scgt1 3 Posted ... Seems I'm on an older 2.13.6 and I was looking at updating. If I run the install file does it update or replace the current Eddie. Regardless of which it does will it keep my settings intact or should I go through and screen shot each setting page so I can migrate settings over? Quote Share this post Link to post
scgt1 3 Posted ... Guess I'll just take screen shots of every single settings screen since no one chimed in to confirm if Eddie just updates or is replaced and settings are wiped when running the install for a newer version. Quote Share this post Link to post
Staff 9751 Posted ... Hello! The settings are not wiped out when you upgrade. The file "default.xml" or "AirVPN.xml" in older versions keeps all of your settings, so you can back it up for additional safety. Note: if you have defined customized profiles, of course you will have additional xml files. Kind regards 2 scgt1 and popofthetops reacted to this Quote Share this post Link to post
scgt1 3 Posted ... Hello! The settings are not wiped out when you upgrade. The file "default.xml" or "AirVPN.xml" in older versions keeps all of your settings, so you can back it up for additional safety. Note: if you have defined customized profiles, of course you will additional xml files. Kind regardsThanks for the response. I haven't gotten around to taking screen shots of all the settings yet so this will save that time. LOL Quote Share this post Link to post
