34:48 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:34:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:34:48 - Flushing DNS. 2018.09.19 13:34:49 - Systems & servers data update completed! 2018.09.19 13:34:51 - Session terminated.I 2018.09.19 13:35:05 - Session starting.I 2018.09.19 13:35:05 - Checking authorization ...! 2018.09.19 13:35:06 - Connecting to Rana (Canada, Toronto, Ontario). 2018.09.19 13:35:06 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:35:06 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:35:06 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:35:06 - Connection to OpenVPN Management Interface. 2018.09.19 13:35:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:35:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:35:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:35:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]199.19.94.132:443. 2018.09.19 13:35:06 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:35:06 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:35:06 - OpenVPN > UDP link remote: [AF_INET]199.19.94.132:443. 2018.09.19 13:35:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:35:06 - OpenVPN > TLS: Initial packet from [AF_INET]199.19.94.132:443, sid=382ab5b6 e99e68fb. 2018.09.19 13:35:06 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:35:06 - OpenVPN > VERIFY KU OK. 2018.09.19 13:35:06 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:35:06 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:35:06 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:35:06 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2018.09.19 13:35:07 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:35:07 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]199.19.94.132:443. 2018.09.19 13:35:08 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:35:08 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.27.200.1,dhcp-option DNS6 fde6:7a:7d20:17c8::1,tun-ipv6,route-gateway 10.27.200.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:17c8::10f9/64 fde6:7a:7d20:17c8::1,ifconfig 10.27.200.251 255.255.255.0,peer-id 13,cipher AES-256-GCM'. 2018.09.19 13:35:08 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:35:08 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:35:08 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:35:08 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:35:08 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:35:08 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:35:08 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:35:08 - OpenVPN > GDG6: remote_host_ipv6=n/a. 2018.09.19 13:35:08 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168). 2018.09.19 13:35:08 - OpenVPN > ROUTE6: default_gateway=UNDEF. 2018.09.19 13:35:08 - OpenVPN > open_tun. 2018.09.19 13:35:08 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:35:08 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:35:08 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.27.200.0/10.27.200.251/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:35:08 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.27.200.251/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.27.200.254, lease-time: 31536000]. 2018.09.19 13:35:08 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:35:08 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1. 2018.09.19 13:35:09 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=42 fde6:7a:7d20:17c8::10f9 store=active. 2018.09.19 13:35:10 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:17c8::1 validate=no. 2018.09.19 13:35:10 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.. 2018.09.19 13:35:10 - OpenVPN > add_route_ipv6(fde6:7a:7d20:17c8::/64 -> fde6:7a:7d20:17c8::10f9 metric 0) dev Ethernet 2. 2018.09.19 13:35:10 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:17c8::/64 interface=42 fe80::8 store=active. 2018.09.19 13:35:10 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:35:15 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:35:15 - OpenVPN > C:\Windows\system32\route.exe ADD 199.19.94.132 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:35:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:35:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:35:15 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.27.200.1. 2018.09.19 13:35:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:35:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:35:15 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.27.200.1. 2018.09.19 13:35:15 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:35:15 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:35:15 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:17c8::1 metric -1) dev Ethernet 2. 2018.09.19 13:35:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:35:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:35:15 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:17c8::1 metric -1) dev Ethernet 2. 2018.09.19 13:35:15 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:35:15 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:35:16 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:17c8::1 metric -1) dev Ethernet 2. 2018.09.19 13:35:16 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:35:16 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:35:16 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:17c8::1 metric -1) dev Ethernet 2. 