Not connected, Your IP: 54.160.243.44
i thought i had this issue figured out and was closed
https://airvpn.org/topic/16427-high-latency-lost-connection-durring-hourly-tls-rekeying/?do=findComment&comment=35775
But, i have not had any issue for the last 7 month and have happily forgot the problems i had. But suddenly is it a issue again.
I am loosing connection every hour during the TLS-rekeying where there is a drop in my connection for up to 6-10sec. I thought i was a issue with my router RT-ac66u with lack of CPU power. But the last 7-8 month hasnt there been any problems. So i can only conclude it isnt a client issue?!
i have attached my log file during the TLS rekeying. see the timestamps 21.26.10 - 21.26.16 the 6 sec difference is a drop in connection.
Jul 31 21:26:10 openvpn[11656]: TLS: soft reset sec=0 bytes=894520/-1 pkts=7903/0
Jul 31 21:26:10 openvpn[11656]: VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Jul 31 21:26:10 openvpn[11656]: Validating certificate key usage
Jul 31 21:26:10 openvpn[11656]: ++ Certificate has key usage  00a0, expects 00a0
Jul 31 21:26:10 openvpn[11656]: VERIFY KU OK
Jul 31 21:26:10 openvpn[11656]: Validating certificate extended key usage
Jul 31 21:26:10 openvpn[11656]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Jul 31 21:26:10 openvpn[11656]: VERIFY EKU OK
Jul 31 21:26:10 openvpn[11656]: VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Jul 31 21:26:16 openvpn[11656]: Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
Jul 31 21:26:16 openvpn[11656]: Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
Jul 31 21:26:16 openvpn[11656]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Any ideas?
To whom it might be of interest...
Problem is solved. Got a AC86U with 1.8Ghz dual core CPU and AES instruction set and the latency problem is gone.
openvpn / openssl does shut down datalink during tls rekeying on slow cpu.
