I have AirVPN all set up and running great on a pf Sense router that my home network sits behind. I am trying to get port forwarding set up for torrenting on a server running Windows Server 2016. As far as I can tell everything is set up exactly as it should be but I just can't get it to work. I am connected to Metallah. I have created the forwarded port on the AirVPN site. I have the port open in my Windows firewall. I have the port forwarded in pfSense. I have my torrent client configured to listen on the port I've set up in AirVPN and pfSense and I have my torrent client running with an active torrent trying to download.
I have verified that the port is open and can be connected to on my LAN. I have tried 2 different torrent clients (qBittorrent and Deluge) as well as a port listener tool that simply opens any port you specify on TCP or UDP and just listens for connections. When I check the port on the AirVPN site I get error 110 timeout. I've also tried other sites and tools for performing external tests on that port and they all indicate that the port is not open. I have tried creating several new ports on AirVPN (at least 4) and tested on multiple computers on my network all with new corresponding NAT rules in pfSense. No matter what I do I can't get port forwarding to work and I'm at my wits end. I hope someone can help me figure this out.
Here is a screenshot of my NAT rule in pfSense.