2018.09.19 13:35:16 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:35:16 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:35:16 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:35:16 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:35:16 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:35:16 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.27.200.1). 2018.09.19 13:35:16 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:17c8::1). 2018.09.19 13:35:16 - Routes, added a new route, 199.19.94.135 for gateway 10.27.200.1. 2018.09.19 13:35:17 - Routes, added a new route, 2604:6880:c713:5e84:a4ee:64a5:d8f2:e5c0 for gateway fde6:7a:7d20:17c8::1. 2018.09.19 13:35:17 - Flushing DNSI 2018.09.19 13:35:20 - Checking route IPv4I 2018.09.19 13:35:20 - Checking route IPv6. 2018.09.19 13:35:40 - curl: (28) Connection timed out after 20016 milliseconds. 2018.09.19 13:35:40 - Checking route (2° try). 2018.09.19 13:36:01 - curl: (28) Connection timed out after 20000 milliseconds. 2018.09.19 13:36:01 - Checking route (3° try). 2018.09.19 13:36:23 - curl: (28) Connection timed out after 20000 millisecondsE 2018.09.19 13:36:23 - Checking route IPv6 failed.. 2018.09.19 13:36:23 - OpenVPN > Initialization Sequence Completed! 2018.09.19 13:36:23 - Disconnecting. 2018.09.19 13:36:24 - Routes, removed a route previously added, 199.19.94.135 for gateway 10.27.200.1. 2018.09.19 13:36:24 - Routes, removed a route previously added, 2604:6880:c713:5e84:a4ee:64a5:d8f2:e5c0 for gateway fde6:7a:7d20:17c8::1. 2018.09.19 13:36:24 - Sending management termination signal. 2018.09.19 13:36:24 - Management - Send 'signal SIGTERM'. 2018.09.19 13:36:24 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:36:24 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 199.19.94.132 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:36:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.27.200.1. 2018.09.19 13:36:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.27.200.1. 2018.09.19 13:36:30 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:36:30 - OpenVPN > delete_route_ipv6(::/3). 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:36:30 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:36:30 - OpenVPN > delete_route_ipv6(2000::/4). 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:36:30 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:36:30 - OpenVPN > delete_route_ipv6(3000::/4). 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:36:30 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:36:30 - OpenVPN > delete_route_ipv6(fc00::/7). 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:36:30 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:36:30 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:36:30 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:17c8::/64). 2018.09.19 13:36:30 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:17c8::/64 interface=42 fe80::8 store=active. 2018.09.19 13:36:30 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:17c8::10f9 store=active. 2018.09.19 13:36:30 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all. 2018.09.19 13:36:30 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:36:30 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:36:30 - Connection terminated.. 2018.09.19 13:36:30 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:36:30 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:36:30 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:36:31 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:36:31 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6I 2018.09.19 13:36:34 - Checking authorization .... 2018.09.19 13:36:34 - IPv6 disabled with packet filtering.! 2018.09.19 13:36:34 - Connecting to Cynosura (Canada, Vancouver). 2018.09.19 13:36:34 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:36:34 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:36:34 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:36:34 - Connection to OpenVPN Management Interface. 2018.09.19 13:36:34 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:36:34 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:36:34 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:36:34 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.21:443. 2018.09.19 13:36:34 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:36:34 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:36:34 - OpenVPN > UDP link remote: [AF_INET]71.19.252.21:443. 2018.09.19 13:36:34 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=a247f314 416f84cc. 2018.09.19 13:36:35 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:36:35 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:36:35 - OpenVPN > VERIFY KU OK. 2018.09.19 13:36:35 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:36:35 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:36:35 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:36:35 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cynosura, emailAddress=info@airvpn.org. 2018.09.19 13:36:35 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:36:35 - OpenVPN > [Cynosura] Peer Connection Initiated with [AF_INET]71.19.252.21:443. 2018.09.19 13:36:36 - OpenVPN > SENT CONTROL [Cynosura]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:36:36 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.15.8.1,route-gateway 10.15.8.