Every time I try to log in to my bank website over VPN it gives me issues, so I was wondering how I can exclude the bank website's traffic from going over the VPN using the eddie client?
How to send bank website traffic over regular network instead of VPN
#2
Posted 25 August 2018 - 09:03 AM
If it's the router, simple answer to your question is its possible in theory to create static routes towards known IPs (some people have done this to connect to Netflix for example) but this is not simple.
The easy solution is to exclude a device from connecting to the VPN. But it defeats the point of setting up a VPN....
#4
Posted 27 August 2018 - 09:29 AM
Exclude traffic to/from the bank IP addresses from the VPN tunnel. If you run Eddie you can do that in "Preferences" > "Routes".
- A556 likes this
#5
Posted 27 August 2018 - 09:47 AM
What are you using to connect to the VPN? Is it a router with a DD-WRT firmware? Or the Eddie App?
I am using the Eddie software for Windows
#6
Posted 27 August 2018 - 09:48 AM
Is it possible for me to exclude traffic from the bank's domain rather than manually entering all the IP addresses because this is a large national Bank and has tons of IP addressesEvery time I try to log in to my bank website over VPN it gives me issues, so I was wondering how I can exclude the bank website's traffic from going over the VPN using the eddie client?
Similar Topics
Topic | Forum | Started By | Stats | Last Post Info | |
airvpn.org and Netflix blocked |
Blocked websites warning | chuckhammerberry |
Frequent VPN error messages on Android.![]() |
Eddie - AirVPN Client | cdysthe |
eddie on ubuntu LTS uses older openvpn and stunnel versions![]() |
Eddie - AirVPN Client | lazyevaluator |
How-to: AirVPN on Synology DS6 complete guide![]() |
How-To | Mikeyy |
Pinned Alternative AirVPN client with provider-independent double-hop support (GNU/Linux)![]() |
Off-Topic | corrado |
Also tagged with one or more of these keywords: eddie, windows
Community →
Eddie - AirVPN Client →
Persistent tunnel on Android causing problems.Started by cdysthe, 12 Feb 2019 ![]() |
Community →
Howto build eddie-cli for ARMv6?Started by gladde, 05 Feb 2019 ![]() |
![]() Tiny eddie-UIStarted by namefirstlast, 05 Feb 2019 ![]() |
Community →
Troubleshooting and Problems →
Windows 10 -- Cannot connect automatically using OpenVPN GUIStarted by boggleholeclough^, 29 Jan 2019 ![]() |
Community →
Interactive Wrapper for Eddie's CLI versionStarted by nwlyoc, 29 Jan 2019 ![]() |
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
