Not connected, Your IP: 3.145.23.123
keikari
Eddie freezes at startup
Hi.
Today when I started pc, Eddie(2.16.3) just froze. I tried to force kill and restart eddie, but it still froze instantly. I tried to reboot to older kernel but didn't make any difference.
I have had same kind of random freezes daily when using eddie(with every version I've had). But force killing and restarting eddie has always worked for them.
Running Fedora 28.
Here is a log file.
There is what happened last time it worked and freezing from startup start from 10:41
~90% in then end of the logcat is same kind of lines.
https://pastebin.com/RcEDB12t
EDIT:
Removing ~/.airvpn folder fixed issue.
Yesterday I added some IPs to run outside of vpn. (League Of Legends server ip) But I didn't find correct ip and I deleted the changes from settings.
EDIT2:
After setting auto lock network at startup. The client freezes again. It always freezes a while when it's set like that, but I waited many minutes and nothing happened.
I still have some issues. Now I can't deactivate network lock. I click deactivate, it goes ok, but network is still locked. I though I would try to re-lock it and now I've been looking "Activation of Network Lock - Linux iptables" text for 5mins. Program isn't frozen this time.
What should I do to make my linux installation to be like there never was eddie installed. I've tried to remove eddie and ~/.airvpn folder. I would like to test fresh re-installation.
EDIT: Tried whole remove again and this time restarted pc before re-installing and now I believe it works like it used(bit buggy, but still good if you got some patience).
I might have had one ip set to run outside of tunnel twice(can't really check it to make sure). Once as address itself and once within an "ip range" thing, could this have been reason for this weird behavior?