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.15.8.161 255.255.255.0,peer-id 5,cipher AES-256-GCM'. 2018.09.19 13:36:36 - OpenVPN > Pushed option removed by filter: 'redirect-gateway def1 bypass-dhcp'. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:36:36 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:36:36 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:36:36 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:36:36 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:36:36 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:36:36 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:36:36 - OpenVPN > open_tun. 2018.09.19 13:36:36 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:36:36 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:36:36 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.15.8.0/10.15.8.161/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:36:36 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.15.8.161/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.15.8.254, lease-time: 31536000]. 2018.09.19 13:36:36 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:36:36 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2018.09.19 13:36:42 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:36:42 - OpenVPN > C:\Windows\system32\route.exe ADD 71.19.252.21 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:36:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:36:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:36:42 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:36:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:36:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:36:42 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:36:42 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:36:42 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:36:42 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:36:42 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:36:42 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:36:42 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.15.8.1)W 2018.09.19 13:36:42 - Routes, add 71.19.252.22 for gateway 10.15.8.1 failed: The route addition failed: The object already exists. 2018.09.19 13:36:42 - Flushing DNSI 2018.09.19 13:36:45 - Checking route IPv4I 2018.09.19 13:36:46 - Checking DNS! 2018.09.19 13:36:46 - Connected.. 2018.09.19 13:36:46 - OpenVPN > Initialization Sequence Completed! 2018.09.19 13:37:03 - Disconnecting. 2018.09.19 13:37:03 - Sending management termination signal. 2018.09.19 13:37:03 - Management - Send 'signal SIGTERM'. 2018.09.19 13:37:03 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:37:03 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:37:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 71.19.252.21 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:37:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:37:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:37:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:37:08 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.15.8.1. 2018.09.19 13:37:08 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:37:08 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:37:08 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:37:08 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:37:08 - Connection terminated.. 2018.09.19 13:37:08 - IPv6 restored with packet filtering.. 2018.09.19 13:37:08 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:37:08 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:37:08 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:37:08 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6. 2018.09.19 13:37:08 - Flushing DNS! 2018.09.19 13:37:11 - Session terminated.! 2018.09.19 13:37:13 - Deactivation of Network Lock! 2018.09.19 13:40:38 - Activation of Network Lock - Windows Filtering PlatformI 2018.09.19 13:40:44 - Session starting.I 2018.09.19 13:40:45 - Checking authorization .... 2018.09.19 13:40:45 - IPv6 disabled with packet filtering.! 2018.09.19 13:40:45 - Connecting to Cynosura (Canada, Vancouver). 2018.09.19 13:40:45 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:40:45 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:40:45 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:40:45 - Connection to OpenVPN Management Interface. 2018.09.19 13:40:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:40:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:40:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:40:45 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.21:443. 2018.09.19 13:40:45 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:40:45 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:40:45 - OpenVPN > UDP link remote: [AF_INET]71.19.252.21:443. 2018.09.19 13:40:45 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=325e390d cdaa10ac. 2018.09.19 13:40:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:40:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:40:46 - OpenVPN > VERIFY KU OK. 2018.09.19 13:40:46 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:40:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:40:46 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:40:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cynosura, emailAddress=info@airvpn.org. 2018.09.19 13:41:17 - OpenVPN > [Cynosura] Inactivity timeout (--ping-exit), exiting. 2018.09.19 13:41:17 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:41:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2018.09.19 13:41:22 - Disconnecting. 2018.09.19 13:41:22 - Connection terminated.. 2018.09.19 13:41:22 - IPv6 restored with packet filtering.I 2018.09.19 13:41:25 - Checking authorization ...! 2018.09.19 13:41:25 - Connecting to Rotanev (Canada, Toronto, Ontario). 2018.09.19 13:41:25 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:41:25 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:41:25 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:41:25 - Connection to OpenVPN Management Interface. 2018.09.19 13:41:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:41:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:41:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:41:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.186:443. 2018.09.19 13:41:25 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:41:25 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:41:25 - OpenVPN > UDP link remote: [AF_INET]104.254.90.186:443. 2018.09.19 13:41:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:41:26 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.186:443, sid=44bae9db a9416d6c. 2018.09.19 13:41:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:41:26 - OpenVPN > VERIFY KU OK. 2018.09.19 13:41:26 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:41:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:41:26 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:41:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2018.09.19 13:41:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:41:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.186:443. 2018.09.19 13:41:27 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:41:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.28.72.1,dhcp-option DNS6 fde6:7a:7d20:1848::1,tun-ipv6,route-gateway 10.28.72.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:1848::104e/64 fde6:7a:7d20:1848::1,ifconfig 10.28.72.80 255.255.255.0,peer-id 5,cipher AES-256-GCM'. 2018.09.19 13:41:27 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:41:27 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:41:27 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:41:27 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:41:27 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:41:27 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:41:27 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:41:27 - OpenVPN > GDG6: remote_host_ipv6=n/a. 2018.09.19 13:41:27 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168). 2018.09.19 13:41:27 - OpenVPN > ROUTE6: default_gateway=UNDEF. 2018.09.19 13:41:27 - OpenVPN > open_tun. 2018.09.19 13:41:27 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:41:27 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:41:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.28.72.0/10.28.72.80/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:41:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.28.72.80/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.28.72.254, lease-time: 31536000]. 2018.09.19 13:41:27 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:41:27 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1. 2018.09.19 13:41:28 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=42 fde6:7a:7d20:1848::104e store=active. 2018.09.19 13:41:29 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:1848::1 validate=no. 2018.09.19 13:41:29 - OpenVPN > add_route_ipv6(fde6:7a:7d20:1848::/64 -> fde6:7a:7d20:1848::104e metric 0) dev Ethernet 2. 2018.09.19 13:41:29 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:1848::/64 interface=42 fe80::8 store=active. 2018.09.19 13:41:29 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:41:34 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.186 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:41:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:41:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.28.72.1. 2018.09.19 13:41:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:41:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.28.72.1. 2018.09.19 13:41:34 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:41:34 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:41:34 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:1848::1 metric -1) dev Ethernet 2. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:41:34 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:41:34 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:1848::1 metric -1) dev Ethernet 2. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:41:34 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:41:34 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:1848::1 metric -1) dev Ethernet 2. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:41:34 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:41:34 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:1848::1 metric -1) dev Ethernet 2. 2018.09.19 13:41:34 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:41:34 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:41:35 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:41:35 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:41:35 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:41:35 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.28.72.1). 2018.09.19 13:41:35 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:1848::1). 2018.09.19 13:41:35 - Routes, added a new route, 104.254.90.187 for gateway 10.28.72.1. 2018.09.19 13:41:35 - Routes, added a new route, 2606:6080:2001:5:48ec:2d6:cc35:3864 for gateway fde6:7a:7d20:1848::1. 2018.09.19 13:41:35 - Flushing DNSI 2018.09.19 13:41:39 - Checking route IPv4I 2018.09.19 13:41:39 - Checking route IPv6. 2018.09.19 13:41:59 - curl: (28) Connection timed out after 20000 milliseconds. 2018.09.19 13:41:59 - Checking route (2° try). 2018.09.19 13:42:20 - curl: (28) Connection timed out after 20015 milliseconds. 2018.09.19 13:42:20 - Checking route (3° try). 2018.09.19 13:42:42 - curl: (28) Connection timed out after 20000 millisecondsE 2018.09.19 13:42:42 - Checking route IPv6 failed.. 2018.09.19 13:42:42 - OpenVPN > Initialization Sequence Completed! 2018.09.19 13:42:42 - Disconnecting. 2018.09.19 13:42:43 - Routes, removed a route previously added, 104.254.90.187 for gateway 10.28.72.1. 2018.09.19 13:42:43 - Routes, removed a route previously added, 2606:6080:2001:5:48ec:2d6:cc35:3864 for gateway fde6:7a:7d20:1848::1. 2018.09.19 13:42:43 - Sending management termination signal. 2018.09.19 13:42:43 - Management - Send 'signal SIGTERM'. 2018.09.19 13:42:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2018.09.19 13:42:43 - OpenVPN > SIGTERM received, sending exit notification to peer. 2018.09.19 13:42:43 - OpenVpn Management > SUCCESS: signal SIGTERM thrown. 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 104.254.90.186 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:42:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.28.72.1. 2018.09.19 13:42:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.28.72.1. 2018.09.19 13:42:48 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2018.09.19 13:42:48 - OpenVPN > delete_route_ipv6(::/3). 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:42:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:42:48 - OpenVPN > delete_route_ipv6(2000::/4). 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:42:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:42:48 - OpenVPN > delete_route_ipv6(3000::/4). 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:42:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:42:48 - OpenVPN > delete_route_ipv6(fc00::/7). 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:42:48 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:42:48 - OpenVPN > Closing TUN/TAP interface. 2018.09.19 13:42:48 - OpenVPN > delete_route_ipv6(fde6:7a:7d20:1848::/64). 2018.09.19 13:42:48 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 delete route fde6:7a:7d20:1848::/64 interface=42 fe80::8 store=active. 2018.09.19 13:42:48 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete address Ethernet 2 fde6:7a:7d20:1848::104e store=active. 2018.09.19 13:42:48 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 delete dns Ethernet 2 all. 2018.09.19 13:42:48 - OpenVPN > TAP: DHCP address released. 2018.09.19 13:42:48 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2018.09.19 13:42:48 - Connection terminated.. 2018.09.19 13:42:49 - DNS IPv4 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:42:49 - DNS IPv6 of a network adapter restored to original settings (Ethernet 2, to automatic). 2018.09.19 13:42:49 - DNS leak protection with packet filtering disabled.. 2018.09.19 13:42:49 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv4. 2018.09.19 13:42:49 - Interface Ethernet 2 metric restored from 3 to Automatic, layer IPv6I 2018.09.19 13:42:52 - Checking authorization ...! 2018.09.19 13:42:52 - Connecting to Gorgonea (Canada, Toronto, Ontario). 2018.09.19 13:42:53 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.09.19 13:42:53 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.09.19 13:42:53 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.09.19 13:42:53 - Connection to OpenVPN Management Interface. 2018.09.19 13:42:53 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.09.19 13:42:53 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:42:53 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.09.19 13:42:53 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.250:443. 2018.09.19 13:42:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]. 2018.09.19 13:42:53 - OpenVPN > UDP link local: (not bound). 2018.09.19 13:42:53 - OpenVPN > UDP link remote: [AF_INET]104.254.90.250:443. 2018.09.19 13:42:53 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.09.19 13:42:53 - OpenVPN > TLS: Initial packet from [AF_INET]104.254.90.250:443, sid=8d677a60 0d8bc125. 2018.09.19 13:42:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2018.09.19 13:42:53 - OpenVPN > VERIFY KU OK. 2018.09.19 13:42:53 - OpenVPN > Validating certificate extended key usage. 2018.09.19 13:42:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2018.09.19 13:42:53 - OpenVPN > VERIFY EKU OK. 2018.09.19 13:42:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2018.09.19 13:42:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2018.09.19 13:42:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]104.254.90.250:443. 2018.09.19 13:42:54 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2018.09.19 13:42:54 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.18.8.1,dhcp-option DNS6 fde6:7a:7d20:e08::1,tun-ipv6,route-gateway 10.18.8.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:e08::1046/64 fde6:7a:7d20:e08::1,ifconfig 10.18.8.72 255.255.255.0,peer-id 2,cipher AES-256-GCM'. 2018.09.19 13:42:54 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: peer-id set. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2018.09.19 13:42:54 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2018.09.19 13:42:54 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'. 2018.09.19 13:42:54 - OpenVPN > Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:42:54 - OpenVPN > Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key. 2018.09.19 13:42:54 - OpenVPN > interactive service msg_channel=0. 2018.09.19 13:42:54 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=4 HWADDR=ac:fd:ce:d0:df:45. 2018.09.19 13:42:54 - OpenVPN > GDG6: remote_host_ipv6=n/a. 2018.09.19 13:42:54 - OpenVPN > NOTE: GetBestInterfaceEx returned error: Element not found. (code=1168). 2018.09.19 13:42:54 - OpenVPN > ROUTE6: default_gateway=UNDEF. 2018.09.19 13:42:54 - OpenVPN > open_tun. 2018.09.19 13:42:55 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{4601D87B-ACF0-4172-B79D-446234B34813}.tap. 2018.09.19 13:42:55 - OpenVPN > TAP-Windows Driver Version 9.21. 2018.09.19 13:42:55 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.18.8.0/10.18.8.72/255.255.255.0 [sUCCEEDED]. 2018.09.19 13:42:55 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.18.8.72/255.255.255.0 on interface {4601D87B-ACF0-4172-B79D-446234B34813} [DHCP-serv: 10.18.8.254, lease-time: 31536000]. 2018.09.19 13:42:55 - OpenVPN > Successful ARP Flush on interface [42] {4601D87B-ACF0-4172-B79D-446234B34813}. 2018.09.19 13:42:55 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=1. 2018.09.19 13:42:55 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set address interface=42 fde6:7a:7d20:e08::1046 store=active. 2018.09.19 13:42:57 - OpenVPN > NETSH: C:\Windows\system32\netsh.exe interface ipv6 set dns Ethernet 2 static fde6:7a:7d20:e08::1 validate=no. 2018.09.19 13:42:57 - Detected an OpenVPN bug (On-Link route on VPN range), autofix.. 2018.09.19 13:42:57 - OpenVPN > add_route_ipv6(fde6:7a:7d20:e08::/64 -> fde6:7a:7d20:e08::1046 metric 0) dev Ethernet 2. 2018.09.19 13:42:57 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fde6:7a:7d20:e08::/64 interface=42 fe80::8 store=active. 2018.09.19 13:42:57 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:43:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\route.exe ADD 104.254.90.250 MASK 255.255.255.255 192.168.0.1. 2018.09.19 13:43:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=50 and dwForwardType=4. 2018.09.19 13:43:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.18.8.1. 2018.09.19 13:43:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:43:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.18.8.1. 2018.09.19 13:43:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=35 and dwForwardType=4. 2018.09.19 13:43:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2018.09.19 13:43:02 - OpenVPN > add_route_ipv6(::/3 -> fde6:7a:7d20:e08::1 metric -1) dev Ethernet 2. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route ::/3 interface=42 fe80::8 store=active. 2018.09.19 13:43:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:43:02 - OpenVPN > add_route_ipv6(2000::/4 -> fde6:7a:7d20:e08::1 metric -1) dev Ethernet 2. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 2000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:43:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:43:02 - OpenVPN > add_route_ipv6(3000::/4 -> fde6:7a:7d20:e08::1 metric -1) dev Ethernet 2. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route 3000::/4 interface=42 fe80::8 store=active. 2018.09.19 13:43:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:43:02 - OpenVPN > add_route_ipv6(fc00::/7 -> fde6:7a:7d20:e08::1 metric -1) dev Ethernet 2. 2018.09.19 13:43:02 - OpenVPN > C:\Windows\system32\netsh.exe interface ipv6 add route fc00::/7 interface=42 fe80::8 store=active. 2018.09.19 13:43:02 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2018.09.19 13:43:03 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv4. 2018.09.19 13:43:03 - Interface Ethernet 2 metric changed from Automatic to 3, layer IPv6. 2018.09.19 13:43:03 - DNS leak protection with packet filtering enabled.. 2018.09.19 13:43:03 - DNS IPv4 of a network adapter forced (Ethernet 2, from automatic to 10.18.8.1). 2018.09.19 13:43:03 - DNS IPv6 of a network adapter forced (Ethernet 2, from automatic to fde6:7a:7d20:e08::1). 2018.09.19 13:43:03 - Routes, added a new route, 104.254.90.251 for gateway 10.18.8.1. 2018.09.19 13:43:03 - Routes, added a new route, 2606:6080:2001:a:9374:410c:ca5:d631 for gateway fde6:7a:7d20:e08::1. 2018.09.19 13:43:03 - Flushing DNSI 2018.09.19 13:43:06 - Checking route IPv4I 2018.09.19 13:43:07 - Checking route IPv6. 2018.09.19 13:43:27 - curl: (28) Connection timed out after 20016 milliseconds. 2018.09.19 13:43:27 - Checking route (2° try) Quote Share this post Link to post
go558a83nk 352 Posted ... The suggestion to turn off IPv6 is probably on the right track. You can have Eddie turn of IPv6 upon connection - see settings. It's the checking route IPv6 that's failing. Quote Share this post Link to post
OpenSourcerer 1359 Posted ... Set the network lock mode to Windows Firewall and retry. If it always was on Automatic, maybe it's now choosing WFP for a change and that's why it's not working... Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
